The good news? It isn't. The better news? It chops real well.
You sunder it apart, no more attacks.
The three of you land with a thump, lava splashing around all of you as...
Are you fire immune, Alicia?
Yet none of you are touched, warded or immune to flame. As the lava clears, you see you stand on a rotating, circular platform. From above it comes - the gorgon's head again, but this time face and snakes alike are covered in thick armor.
"Round three," Syala takes a breath, as...
It's joining init anew.
> roll 1d20+24
<Penuche> Kotono invokes Penuche's magic: < 44 > [d20=20]
Init is Alicia (Supreme Init) > Armored Gorgon's Head (44) > Antenora (32) > Syala (28)
Any swifts, Alicia?
How far away is the gorgon?
Alicia HP: 1097/1249
Active spells: Many moments of prescience (CL 35), extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 35), repelling shield (CL 35), extended ray deflection (CL 35), epic mage armour (CL 35), dance of the unicorn (CL 36), recitation (CL 35), opal protection (CL 35), sensual blessing (CL 35), arcane sight (CL 35), freedom of movement (CL 35), foresight (CL 35)
Defences: AC 105, CMD 134, spell resistance 50, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 50), freedom of movement
Stat buffs/penalties: +4 morale skills/attack/saves, +9 shield AC, +10 armour AC, +25 competence perception, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size, +8 saves vs poison, +3 luck attack/saves, +3 morale AC, +2 insight AC/ref, +10 morale str/dex/con
Sorcerer spell slots: 6/10/10/10/8/8/0/5/4/5/6/2/3/0/2
Duskblade spell slots: 6/13/13/6/10/4/1
Moments of prescience: 2
Alicia throws her sword up to cut into the gorgon's face before it rebounds back into her hand!
Quickened whirling blade why not.
[23:11] <@Ebiris> roll 1d20+84 same mods as the full attack
[23:11] <Penuche> Ebiris invokes Penuche's magic: < 95 > [d20=11]
[23:11] <@Ebiris> roll 1d20+41 SR
[23:11] <Penuche> Ebiris invokes Penuche's magic: < 47 > [d20=6]
[23:11] <@Ebiris> roll 6d6+38+5d4+80
[23:11] <Penuche> Ebiris invokes Penuche's magic: < 153 > [d6=6,1,1,6,4,4][d4=4,3,1,3,2]
Sorcerer spell slots: 6/10/10/10/7/8/0/5/4/5/6/2/3/0/2
CLANG!
Your blade bounces right off the steel covered face, flying back to you in a wobbling fall. You don't even scratch the iron of it as Antenora looks up, "Magic," She decides in a moment, "Use magic!"
Gorgon's head is up.
Snakes rain down, armored snakes that bite away at all the party.
> roll 1d20+63
<Penuche> Kotono invokes Penuche's magic: < 78 > [d20=15]
AC?
Only Antenora hit again.
> roll 1d6+35
<Penuche> Kotono invokes Penuche's magic: < 40 > [d6=5]
> roll 1d20+64 Antenora ref
<Penuche> Kotono invokes Penuche's magic: < 82 > [d20=18]
20 damage to Antenora.
The snakes bite away, Antenora nibbled on the hand but nothing more. This time the gas comes again, faster and stronger.
Ref all.
+4 Str, +2 Dex, +4 Con, +2 Int, +4 Wis, +4 Cha. +1 natural armor.
Antenora
HP: 852(840)/910 (840)
Bonuses: Attack+10 (+4 morale, +3 luck, +3 strength), Damage+3 (+3 strength), AC+3 (+3 luck), Saves+7 (+4 morale, +3 luck), Skills+4 (+4 morale), Checks+0
Resources: Holy Fury 35/39 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 16/17 Lay On Hands 490/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 23/25 Divine Blast 15/17
Spells Used: Healx2, Opal Protection, Opal Furyx2
SLAs Used:
Spells Active: Mind Blank (CL36), Recitation (CL36), Freedom of Movement (CL35), Forestfold (CL35), Mass Swim (CL35)
Syala
HP: 700/700
Bonuses: Attack+3 (+3 luck), Damage+0 AC+24 (+3 morale, +3 luck, +18 armor), Saves+3 (+3 luck), Skills+0, Checks+0
Spells Used: 1 8th level spell, 1 9th level spell, 1 10th level spell, 2 11th level spell, 1 12th level spell, 2 14th level spell.
SLAs Used:
Spells Active: Mind Blank (CL36), Energy Immunity(Fire)(CL35), Epic Mage Armor (CL35), Recitation (CL36), Freedom of Movement (CL35), Forestfold (CL35), Mass Swim (CL35)
[23:25] <@Ebiris> roll 1d20+65 ref
[23:25] <Penuche> Ebiris invokes Penuche's magic: < 81 > [d20=16]
<Penuche> Kotono invokes Penuche's magic: < 79 > [d20=15]
> roll 1d20+43 Syala ref
<Penuche> Kotono invokes Penuche's magic: < 55 > [d20=12]
> roll 110*4
<Penuche> Kotono invokes Penuche's magic: < 440 >
Alicia and Antenora take half, Syala full. Ow.
The gas burns like acid and fire together, skin peeling away from it. You feel your own form shed in part as Antenora is much the same, reddening all over. Syala blackens instead, stumbling back as hunks of her rot to nothing. The smell is dreadful as...
Antenora.
Immediately Syala's wounds heal in part as do yours, before Antenora rushes to Syala and lays hands on her chest.
Divine succor on both of you for 100 points of healing, then 340 lay on hands healing. Syala.
"Close your eyes," Syala calls, pointing a bit to the side of the gorgon's head, above and away - as a new sun is born there, a storm of solar fury.
Sunstorm.
