Three digits naked? Huh.
Antenora's the only one hit.
> roll 1d6+25
<Penuche> Kotono invokes Penuche's magic: < 30 > [d6=5]
10 damage and Fort.
> roll 1d20+59 (+4 racial bonus vs poison)
<Penuche> Kotono invokes Penuche's magic: < 70 > [d20=11]
Syala bats her snakes away while your bare form simply is too tough for them, all while Antenora's bitten. She doesn't slow down from it nor bleed, all while the gorgon's mouth opens, a burning gush of gas erupting out.
Ref all.
+4 Str, +2 Dex, +4 Con, +2 Int, +4 Wis, +4 Cha. +1 natural armor.
Antenora
HP: 910+39(840)/910 (840)
Bonuses: Attack+10 (+4 morale, +3 luck, +3 strength), Damage+3 (+3 strength), AC+3 (+3 luck), Saves+7 (+4 morale, +3 luck), Skills+4 (+4 morale), Checks+0
Resources: Holy Fury 37/39 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 16/17 Lay On Hands 490/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 24/25 Divine Blast 15/17
Spells Used: Healx2, Opal Protection, Opal Furyx2
SLAs Used:
Spells Active: Mind Blank (CL36), Recitation (CL36), Freedom of Movement (CL35), Forestfold (CL35), Mass Swim (CL35)
Syala
HP: 700/700
Bonuses: Attack+3 (+3 luck), Damage+0 AC+24 (+3 morale, +3 luck, +18 armor), Saves+3 (+3 luck), Skills+0, Checks+0
Spells Used: 1 8th level spell, 1 9th level spell, 1 10th level spell, 1 11th level spell, 1 12th level spell, 2 14th level spell.
SLAs Used:
Spells Active: Mind Blank (CL36), Energy Immunity(Fire)(CL35), Epic Mage Armor (CL35), Recitation (CL36), Freedom of Movement (CL35), Forestfold (CL35), Mass Swim (CL35)
The wonders of having Marie cast epic mage armour before we leave.
[20:35] <@Ebiris> roll 1d20+65 ref
[20:35] <Penuche> Ebiris invokes Penuche's magic: < 81 > [d20=16]
Alicia HP: 1249+98/1249
Active spells: Many moments of prescience (CL 35), extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 35), repelling shield (CL 35), extended ray deflection (CL 35), epic mage armour (CL 35), dance of the unicorn (CL 36), recitation (CL 35), opal protection (CL 35), sensual blessing (CL 35), arcane sight (CL 35), freedom of movement (CL 35), foresight (CL 35)
Defences: AC 105, CMD 134, spell resistance 50, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 50), freedom of movement
Stat buffs/penalties: +4 morale skills/attack/saves, +9 shield AC, +10 armour AC, +25 competence perception, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size, +8 saves vs poison, +3 luck attack/saves, +3 morale AC, +2 insight AC/ref, +10 morale str/dex/con
Sorcerer spell slots: 6/10/10/10/9/9/1/6/4/5/6/2/3/0/2
Duskblade spell slots: 6/13/13/6/10/4/1
Moments of prescience: 2
> roll 1d20+64 Antenora ref
<Penuche> Kotono invokes Penuche's magic: < 80 > [d20=16]
> roll 1d20+43 Syala ref
<Penuche> Kotono invokes Penuche's magic: < 50 > [d20=7]
> roll 55*4
<Penuche> Kotono invokes Penuche's magic: < 220 >
220 damage. Syala takes full and Antenora+Alicia take half.
The blast is pure pain, the gas searing your bodies. There's no escape from it, the gas everywhere as...
Syala is seriously considering a dip for +ref and evasion after the last few adventures. Wyrms are up.
In tandem as the gas clears, the two wyrms breath out over you, blasting the party with white hot flames again. "Kill zone," Antenora calls, "Trim down the attackers, I have this one!"
Refx2, Syala and Alicia. Antenora's high enough up to be out of range.
