Shadow rondo
Distance to it?
Can I detect any spells on it with arcane sight?
[01:19] <@Ebiris> roll 1d20+42 CL if needed
[01:19] <Rei-chan> Ebiris rolled : 1d20+42 CL if needed --> [ 1d20=18 ]{60}
If it's not yet in range of arcane sight hold onto that roll for when I do get close enough I suppose.
Alicia HP: 854+20/854
Active spells: Many moments of prescience (CL 39), extended mind blank (CL 40), extended nondetection (CL 40), greater heroism (CL 37), extended ray deflection (CL 40), epic mage armour (CL 37), sensual blessing (CL 37), greater foresight (CL 39), keen edge (CL 37 on sword), dance of the unicorn (CL 37), extended greater anticipate teleportation (CL 39), repelling shield (CL 39), freedom of movement (CL 37), greater visage of the deity (CL 37), recitation (CL 37), good hope (CL 37)
Defences: AC 108, CMD 118, spell resistance 52, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 55), freedom of movement
Stat buffs/penalties: +4 morale attack/skills/saves, +10 armour AC, +25 competence perception, +7 insight AC/ref, +4 str, +2 dex, +4 con, +2 int, +4 wis, +4 cha, +1 natural armour AC, +9 shield AC, +3 luck AC/attack/saves, +2 morale ability checks
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/3/8/5/6/7/7/3
Duskblade spell slots: 6/23/23/21/11/7/16/3
Moments of prescience left: 4
200ft.
Go ahead and begin your action and I'll adjudicate this when you do get in range.
Alicia flies closer, deciding to play this one cautiously rather than going all out attack from the outset.
Flying 80 feet with my move action, the rest pending what I see with arcane sight.
It has no spells on it.
Perhaps she should have just gone all out on the attack? Well, she'll assault it with spells to try and soften it up from here, launching first a blast of radiant sunlight which is followed by a dizzying wave of coruscating rainbow colours!
Sunlance and quickened radiant assault.
[16:31] <@Ebiris> roll 1d20+62 ranged touch on sunlance
[16:32] <Kobot> Ebiris rolled 1d20+62 ranged touch on sunlance --> [ 1d20=9 ]{71}
[16:32] <@Ebiris> roll 1d20+44 SR
[16:32] <Kobot> Ebiris rolled 1d20+44 SR --> [ 1d20=2 ]{46}
[16:32] <@Ebiris> roll 30d6 if that hit
[16:32] <Kobot> Ebiris rolled 30d6 if that hit --> [ 30d6=84 ]{84}
[16:32] <@Ebiris> roll 6d6 splash damage
[16:32] <Kobot> Ebiris rolled 6d6 splash damage --> [ 6d6=21 ]{21}
DC 39 ref, halves the 21 damage and negates blindness
[16:33] <@Ebiris> roll 1d20+44 SR for radiant assault
[16:33] <Kobot> Ebiris rolled 1d20+44 SR for radiant assault --> [ 1d20=11 ]{55}
[16:33] <@Ebiris> roll 15d6
[16:33] <Kobot> Ebiris rolled 15d6 --> [ 15d6=73 ]{73}
[16:33] <@Ebiris> roll 1d6 debuff duration
[16:34] <Kobot> Ebiris rolled 1d6 debuff duration --> [ 1d6=2 ]{2}
DC 35 will halves the damage, dazed 2 rounds if save failed, dazzled 2 rounds if save passed.
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/2/8/4/6/7/7/3
The sunlance is hurled and hits the eye, only to break against it. The light splinters away as your radiant assault follows.
> roll 1d20+30
<Kobot> Kotono rolled 1d20+30 --> [ 1d20=16 ]{46}
The eye is struck by the burst of light, the center mass of it dazzled and covered in light a few moments. But little more, the beast far from any sort of normal demon.
That it for you?
> roll 1d20+14 Antenora
<Kobot> Kotono rolled 1d20+14 Antenora --> [ 1d20=9 ]{23}
> roll 1d20+12 horror
<Kobot> Kotono rolled 1d20+12 horror --> [ 1d20=12 ]{24}
Init is Alicia (Supreme) > Eye Horror (24) > Antenora (23)
The cracks fester and spread, all around reality and the two of you, as crack lines try to encroach on both yourself and Antenora.
