"If it comes to that we'll have to give it our all," Alicia says. If the guardian mimics its form and probably its power then even if they do avoid a fight with the world serpent they'll have to fight something just like it later anyway.
With that you notice something ahead. About half a mile away you see something come around the corner of the burrow-tunnel. A solar flies ahead, coming in your direction. He is clad in heavy armor and helm, nothing but his wings visible, and even those are heavily armored. He carries a fullblade in hand, a massive sword large even for a solar. It's more like a slab of steel with an edge than a real sword.
"Oh look, our next fight," Syala says, "Wonder who he wants to challenge?"
"One of you should take it since I had the last one," Alicia says, it being important to spread such things around.
"I'll take him," Syala strides forward, Blessing of the Twelve in hand. In response the celestial raises his blade to the air, a salute back.
"Goddess," The celestial calls, "I, Radodiel, challenge you!"
Syala stops at 100ft away and beckons him closer, "It's your life to lose," Syala says pleasantly, "Accepted!"
Antenora takes 10 for 56 on K:P, and will set up divine insight for further checks with alter reality.
In the meantime Antenora sends to Alicia, 'Radodiel, I've heard of the name but it's an old one. Likely a celestial out of sight serving Jormugandr for eternity. I fear Syala is at a reach disadvantage, but I doubt that will slow her down in the slightest.'
Most of the celestials in here are likely powerful but unknown to the wider world, even more obscure than Heavenly Rock. She nods to Antenora, "Unless a decisive blow is struck with it, the reach advantage is only ever a temporary one," she says quietly.
No more words as Syala and Radoliel clash, the two coming together, weapons at the ready.
> roll 1d20+12 Syala
<Penuche> Kotono invokes Penuche's magic: < 17 > [d20=5]
> roll 1d20+17 Radoliel
<Penuche> Kotono invokes Penuche's magic: < 27 > [d20=10]
Init is Radoliel (27) > Syala (17)
Radoliel charges forward, his great blade swinging ahead. From it light comes as he rushes in, the blade a sword of light that reaches far as he stops 30ft away and swings.
> roll 1d20+75 (+2 charge, +4 ???, +1 blinding speed, +2 ???, +8 ???)
<Penuche> Kotono invokes Penuche's magic: < 81 > [d20=6]
Yet Syala is too much. She glides through the blade, a moment where she is gone, only to reappear past the swing. As she does columns of burning, white hot flame erupt out all around Syala, great pillars of it that reach almost to the ceiling high above.
> roll 1d20+40 SR
<Penuche> Kotono invokes Penuche's magic: < 55 > [d20=15]
Ref save for Syala.
> roll 1d20+46 Syala Ref
<Penuche> Kotono invokes Penuche's magic: < 61 > [d20=15]
200 searing fire damage. So 100 and then halved for 50 damage to Syala. Negative status negated as Syala is immune to stunning.
The flame pillars dance and whirl, Syala brushed and burnt. But it's only that as the pillars stay up, spreading and moving, tracking Syala. She's grinning now as she meets his charge with one of her own, taking a swipe as she does.
AoO provoked.
> roll 1d20+73 (+4 ???, +1 blinding speed, +2 ???, +8 ???)
<Penuche> Kotono invokes Penuche's magic: < 86 > [d20=13]
Again Syala dodges that blade and the light that comes from it, as she brings her hammer down.
> roll 1d20+64 (+2 charge, +3 luck, testing the ol' defenses)
<Penuche> Kotono invokes Penuche's magic: < 77 > [d20=13]
In turn Syala's blow is stopped by a pillar of flame that erupts out just before Radoliel, which forces Syala back. As this happens...
Round 1 over, go ahead and react while I post to other topics.
Antenora
HP: 840/840
Bonuses: Attack+3 (+3 luck), Damage+0 AC+6 (+3 morale, +3 luck), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Resources: Holy Fury 38/39 (enc) Divine Retribution 1/1 Smite Evil 13/13 Channel Energy 17/17 Lay On Hands 490/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 25/25 Divine Blast 17/17
Spells Used: Opal Protection
SLAs Used:
Spells Active: Mind Blank (CL36), Recitation (CL36), Opal Protection (CL36)
Syala
HP: 650/700
Bonuses: Attack+3 (+3 luck), Damage+0 AC+24 (+3 morale, +3 luck, +18 armor), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Spells Used: 1 10th level spell
SLAs Used:
Spells Active: Mind Blank (CL36), Energy Immunity(Fire)(CL35), Epic Mage Armor (CL35), Recitation (CL36), Opal Protection (CL36)
"His magic is strong," Alicia says, watching it play out. "That wasn't much more than an upscaled flame strike but it had a lot of force behind it."