Antenora
HP: 729(840)/910 (840)
SLAs Used:
Syala
HP: 480/700
SLAs Used:
[20:44] <@Ebiris> roll 2#1d20+65 ref
[20:44] <Penuche> Ebiris invokes Penuche's magic: < 74, 77 >
Alicia HP: 1237/1249
> roll 2#1d20+43 Syala ref
<Penuche> Kotono invokes Penuche's magic: < 48, 60 >
> roll 26d10
> roll 26d10
<Penuche> Kotono invokes Penuche's magic: < 159 > [d10=8,3,6,9,2,1,8,4,8,4,8,1,7,10,3,4,10,9,8,6,10,8,4,3,5,10]
<Penuche> Kotono invokes Penuche's magic: < 138 > [d10=1,7,3,7,2,2,9,8,6,4,3,3,3,4,6,9,6,10,3,10,7,9,1,8,5,2]
Both of you made the saves for a total of....148 damage.
Flames roast the two of you, striking without mercy as amid them, more blasts of light rise from above.
> roll 1d6 number of blasts that hit a target
<Penuche> Kotono invokes Penuche's magic: < 2 > [d6=2]
> roll 1d3 1 Alicia 2 Antenora 3 Syala (Syala nulls light so a 3 is nothing)
<Penuche> Kotono invokes Penuche's magic: < 2 > [d3=2]
<Penuche> Kotono invokes Penuche's magic: < 1 > [d3=1]
> roll 1d20+43 touch AC Alicia
<Penuche> Kotono invokes Penuche's magic: < 54 > [d20=11]
> roll 1d20+43 touch AC Antenora
<Penuche> Kotono invokes Penuche's magic: < 56 > [d20=13]
Touch AC?
Antenora
SLAs Used:
Syala
HP: 332/700
SLAs Used:
42, I have ray deflection up if it helps.
Alicia HP: 1089/1249
It does.
> roll 15d6
<Penuche> Kotono invokes Penuche's magic: < 57 > [d6=6,3,2,2,6,5,6,4,1,4,5,5,2,1,5]
Antenora takes 57 damage.
The silver light grazes Antenora, leaving a scorch across her wing as...
Go.
Antenora
HP: 672(840)/910 (840)
SLAs Used:
Syala
HP: 332/700
SLAs Used:
Are we still getting Ysgard's fast healing here?
"I've got the wyrms, heal yourself Syala!" Alicia calls as her sword goes out for the red serpents, controlling her descent as they plummet to leverage her temporary sword to best effect in rending them apart!
[21:48] <@Ebiris> roll 1d20+86 blinding speed, channelled vivacious/maximised/enhanced combust, 7th level arcane strike
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 105 > [d20=19]
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 102 > [d20=16]
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 93 > [d20=7]
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 106 > [d20=20]
[21:48] <@Ebiris> roll 1d20+81 blinding speed, channelled vivacious/maximised/enhanced combust, 7th level arcane strike
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 88 > [d20=7]
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=17]
[21:48] <@Ebiris> roll 1d20+76 blinding speed, channelled vivacious/maximised/enhanced combust, 7th level arcane strike
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 89 > [d20=13]
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 85 > [d20=9]
[21:48] <@Ebiris> roll 1d20+71 blinding speed, channelled vivacious/maximised/enhanced combust, 7th level arcane strike
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 91 > [d20=20]
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 72 > [d20=1]
[21:48] <@Ebiris> roll 1d20+86 blinding speed, channelled vivacious/maximised/enhanced combust, 7th level arcane strike crit check on 105
[21:48] <Penuche> Ebiris invokes Penuche's magic: < 101 > [d20=15]
[21:49] <@Ebiris> roll 1d20+86 blinding speed, channelled vivacious/maximised/enhanced combust, 7th level arcane strike crit check on 106
[21:49] <Penuche> Ebiris invokes Penuche's magic: < 103 > [d20=17]
[21:49] <@Ebiris> roll 1d20+71 blinding speed, channelled vivacious/maximised/enhanced combust, 7th level arcane strike crit check on 91