Two Fort saves, Alicia.
[17:49] <@Ebiris> roll 2#1d20+80 improved mettle
[17:49] <Kobot> Ebiris rolled 2#1d20+80 improved mettle --> [ 1d20=10 ]{90}, [ 1d20=20 ]{100}
> roll 1d20+67 mettle
> roll 1d20+67 mettle
<Kobot> Kotono rolled 1d20+67 mettle --> [ 1d20=10 ]{77}
<Kobot> Kotono rolled 1d20+67 mettle --> [ 1d20=3 ]{70}
Yet both of you stand true. Those cracks do not touch you, they fade away as you endure a feeling of being splintered all over. Instead you are unharmed - as the center eye glows acid green, before a great, river sized jet of it comes forth, engulfing you utterly.
Reflex save. Note that half of this is unholy damage so you'll take some even if you're acid immune.
Antenora
HP: 959+20/959
Resources: Holy Fury 42/42 (enc) Divine Retribution 1/1 Smite Evil 13/13 Channel Energy 18/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 25/25 Divine Blast 18/18
Spells Used:
SLAs Used:
Typical Charging Numbers: 36 for base smite damage, 72 for charging smite +2 per per level. So 108 bonus damage baseline. Raw attack plus smite is 1d8+145+2d6+2d6 (+4/+4d6 if fiendbane hits). Doesn't include other factors.
[18:05] <@Ebiris> roll 1d20+75 ref saves my one weakness
[18:05] <Kobot> Ebiris rolled 1d20+75 ref saves my one weakness --> [ 1d20=14 ]{89}
Made the save.
A base of 300 acid damage and 300 unholy damage before the save and any immunities come into play. What's your HP after that?
I'm guessing save half?
574/854
Alicia HP: 574/854
Correct.
Acid and agony. It eats at you, unholy power twisting your flesh, rivulets of it ruined and broken. The pain of is sublime for seconds, then nothing as nerves are eaten away.  Yet you endure it as you hold - and Antenora streaks past you, an opal blue blur as she charges at the nightmare that challenges both of you.
<Kobot> Kotono rolled 1d20+75 (+4 charge, +7 Alicia, +18 furious strike, +15 smite evil, +1 haste, divine might used, -30 PA) --> [ 1d20=14 ]{89}
> roll 258*3
<Kobot> Kotono rolled 258*3 --> {774}
> roll 1d8+774+2d6+2d6+4d6+10d6
<Kobot> Kotono rolled 1d8+774+2d6+2d6+4d6+10d6 --> [ 1d8=8 2d6=10 2d6=11 4d6=16 10d6=26 ]{845}
In a moment Antenora has closed the distance. Her spear plunges into it, cracks of opal blue light cascading thorugh the eye. The nalfeshnee that make its legs howl in unfettered agony, but they do not yield. Instead with a cry of inhuman pain, a greater cascade of cracks erupt around Antenora.
> roll 4#1d20+67 mettle
<Kobot> Kotono rolled 4#1d20+67 mettle --> [ 1d20=3 ]{70}, [ 1d20=4 ]{71}, [ 1d20=8 ]{75}, [ 1d20=8 ]{75}
Yet Antenora stays true and endures. She does not yield as meanwhile? Even in your fading pain you can sense it below. Movement.  The gemstone on your chest grows warm again. A ripple beneath you, near the castle. Human sized this time at least, but a dull black. A gargoyle like creature begins to form, wings fanning out around it - hundreds of feet, the wings impossibly long. They scythe through whatever blocks them - stone, metal, bone. Nothing stops them, severed apart completely.
Joining init.
> roll 1d20+18 gargoyle
<Kobot> Kotono rolled 1d20+18 gargoyle --> [ 1d20=11 ]{29}
Init is Alicia (Supreme) > Gargoyle? (29) > Eye Horror (24) > Antenora (23)
Go.
Antenora
HP: 959+20/959
Resources: Holy Fury 41/42 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 17/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 24/25 Divine Blast 18/18
Spells Used:
SLAs Used:
#284
Alright, it's time for Alicia to stop playing around! Distorting space so she can move to between the gargoyle and the combination-eye-horror, Alicia grows to a size that exceeds both and then slices out with her twin holy blades to deadly effect.
