Mystran rest
Started by Anastasia, July 21, 2020, 12:51:45 PM
Alicia honestly doesn't anticipate a trap at this point. And that's even more unsettling.
"We go. Whatever we find, we must bear witness," Alicia says, leading the way through. Marie follows close behind, positioning her projected image to transition seamlessly along with her.
Alicia HP: 903+20/903
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 39), extended nondetection (CL 39), greater heroism (CL 36), extended ray deflection (CL 39), epic mage armour (CL 36), sensual blessing (CL 36), greater foresight (CL 38), keen edge (CL 36 on sword), dance of the unicorn (CL 36), extended greater anticipate teleportation (CL 38), repelling shield (CL 38), freedom of movement (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), death ward (CL 36), energy immunity - cold (CL 38)
Defences: AC 97, CMD 127, spell resistance 51, energy immunity (negative, fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale attack/skills, +10 armour AC, +25 competence perception, +7 insight AC/ref, +12 str, +8 con, +2 int, +4 wis, +4 cha, +3 natural armour AC, -1 size attack/AC, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC
Sorcerer spell slots: 6/16/16/14/9/9/15/9/9/6/8/3/7/6/6/3
Marie HP: 720+20/720
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 36), extended nondetection (CL 36), greater heroism (CL 36), greater arcane sight (CL 36), epic mage armour (CL 36), sensual blessing (CL 36), repelling shield (CL 36), freedom of movement (CL 36), recitation (CL 36), true seeing (CL 36), bibliotheca arcana (CL 36), death ward (CL 36), energy immunity - cold (CL 38), superior invisibility (CL 40)
Defences: AC 105, CMD 99, spell resistance 51, energy immunity (negative, cold, electricity, fire, sonic), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 51), freedom of movement
Stat buffs/penalties: +4 morale attack/skills, +25 competence perception, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC
Sorcerer spell slots: 6/9/10/8/8/9/9/7/7/8/7/4/6/7/4
It is dark when you step in. It is dark, silent and lonely. There is no immediate sign of Shar here. It is the ever gloom of caverns forever sequestered from the sun, a darkness absolute and only pierced by your radiances.
A single path invites you ahead, hewn of stone.
Alicia waits a moment for everyone else to make it through before following this tunnel.
What does tremorsense/blindsight 5 miles say about what's ahead? Also can I identify the demi-plane's planar traits?
Out of sight, everything becomes incoherent and faded, like a landscape waiting to be defined. Unrealized space, ready to be molded by the controller of this place.
If this is not a physical attack then expect an attack on our spirits. Whatever Shar has to show us, she believes it will bring us despair, so steel yourselves.
Imparting that warning to her companions, Alicia strides down the tunnel.
Then let the light of the dawn show us the way.
We will not be afraid. Not this time.
You stride on as the cavern's walls begin to glint with a metallic cast. Lines of metal, sleek tubes that seem almost like metallic shadows, run through the walls now. As space forms mere steps ahead of your sight, just enough to not disturb the illusion that this is a whole and formed place if not for your superior senses?
A swirling node. A nexus. You step into a larger space, where the tubes extend further. Here, at the very end, the avatar of Shar stands. Her head is bowed low, as if lost in a deep contemplation.
There are few things stronger than us in Creation.
But we are not quite supreme.
You've felt Sylica's will. Your realm is mighty and it would do anything to protect you. Look at how Bytopia mourned the loss of what drove it.
"What blasphemy is this, Shar?" Phoebe declares, moonfire swirling around her hands like a tightly knit inferno.
Any knowledge check to make sense of what all this stuff is doing/meant to do?
[17:22] <@Ebiris> roll 1d20+75 divine insight
[17:22] <Penuche> Ebiris invokes Penuche's magic: < 85 > [d20=10]
You recall a fragment of lore, something brought to mind with Shar's own words.
That one day Arborea itself stirred, and sent an avatar to confront Morwel.
Just a bit of an ancient legend, whispered and distorted over the eons, but clear. That the planes themselves have great power, something you have seen firsthand.
Was more trying to figure out what all the pipes are doing and if they're some way of creating/controlling an avatar for this demi-plane or else for the plane of shadow.
You aren't quite sure what the metal tubes are about offhand.
"And you tried to force Bytopia back into mourning. We haven't forgotten that," Marie speaks up through her projected image.
"We haven't," Alicia seconds. "What have you done, Shar?"
I have turned that very possibility to my own ends.
Let me show you.
Is this demonstration going to be incipiently fatal for them?
There's no point trying to stop her, it's just an avatar and so whatever she's demonstrating is something Shar herself and any of her other avatars can do at any time. Better then to learn just what this technique entails so they can better form countermeasures.
"Why are you showing us this?" she asks, holding still.
Btw I asked earlier but never had it answered. What are this demiplane's planar traits?