[21:49] <Penuche> Ebiris invokes Penuche's magic: < 85 > [d20=14]
[21:49] <@Ebiris> roll 1d20+41 SR
[21:49] <Penuche> Ebiris invokes Penuche's magic: < 45 > [d20=4]
[21:49] <@Ebiris> roll 10#1d100
[21:49] <Penuche> Ebiris invokes Penuche's magic: < 91, 95, 60, 83, 78, 86, 9, 55, 66, 4 >
[21:49] <@Ebiris> roll 6d6+38+7d4+160 attack 1, 105/ miss chance 91
[21:49] <Penuche> Ebiris invokes Penuche's magic: < 237 > [d6=4,5,3,4,4,3][d4=4,1,3,2,1,2,3]
[21:49] <@Ebiris> roll 6d6+38+7d4+160 attack 2, 102/ miss chance 95
[21:49] <Penuche> Ebiris invokes Penuche's magic: < 238 > [d6=4,5,3,3,3,6][d4=3,3,2,1,2,2,3]
[21:50] <@Ebiris> roll 6d6+38+7d4+160 attack 3, 93/ miss chance 60
[21:50] <Penuche> Ebiris invokes Penuche's magic: < 242 > [d6=5,4,6,2,6,6][d4=1,2,1,4,3,1,3]
[21:50] <@Ebiris> roll 12d6+81+7d4+320 attack 4, 106/101/ miss chance 83
[21:50] <Penuche> Ebiris invokes Penuche's magic: < 462 > [d6=5,4,6,4,4,5,3,4,3,1,5,1][d4=4,1,3,3,1,3,1]
[21:50] <@Ebiris> roll 6d6+38+7d4+160 attack 5, 88/ miss chance 78
[21:50] <Penuche> Ebiris invokes Penuche's magic: < 238 > [d6=4,4,3,2,4,4][d4=3,1,4,4,1,4,2]
[21:51] <@Ebiris> roll 6d6+38+7d4+160 attack 6, 98/ miss chance 86
[21:51] <Penuche> Ebiris invokes Penuche's magic: < 230 > [d6=5,1,3,1,1,5][d4=2,3,4,3,1,2,1]
[21:51] <@Ebiris> roll 6d6+38+7d4+160 attack 7, 89/ miss chance 9
[21:51] <Penuche> Ebiris invokes Penuche's magic: < 235 > [d6=5,3,2,5,1,1][d4=1,3,3,3,4,3,3]
[21:52] <@Ebiris> roll 12d6+81+7d4+320 attack 8, 91/85/ miss chance 55
[21:52] <Penuche> Ebiris invokes Penuche's magic: < 449 > [d6=6,1,6,2,1,4,2,1,1,4,2,5][d4=1,1,3,3,1,2,2]
[21:53] <@Ebiris> roll 6d6+38+7d4+160 attack 9, 85/ miss chance 66
[21:53] <Penuche> Ebiris invokes Penuche's magic: < 236 > [d6=4,3,6,3,2,5][d4=1,3,3,2,1,3,2]
[21:53] <@Ebiris> roll 6d6+38+7d4+160 attack 10, 72/ miss chance 4
[21:53] <Penuche> Ebiris invokes Penuche's magic: < 237 > [d6=6,2,1,4,3,4][d4=4,1,4,1,3,4,2]
[21:53] <@Ebiris> roll 12d6+81+7d4+320 if attack 1 was a crit which it surely was, so ignore the earlier result
[21:53] <Penuche> Ebiris invokes Penuche's magic: < 441 > [d6=3,1,4,1,3,2,2,2,3,2,2,1][d4=2,2,3,3,1,1,2]
Alicia HP: 1093/1249
Sorcerer spell slots: 6/10/10/10/9/9/0/5/4/5/6/2/3/0/2
Init is Alicia (Supreme Init) > Antenora (32) > Syala (28) > Gorgon Head (27) > Silver Ooze (8)
In a flurry of swings the two wyrms are eliminated, as Antenora meanwhile presses her attack, spear jabbing out constantly. As wyrms fall back into the lava, as you plummet down, Antenora...
Healing herself twice with divine succor.
> roll 1d20+57 (+1 blinding speed, +12 various, -10 PA)
<Penuche> Kotono invokes Penuche's magic: < 61 > [d20=4]
<Penuche> Kotono invokes Penuche's magic: < 62 > [d20=5]
> roll 1d20+52 (+1 blinding speed, +12 various, -10 PA)
<Penuche> Kotono invokes Penuche's magic: < 70 > [d20=18]
> roll 1d20+47 (+1 blinding speed, +12 various, -10 PA)
<Penuche> Kotono invokes Penuche's magic: < 57 > [d20=10]
> roll 1d20+42 (+1 blinding speed, +12 various, -10 PA)
<Penuche> Kotono invokes Penuche's magic: < 54 > [d20=12]
> roll 1d8+62
> roll 1d8+62
> roll 1d8+62
<Penuche> Kotono invokes Penuche's magic: < 67 > [d8=5]
<Penuche> Kotono invokes Penuche's magic: < 68 > [d8=6]
> roll 1d8+62
<Penuche> Kotono invokes Penuche's magic: < 70 > [d8=8]
Jab after jab as the gorgon's eyes are pierced, the snake haired woman retreating back into the lava, nothing but lava above now.