Free action to compress space, five foot step, swift to go colossal, then full attack.
[19:08] <@Ebiris> roll 1d20+99 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch
[19:08] <Kobot> Ebiris rolled 1d20+99 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=12 ]{111}
[19:09] <Kobot> Ebiris rolled 1d20+99 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=9 ]{108}
[19:09] <@Ebiris> roll 1d20+99 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch
[19:09] <Kobot> Ebiris rolled 1d20+99 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=8 ]{107}
[19:09] <@Ebiris> roll 1d20+94 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch
[19:09] <Kobot> Ebiris rolled 1d20+94 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=19 ]{113}
[19:09] <@Ebiris> roll 1d20+89 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch
[19:09] <Kobot> Ebiris rolled 1d20+89 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=3 ]{92}
[19:09] <Kobot> Ebiris rolled 1d20+89 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=17 ]{106}
[19:09] <@Ebiris> roll 1d20+84 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch
[19:09] <Kobot> Ebiris rolled 1d20+84 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=19 ]{103}
[19:09] <Kobot> Ebiris rolled 1d20+84 blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=15 ]{99}
[19:09] <@Ebiris> roll 1d20+94 crit check for 113
[19:09] <Kobot> Ebiris rolled 1d20+94 crit check for 113 --> [ 1d20=8 ]{102}
[19:09] <Kobot> Ebiris rolled 1d20+94 crit check for 113 --> [ 1d20=18 ]{112}
[19:09] <@Ebiris> roll 1d20+89 crit check for 106
[19:09] <Kobot> Ebiris rolled 1d20+89 crit check for 106 --> [ 1d20=16 ]{105}
[19:09] <@Ebiris> roll 1d20+84 crit check for 103
[19:09] <Kobot> Ebiris rolled 1d20+84 crit check for 103 --> [ 1d20=10 ]{94}
[19:10] <@Ebiris> roll 1d20+49 vampiric touch SR
[19:10] <Kobot> Ebiris rolled 1d20+49 vampiric touch SR --> [ 1d20=14 ]{63}
[19:11] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+120
[19:11] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 --> [ 6d6=19 2d6=4 3d6=10 14d4=37 ]{235}
[19:12] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+120
[19:12] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 --> [ 6d6=20 2d6=5 3d6=10 14d4=30 ]{230}
[19:12] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 --> [ 6d6=22 2d6=7 3d6=11 14d4=35 ]{240}
[19:12] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 --> [ 6d6=25 2d6=5 3d6=8 14d4=36 ]{239}
[19:12] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+240 if 113/102 was a crit
[19:12] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+240 if 113/102 was a crit --> [ 12d6=38 2d6=9 6d6=17 14d4=34 ]{428}
[19:12] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+120 if not
[19:12] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 if not --> [ 6d6=18 2d6=6 3d6=9 14d4=36 ]{234}
[19:12] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+240 if 113/112 was a crit
[19:12] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+240 if 113/112 was a crit --> [ 12d6=50 2d6=8 6d6=23 14d4=35 ]{446}
[19:12] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 if not --> [ 6d6=16 2d6=9 3d6=12 14d4=34 ]{236}
[19:12] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 --> [ 6d6=24 2d6=8 3d6=16 14d4=38 ]{251}
[19:12] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+240 if 106/105 was a crit
[19:12] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+240 if 106/105 was a crit --> [ 12d6=48 2d6=10 6d6=27 14d4=35 ]{450}
[19:13] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 if not --> [ 6d6=25 2d6=9 3d6=7 14d4=33 ]{239}
[19:13] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+240 if 103/94 was a crit
[19:13] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+240 if 103/94 was a crit --> [ 12d6=42 2d6=7 6d6=18 14d4=33 ]{430}
[19:13] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+120 if not
[19:13] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 if not --> [ 6d6=19 2d6=7 3d6=17 14d4=37 ]{245}
[19:28] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+120
[19:28] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+120 --> [ 6d6=15 2d6=5 3d6=5 14d4=27 ]{217}
Each hit inflicts a negative level, 2 on the crits. Alicia will commence attacks on the gargoyle and swap to the eye horror when it drops.
Alicia HP: 574+240/854
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/2/8/4/6/7/6/3
Duskblade spell slots: 6/23/23/21/11/6/16/3
