Mystran rest
Started by Anastasia, July 21, 2020, 12:51:45 PM
It's pretty normal save for everything being morphic and under the controller's power. Of course, due to that, it's possible the traits could change.
Does that change your action at all?
It does not, but out of interest does that mean we can control it with our anarch powers? Would planar perinarch give control?
Alicia HP: 903+20/903
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 39), extended nondetection (CL 39), greater heroism (CL 36), extended ray deflection (CL 39), epic mage armour (CL 36), sensual blessing (CL 36), greater foresight (CL 38), keen edge (CL 36 on sword), dance of the unicorn (CL 36), extended greater anticipate teleportation (CL 38), repelling shield (CL 38), freedom of movement (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), death ward (CL 36), energy immunity - cold (CL 38)
Defences: AC 97, CMD 127, spell resistance 51, energy immunity (negative, fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale attack/skills, +10 armour AC, +25 competence perception, +7 insight AC/ref, +12 str, +8 con, +2 int, +4 wis, +4 cha, +3 natural armour AC, -1 size attack/AC, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC
Sorcerer spell slots: 6/16/16/14/9/9/15/9/9/6/8/3/7/6/6/3
Marie HP: 720+20/720
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 36), extended nondetection (CL 36), greater heroism (CL 36), greater arcane sight (CL 36), epic mage armour (CL 36), sensual blessing (CL 36), repelling shield (CL 36), freedom of movement (CL 36), recitation (CL 36), true seeing (CL 36), bibliotheca arcana (CL 36), death ward (CL 36), energy immunity - cold (CL 38), superior invisibility (CL 40)
Defences: AC 105, CMD 99, spell resistance 51, energy immunity (negative, cold, electricity, fire, sonic), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 51), freedom of movement
Stat buffs/penalties: +4 morale attack/skills, +25 competence perception, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC
Sorcerer spell slots: 6/9/10/8/8/9/9/7/7/8/7/4/6/7/4
You believe you could certainly try to do so, yes.
Cool. Carry on! I'm not doing anything yet, I just wanted to know for future reference. Let Shar do her exposition.
Shar steps back into the wall. The wall is indistinct as is the avatar - and slowly they seem to become one. Merging, folding together, combining before your very eyes.
"So that's it," Latha declares, "Remove the distinction between plane and deity, and harvest the power of both?"
Is there anything at all I can discern magic-wise about what's going on here?
Spellcraft. This is advanced enough to require a roll.
[19:22] <@Ebiris> roll 1d20+94 divine insight and improvisation
[19:22] <Penuche2> Ebiris invokes Penuche's magic: < 111 > [d20=17]
A new system had spread - like the Weave and not, and it connects the avatar and the demiplane here. A sort of unholy combination, an elimination of barriers into one whole through this connection.
Would it effectively turn the avatar into a mobile demiplane or does it just result in a super-buff avatar within the demiplane?
"So that's what you did with Mystra's blood," Alicia says in realisation. "Why are you showing us this, Shar?"
Because...
I want to see your face the moment you realize your entire purpose is pointless and doomed.
Shar's voice is warm, even concerned.
Because I will be the one to grant you the rest of oblivion when existence becomes too painful to continue.
In that voice is soothing tones, as if to wash away your fears.
Because no matter what you will do, you are condemned to failure. Every battle and struggle you have waged is a meaningless rearguard action after your defeat is assured. All the sacrifices you have made are nothing. All the blood you have spilled is only a pleasant distraction from your reality.
Marie, Latha? Please help me with wresting control. The demiplane is morphic; like Limbo.
"I thought it might be something like that," she says as she asserts her anarchic control over the demiplane to wrench the avatar loose and 'tie off' the system that's been put in place here so it can't be easily re-done.
Check for that?
[16:50] <@Ebiris> roll 1d20+21 Alicia charisma
[16:50] <Penuche2> Ebiris invokes Penuche's magic: < 23 > [d20=2]
[16:51] <@Ebiris> roll 1d20+16 Marie charisma
[16:51] <Penuche2> Ebiris invokes Penuche's magic: < 31 > [d20=15]
> roll 1d20+13 Latha
<Penuche2> Kotono invokes Penuche's magic: < 21 > [d20=8]
Total of 75.
It's like trying to move lead. It's wrong, something clings to the entire demiplane. It resists your will like a stain clings to a white dress, as if to spoil the entire thing and never leave.
Is that it? I expected more of a struggle, not feeble flailing.