Init is Alicia (Supreme Init) > Antenora (32) > Syala (28) > Silver Ooze (8)
Chance to react, Syala in next post.
Antenora
HP: 872(840)/910 (840)
Resources: Holy Fury 35/39 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 16/17 Lay On Hands 490/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 23/25 Divine Blast 15/17
SLAs Used:
Syala
HP: 332/700
SLAs Used:
"Good going, Antenora!" Alicia calls. They're giving a good show to go with the gratuitous nudity!
Healing light erupts around Syala, her wounds gone in the flash of an eye. Syala stands there after, untouched by wounds or death.
Meanwhile more beams of light come from below.
Greater Heal, another 11th levek spell used. +450 HP.
> roll 5#1d3 1 Alicia 2 Antenora 3 Syala Antenora is the only one vulnerable to these
<Penuche> Kotono invokes Penuche's magic: < 1, 3, 1, 1, 3 >
Beams bounce off your protections and are lost in Syala's light as Antenora looks down and calls, "Finish it off!"
Go.
Antenora
SLAs Used:
Syala
HP: 700/700
Spells Used: 1 8th level spell, 1 9th level spell, 1 10th level spell, 2 11th level spell, 1 12th level spell, 2 14th level spell.
SLAs Used:
They're all falling concurrently but Alicia is able to manipulate space so that she's brought closer to that ooze so her temporary sword can slice it up!
It better not be one of those oozes that split into more oozes when sliced.
Seriously if it is she'll stop after one attack she won't keep going!
[22:36] <@Ebiris> roll 1d20+84 blinding speed, channelled vivacious/maximised combust, 5th level arcane strike
[22:36] <Penuche> Ebiris invokes Penuche's magic: < 97 > [d20=13]
[22:36] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=14]
[22:36] <Penuche> Ebiris invokes Penuche's magic: < 90 > [d20=6]
[22:36] <Penuche> Ebiris invokes Penuche's magic: < 88 > [d20=4]
[22:36] <@Ebiris> roll 1d20+79 blinding speed, channelled vivacious/maximised combust, 5th level arcane strike
[22:36] <Penuche> Ebiris invokes Penuche's magic: < 81 > [d20=2]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 87 > [d20=8]
[22:37] <@Ebiris> roll 1d20+74 blinding speed, channelled vivacious/maximised combust, 5th level arcane strike
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 89 > [d20=15]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 85 > [d20=11]
[22:37] <@Ebiris> roll 1d20+69 blinding speed, channelled vivacious/maximised combust, 5th level arcane strike
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 82 > [d20=13]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 84 > [d20=15]
[22:37] <@Ebiris> roll 6d6+38+5d4+80
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 148 > [d6=5,2,2,4,2,2][d4=4,3,1,2,3]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 152 > [d6=6,6,1,1,6,4][d4=4,2,1,1,2]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 159 > [d6=3,5,5,5,6,5][d4=1,3,3,2,3]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 152 > [d6=1,6,5,2,4,1][d4=4,3,2,2,4]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 150 > [d6=2,4,4,2,5,5][d4=1,2,2,4,1]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 151 > [d6=2,6,5,4,4,2][d4=2,3,1,2,2]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 149 > [d6=3,2,1,5,3,3][d4=4,4,1,2,3]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 158 > [d6=5,3,1,6,6,6][d4=1,2,2,4,4]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 152 > [d6=4,2,4,4,3,3][d4=4,1,2,3,4]
[22:37] <Penuche> Ebiris invokes Penuche's magic: < 160 > [d6=4,4,4,3,4,5][d4=3,4,3,4,4]
Alicia HP: 1097/1249
Sorcerer spell slots: 6/10/10/10/8/8/0/5/4/5/6/2/3/0/2