"They're not going away, it's a formidable trick," Antenora watches the combat, "They're moving, I suspect he controls them."
Meanwhile it is a clash of fire and fury. All the flame pillars converge on Syala, attempting to entomb her in flame.
<Penuche> Kotono invokes Penuche's magic: < 66 > [d20=20]
Again this boils down to 50 damage that gets through and stun being negated.
Syala has no choice but to leap back, to dodge fully on as the pillars of fire surround Radoliel. The way to him is obscured completely, hidden by great eruptions of searing white fire. Syala flies up and back, another swipe through the flame as she does.
<Penuche> Kotono invokes Penuche's magic: < 85 > [d20=12]
Syala is too fast again, avoiding the light as she points and utters a word of profound power, one that causes the air around the flames to erupt and crack.
Superb dispelling.
> roll 1d20+35
<Penuche> Kotono invokes Penuche's magic: < 53 > [d20=18]
A great woooosh of flame comes as the pillars collapse in on themselves, embers of flame raining down all around. They are gone now, Radoliel revealed once more.
'Can he do it again and again, or is he only good for it once?' Antenora asks you in your mind.
The Child of Fire watches those flames, "Radoliel understands fire," he speaks now, "The heat of Ysgard's bones is his teacher."
Round 2 done.
Antenora
HP: 840/840
SLAs Used:
Syala
HP: 600/700
Spells Used: 1 10th level spell, 1 11th level spell.
SLAs Used:
"It's a powerful spell, but Syala had to dig deep to dispel it and she's been scorched a bit," Alicia says to Antenora. "And since we still have much further to go, attrition favours Radoliel."
Antenora nods faintly as Radoliel raises his blade up. Light of all colors floods into it, a rainbow glow around it. "Come forth and smite," he cries, as more and more light comes to it by the moment.
"Radoliel, I hope you can take all the light I have to give," Syala declares, "Lathander's light, burst!" she intones, as a sunstorm explodes out, the entire area suddenly awash in glorious sunshine.
She's taking a page from Latha's book (Don't worry, Latha's used to it, and sunstorm isn't a unique spell for her anyway) and casting sunstorm.
> roll 1d20+35
<Penuche> Kotono invokes Penuche's magic: < 52 > [d20=17]
No damage to Radodiel because of what his sword is doing, but a Fort save is called for.
> roll 1d20+30
<Penuche> Kotono invokes Penuche's magic: < 44 > [d20=14]
> roll 35d8 sword
<Penuche> Kotono invokes Penuche's magic: < 174 > [d8=5,6,7,1,4,2,3,4,7,7,1,8,5,7,3,1,8,2,3,4,5,8,6,6,7,7,1,7,3,7,8,7,6,4,4]
With a loud CRACK Radodiel's sword shatters into several pieces, light spilling out all around the solar. He reels back from it, the handle and a little of the blade still in hand. There is a long moment before the solar kneels, "Yield," he announces, voice pained.
Syala gathers the pieces of his sword with divine will and says, "A good battle, and come to Sylica." She approaches him and offers a hand, "Latha's services would be sufficient to repair your sword, for the sun, light and smithing are her gifts."
Radodiel takes that hand and rises, "My deepest thanks."
Antenora
HP: 840/840
SLAs Used:
Syala
HP: 600/700
Spells Used: 1 10th level spell, 1 11th level spell, 1 14th level spell.
SLAs Used:
"There's no crueller loss on Ysgard than that of your weapon," Alicia commiserates as she moves forward to join Syala and her opponent.
"It was well reasoned," Radodiel confesses, "I knew it a risk when I challenged a goddess of light."
"Nonetheless, Latha will see it renewed," Antenora agrees, "There may come a day where you need that blade for deeds of great righteousness, we would not deprive Creation of it when that day comes."
"Indeed. Do you know who is next likely to challenge us when we continue in this direction, Radodiel?" Alicia asks.
"The better question is what won't," Radodiel admits, "But I believe more Children of Jormugandr approach faster than anything else. The Quadruplets in particular."
"What are they like?" she asks, a glance down at Partanyx.
Also she reaches over to heal Syala.
Silver fire healing, +150 hp.
