Mystran rest
Started by Anastasia, July 21, 2020, 12:51:45 PM
Another quickened limited wish to pop improvisation.
"Again," Alicia nods to Marie (or at least her illusory image) and Latha as she focuses on asserting her will over the plane and wrenching Shar loose from the conjoined monstrosity she's created.
[17:57] <@Ebiris> roll 1d20+43 Alicia charisma
[17:57] <Penuche> Ebiris invokes Penuche's magic: < 58 > [d20=15]
[17:57] <@Ebiris> roll 1d20+43 Marie charisma, improvisation used up
[17:57] <Penuche> Ebiris invokes Penuche's magic: < 59 > [d20=16]
Also Alicia is now at 60% hp if Phoebe is taking note.
Alicia HP: 630/1038
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 39), extended nondetection (CL 39), greater heroism (CL 36), extended ray deflection (CL 39), epic mage armour (CL 36), sensual blessing (CL 36), greater foresight (CL 38), keen edge (CL 36 on sword), dance of the unicorn (CL 36), extended greater anticipate teleportation (CL 38), repelling shield (CL 38), freedom of movement (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), death ward (CL 36), energy immunity - cold (CL 38), good hope (CL 38), Seira's Arcane Thesis (CL 38)
Defences: AC 97, CMD 133, spell resistance 51, energy immunity (negative, fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale attack/skills, +10 armour AC, +25 competence perception, +7 insight AC/ref, +12 str, +8 con, +2 int, +4 wis, +4 cha, +3 natural armour AC, -1 size attack/AC, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC, +2 ability checks, +5 spell DCs, +10 SR checks, +6 competence attack, +4 competence fort
Sorcerer spell slots: 6/16/16/14/9/9/15/9/9/4/8/2/7/5/6/3
Marie HP: 830+20/830
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 36), extended nondetection (CL 36), greater heroism (CL 36), greater arcane sight (CL 36), epic mage armour (CL 36), sensual blessing (CL 36), repelling shield (CL 36), freedom of movement (CL 36), recitation (CL 36), true seeing (CL 36), bibliotheca arcana (CL 36), death ward (CL 36), energy immunity - cold (CL 38), superior invisibility (CL 40), good hope (CL 38)
Defences: AC 105, CMD 105, spell resistance 51, energy immunity (negative, cold, electricity, fire, sonic), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 51), freedom of movement
Stat buffs/penalties: +4 morale attack/skills, +25 competence perception, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC, +2 morale ability checks, +6 competence attack, +4 competence fort
Sorcerer spell slots: 6/8/10/8/8/9/9/7/7/8/7/4/6/7/4
> roll 1d20+33 Latha
<Penuche> Kotono invokes Penuche's magic: < 52 > [d20=19]
An excellent set of rolls.
Another pull. This time a leg comes free, half in and half out. You're fighting against it, making more and more headway as...
Anything else this turn for you?
No, I'll reserve my other swift for countering if needed, Marie's not doing anything else.
With half of Shar out and half in?
Fine then. Enough games. Die in the shadows.
Suddenly all the darkness comes forth, like a smothering blanket over all of you. It drains away warmth, heat, energy, everything. It's harder to think by the moment as it comes forth.
Ref all.
Unfortunately for Marie it doesn't matter if you're invisible and away from where you appear to be when an attack covers that kind of radius!
[18:27] <@Ebiris> roll 1d20+80 Alicia ref
[18:27] <Penuche> Ebiris invokes Penuche's magic: < 95 > [d20=15]
[18:28] <@Ebiris> roll 1d20+85 Marie ref, she's using many moments of prescience
[18:28] <Penuche> Ebiris invokes Penuche's magic: < 91 > [d20=6]
Alicia HP: 630/1038
Many moments of prescience: 3/4
> roll 1d20+49 Phoebe
<Penuche> Kotono invokes Penuche's magic: < 67 > [d20=18]
> roll 1d20+62 Latha evasion
<Penuche> Kotono invokes Penuche's magic: < 68 > [d20=6]
500 damage. Marie and Alicia take half, Latha and Phoebe take full.
