Alicia raises her sword in salute. "The effort is appreciated, we will see you inside!" her divinely augmented voice projects outwards and then she moves, surging forwards to break a path inside!!
Alicia HP: 794+240/794
Active spells:  Many moments of prescience (CL 34), extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 34), repelling shield (CL 34), extended ray deflection (CL 35), epic mage armour (CL 35), dance of the unicorn (CL 36), recitation (CL 35), opal protection (CL 35)
Defences: AC 96, CMD 100, spell resistance 50, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49)
Stat buffs/penalties: +4 morale skills/attack/saves, +9 shield AC, +10 armour AC, +25 competence perception, +4 str, +2 dex, +4 con, +2 int, +4 wis, +4 cha, +1 natural armour AC,+8 saves vs poison, +3 luck attack/saves, +3 morale AC
Sorcerer spell slots: 6/16/16/16/9/9/14/9/8/5/6/3/4/3/4
Duskblade spell slots: 6/23/23/21/10/7/8
Supreme init here.
> roll 1d20+13 Antenora
<Penuche> Kotono invokes Penuche's magic: < 21 > [d20=8]
> roll 1d20+12 Syala
<Penuche> Kotono invokes Penuche's magic: < 13 > [d20=1]
> roll 1d20+18 archers
<Penuche> Kotono invokes Penuche's magic: < 29 > [d20=11]
> roll 1d20+15 fire
<Penuche> Kotono invokes Penuche's magic: < 34 > [d20=19]
> roll 1d20+15 ice
<Penuche> Kotono invokes Penuche's magic: < 33 > [d20=18]
> roll 1d20+15 acid
<Penuche> Kotono invokes Penuche's magic: < 32 > [d20=17]
> roll 1d20+15 electricity
<Penuche> Kotono invokes Penuche's magic: < 25 > [d20=10]
> roll 1d20+12 gates
<Penuche> Kotono invokes Penuche's magic: < 20 > [d20=8]
> roll 1d20+28 ????
<Penuche> Kotono invokes Penuche's magic: < 34 > [d20=6]
> roll 1d20+7 ????2
<Penuche> Kotono invokes Penuche's magic: < 19 > [d20=12]
> roll 1d20+7 ????3
<Penuche> Kotono invokes Penuche's magic: < 10 > [d20=3]
> roll 1d20+10 ????4
<Penuche> Kotono invokes Penuche's magic: < 19 > [d20=9]
Init is Alicia (Supreme Init) > Fire = ????1 (34) > Ice (33) > Acid (32) > Archers (29) > Electricity (25) > Antenora (21) > Gates (20) > ????2 = ????4 (19) > Syala (13) > ????3 (10)
Open.
Antenora
HP: 840/840
Bonuses: Attack+3 (+3 luck), Damage+0 AC+6 (+3 morale, +3 luck), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Resources: Holy Fury 38/39 (enc) Divine Retribution 1/1 Smite Evil 13/13 Channel Energy 17/17 Lay On Hands 490/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 25/25 Divine Blast 17/17
Spells Used: Opal Protection
SLAs Used:
Spells Active: Mind Blank (CL36), Recitation (CL36), Opal Protection (CL36)
Syala
HP: 700/700
Bonuses: Attack+3 (+3 luck), Damage+0 AC+24 (+3 morale, +3 luck, +18 armor), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Spells Used: 1 10th level spell, 1 11th level spell, 1 14th level spell.
SLAs Used:
Spells Active: Mind Blank (CL36), Energy Immunity(Fire)(CL35), Epic Mage Armor (CL35), Recitation (CL36), Opal Protection (CL36)
Alicia flies forward to meet the advancing fortress, and then releases a burst of liberating magic that breaks down a great deal of its defences!
Fly forward 230 as move action (using blinding speed) then standard to use Unbinding SLA.
"An unbinding spell negates charm and hold spells of all types; arcane locks and similar closures; and spells that create physical or magical barriers, such as wall of fire, wall of force, guards and wards, temporal stasis, and slow spells, among others. The effect of a statue spell is also ended, and a magic jar is shattered—forever destroyed—and the life force within snuffed out. In addition, any spell that holds magical effects, including other spells (magic mouth, imbue with spell ability, and so on), immediately releases them at a range of 0 feet."
So magic walls go down, channelled spells erupt, all sorts of good stuff. Will spend my swift actions depending on how this resolves.
Does the spell mention if it applies to magical items in any way?
It specifies spells repeatedly. A wall of force cast by a magic item would go down because that's a spell but it wouldn't force that item to cast whatever spell it holds. But a spell that casts other spells like glyph of warding or snake sigil would go off.
Right.
The sphere of force fizzles out and the doors to the fortress pop ajar, though the ice around them erupts out, cascading out in great waves, razor sharp ice sprouting up all over.
Ref save on the ice, all. Note if immune, this isn't piercing cold or anything.
Antenora thinks it's 900 degrees too warm to match Caina's cold.
Syala thinks it tickles.
The ice and cold do not harm you. However, all the battlefield is iced over with slippery, razor sharp blades of ice. Going forward on foot will be perilous indeed.
Ground is icy terrain and be treated as such, though I suspect flight will make this mostly moot. Anything else, Alicia?
Transforming into a crackle of lightning, Alicia pushes forward through the gate and into the fortress!
Quickened lightning leap to get inside, will see how that looks before using the last swift.
Sorcerer spell slots: 6/16/16/16/9/9/14/8/8/5/6/3/4/3/4
What's the range on it? Remember you're 350ft away and you moved 230ft, so you'd need to be able to cover 120ft or so.
It's 60 feet, but didn't the fortress move another 120 feet towards us while we bantered? If not we'll just stop there and I'll withhold my swift actions this turn.
It did not. Okay then.
The same voice - masculine and strong - calls, "Fire!" As his voice booms out, from some of the murder holes jets of flames come forth. They melt the ice into water, the ground growing wet and scorched. It washes over everything, a wave of flaming destruction.
Entire party nulls fire.
Yet this does nothing as a salvo of freezing cold follows. It isn't the sharp ice of before, but a barrage of icicles from the murder holes. These do nothing as well, but what follows next is dozens of spheres of acid, flung out at the party.
> roll 1d20+40 touch AC
<Penuche> Kotono invokes Penuche's magic: < 50 > [d20=10]
Touch AC? Note if acid immune.
45