> roll 1d20+43 ref improved gorgon evasion
<Penuche> Kotono invokes Penuche's magic: < 56 > [d20=13]
Yet the head isn't even affected, somehow not where it's supposed to be as...
Go.
Antenora
HP: 632(840)/910 (840)
Resources: Holy Fury 35/39 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 16/17 Lay On Hands 150/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 23/25 Divine Blast 15/17
SLAs Used:
Syala
HP: 700/700
Spells Used: 1 8th level spell, 1 9th level spell, 1 10th level spell, 2 11th level spell, 1 12th level spell, 3 14th level spell.
SLAs Used:
On the off chance this is an oversight, evasion generally only works with light or no armour. Just in case that matters here, worth a shot?
"Nothing it can dodge," Alicia glowers up at the unusually agile thing. Silver fire would be no good either. "Syala you can be my familiar for a little bit."
Syala is now my familiar so she gets improved evasion. Which is an exception to what I said above in that it has no reference to armour in its description!
Also she gets +18 natural armour and 2 uses of limited wish as an SLA.
"Actually... this will do," she casts a spell to make all of their temporary weapons glow vivid blue, their substance ignoring the nonliving now, before compressing space a little to help her blades reach the target.
Quickened brilliant aura, all our weapons are now brilliant energy and ignore armour/shield bonuses to AC.
[00:03] <@Ebiris> roll 1d20+89 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC
[00:03] <Penuche> Ebiris invokes Penuche's magic: < 95 > [d20=6]
[00:03] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=9]
[00:03] <Penuche> Ebiris invokes Penuche's magic: < 107 > [d20=18]
[00:03] <Penuche> Ebiris invokes Penuche's magic: < 93 > [d20=4]
[00:03] <@Ebiris> roll 1d20+84 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC
[00:03] <Penuche> Ebiris invokes Penuche's magic: < 94 > [d20=10]
[00:04] <@Ebiris> roll 1d20+84 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 97 > [d20=13]
[00:04] <@Ebiris> roll 1d20+79 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 82 > [d20=3]
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=19]
[00:04] <@Ebiris> roll 1d20+74 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 92 > [d20=18]
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 87 > [d20=13]
[00:04] <@Ebiris> roll 1d20+89 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC - crit check
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 107 > [d20=18]
[00:04] <@Ebiris> roll 1d20+79 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC - crit check
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 93 > [d20=14]
[00:04] <@Ebiris> roll 1d20+74 blinding speed, channelled vivacious/maximised/enhanced combust, 10th level arcane strike. Ignores armour/shield AC - crit check
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 78 > [d20=4]
[00:04] <@Ebiris> roll 6d6+38+10d4+160
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 241 > [d6=5,3,4,1,6,2][d4=3,1,1,1,2,2,4,2,2,4]
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 234 > [d6=6,1,3,1,5,2][d4=2,1,4,2,1,3,1,1,2,1]
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 244 > [d6=1,4,3,6,5,2][d4=1,3,4,3,4,2,1,1,3,3]
[00:04] <Penuche> Ebiris invokes Penuche's magic: < 240 > [d6=1,1,4,1,2,5][d4=2,2,4,4,1,3,4,3,2,3]
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 251 > [d6=2,6,5,4,4,5][d4=1,1,2,3,4,4,3,4,3,2]
[00:05] <@Ebiris> roll 6d6+38+10d4+160
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 242 > [d6=2,5,5,3,2,5][d4=3,1,4,1,4,3,3,1,1,1]
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 247 > [d6=5,5,2,6,3,3][d4=2,1,1,3,4,3,2,4,3,2]
[00:05] <@Ebiris> roll 12d6+76+10d4+320 if 107/107 was a crit
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 467 > [d6=5,2,2,1,6,1,5,2,4,3,3,4][d4=4,4,4,4,1,4,4,1,4,3]
[00:05] <@Ebiris> roll 6d6+38+10d4+160 if not
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 246 > [d6=4,1,2,6,6,5][d4=2,3,4,2,3,4,1,2,1,2]
[00:05] <@Ebiris> roll 12d6+76+10d4+320 if 98/93 was a crit
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 469 > [d6=4,6,2,5,2,3,4,2,3,6,2,5][d4=2,2,3,1,3,4,4,4,3,3]
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 239 > [d6=2,5,5,3,1,4][d4=1,3,1,2,3,3,1,3,1,3]
[00:05] <@Ebiris> roll 12d6+76+10d4+320 if 92/78 was a crit
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 463 > [d6=1,3,2,2,6,3,5,1,2,6,6,4][d4=4,1,2,4,3,2,3,4,1,2]
[00:05] <Penuche> Ebiris invokes Penuche's magic: < 246 > [d6=3,5,4,6,6,1][d4=2,1,3,1,1,4,4,1,3,3]
[00:06] <@Ebiris> roll 1d20+41 belated SR
[00:06] <Penuche> Ebiris invokes Penuche's magic: < 59 > [d20=18]
Alicia HP: 981/1249
Sorcerer spell slots: 6/10/10/10/7/8/0/4/4/4/5/2/3/0/2
Thus enhanced, Alicia rips into the gorgon's face. She tears it asunder, her blade enough to rip it apart. It is simply gone a moment as you stand there - is the battle finally over?
Then the ground shakes and is gone, save for the circular platform you are on. The gorgon now rises as tall as Alicia, covered heat to toe in thick armor and with snakes larger than Hanna. Her face is still a sundered mess, bleeding down, but the rest of her is more than intact and ready to go.
Anything else to do this turn, Alicia?
Init is Alicia (Supreme Init) > Armored Gorgon (44) > Antenora (32) > Syala (28)
Firstly, the armored gorgon rears back and breathes out gas over all the party, spreading far and wide about.
Ref all.