Night fall. Darkness tears at you and saps you. For a moment Alicia is lost in it and...
HPs?
Inspire greatness is +6 competence attack, +4 competence fort, and +5 bonus d10 hd.
[17:22] <@Ebiris> roll 5d10
[17:22] <Penuche> Ebiris invokes Penuche's magic: < 32 > [d10=1,10,7,10,4]
Phoebe gets 32 + 5 x con mod, the rest of us have maximum hit points per die so 50 + 5 x con mod.
Latha
HP: 410(300)/910
Aura: Holy Light 30ft (7d6+7 damage vs evil/round) Protective 20ft (+4 deflection/+4 resistance vs evil), Divine 10ft (various)
Bonuses: Attack+0, Damage+0 AC+12 (+12 armor), Saves+0, Skills+0, Checks+0
Resources: Channel Energy 15/15 Sun Devotion 4/4 Sunweaver 3/3 Vision of Heaven (rnd) 1/1 Zeal Domain 1/1
Spells Used:
SLAs Used:
Spells Active: Epic Mage Armor (CL36), Many Moments of Prescience (CL38), Death Ward (CL36), Mass Energy Immunity (Cold) (CL38)
Notes: Level + 22 extra damage per hit vs undead during sun devotion.
Many Moments of Prescience: 4 uses for a +30 insight bonus.
380 for Alicia and 600 for Marie. Alicia is at 36% health. Marie is at  72% but unless someone beats her insane stealth check they're not going to be landing any heals on her.
Alicia HP: 380/1038
Marie HP: 600/830
Suddenly a barrage of pressure surrounds Alicia, as if to crush her into dust, the shadows like squeezing hands around her neck.
Fort.
[19:41] <@Ebiris> roll 1d20+92 improved mettle
[19:41] <Penuche> Ebiris invokes Penuche's magic: < 107 > [d20=15]
But this time you endure it, even as you feel Shar's eyes on you, like a pressure that bombards your mind, even as you hear Latha's soft cry of pain.
Will.
[20:03] <@Ebiris> roll 1d20+83 improved mettle
[20:03] <Penuche> Ebiris invokes Penuche's magic: < 88 > [d20=5]
But again Alicia endures. She endures it all as she can see her allies pushed back. Phoebe is bloodied all over while Latha blocks behind her Aegis of the Tarrasque. It buys her precious moments as...
The moon. For a precious moment the moon shines above you, bringing mercy to your wounds.
Mass Lunar Healing. 450 healing all. Marie.
Alicia's fully healed thanks to sensual blessing. Also Marie, Latha, and Alicia are basically on the same init because of the previous round's delay so we can all act together.
"Again!" Alicia says, continuing to do their best to break what Shar's done. They're making progress but all the same this feels perilously unworkable in battle. She wants to confirm the process but it might not be the best approach next time this happens.
Alicia has one more use on her improvisation but Marie and Latha are out and we don't want to have to waste a turn on them using alter reality to replace it.
Alicia will use quickened limited wishes - it's a personal level 1 bard spell but with a limited wish can she hit them with it or a similar effect to give them +18 on their next ability score check?
Alicia HP: 1038/1038
Marie HP: 600/830
Okay.  Get to rolling.
+19 actually since Alicia's sorc CL is 38.
[16:42] <@Ebiris> roll 1d20+44 Alicia charisma
[16:42] <Penuche> Ebiris invokes Penuche's magic: < 62 > [d20=18]
[16:42] <@Ebiris> roll 1d20+37 Marie charisma
[16:42] <Penuche> Ebiris invokes Penuche's magic: < 45 > [d20=8]
Sorcerer spell slots: 6/16/16/14/9/9/15/9/9/2/8/2/7/5/6/3
Marie HP: 600/830
