Shadow rondo
#300
"Come then, fury of the Abyss," Alicia challenges boldly, resetting her stance after that clash, mind on the battle even with those memories of ones past. "Aren't I the invader here, after all? Show me you have something worth protecting!"
Init is Alicia (Supreme) > Faranos (Fell Hunter) > Eye Horror (24) > Antenora (23) > Spear (22)
To your words, the mouth that birthed Faranos screams. It screams loud, a high pitched wail as great blobs of acid come forth from its mouth - three fly right at you and three at Antenora, smaller than the previous attack but still coming in hot and fast. When they close in they erupt into great blasts of acid, threatening to entomb you in agony.
Faranos meanwhile gathers himself anew, fury on his face now as he brandishes his spear for another charge.
Refx3.
[16:43] <@Ebiris> roll 3#1d20+73 ref
[16:43] <Kobot> Ebiris rolled 3#1d20+73 ref --> [ 1d20=15 ]{88}, [ 1d20=9 ]{82}, [ 1d20=1 ]{74}
Alicia HP: 1150+240/1150
Active spells: Many moments of prescience (CL 39), extended mind blank (CL 40), extended nondetection (CL 40), greater heroism (CL 37), extended ray deflection (CL 40), epic mage armour (CL 37), sensual blessing (CL 37), greater foresight (CL 39), keen edge (CL 37 on sword), dance of the unicorn (CL 37), extended greater anticipate teleportation (CL 39), repelling shield (CL 39), freedom of movement (CL 37), greater visage of the deity (CL 37), recitation (CL 37), good hope (CL 37)
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/0/8/4/6/7/6/3
Duskblade spell slots: 6/23/23/21/11/6/16/3
Moments of prescience left: 4
> roll 3#1d20+67 Antenora evasion a 2 level dip into monk appeals to her more and more some days
<Kobot> Kotono rolled 3#1d20+67 Antenora evasion a 2 level dip into monk appeals to her more and more some days --> [ 1d20=10 ]{77}, [ 1d20=19 ]{86}, [ 1d20=20 ]{87}
Each one is 120 points of damage half acid and half unholy. Antenora has resistance 20 to acid and electricity, so that's 60 damage off the total for her. 300 damage total for Antenora.
The acid mars both of you, sizzling pain as Antenora is splashed. Her leg, arm and side hisses, burnt deeply by the acids. At the same time, as pain wraps across your body...
Antenora is up. What's your HP, Alicia, so she can do healing as needed.
Antenora
HP: 679/959
Resources: Holy Fury 39/42 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 17/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 24/25 Divine Blast 18/18
Spells Used:
SLAs Used:
Typical Charging Numbers: 36 for base smite damage, 72 for charging smite +2 per per level. So 108 bonus damage baseline. Raw attack plus smite is 1d8+145+2d6+2d6 (+4/+4d6 if fiendbane hits). Doesn't include other factors.
Did I make the saves?
1030/1150 if I didn't, 1150+60/1150 if I did.
You did, I'm sorry.
Antenora's burns begin to heal as she is a blur. A raw dart dead on at Faranos, a coming clash that - !
> roll 1d20+90 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -20 PA)
<Kobot> Kotono rolled 1d20+90 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -20 PA) --> [ 1d20=12 ]{102}
> roll 213*3
<Kobot> Kotono rolled 213*3 --> {639}
> roll 3d8+639+2d6+2d6+10d6
<Kobot> Kotono rolled 3d8+639+2d6+2d6+10d6 --> [ 3d8=21 2d6=9 2d6=6 10d6=38 ]{713}
Antenora's spear meets his chest. A flare of metal gray light. A defense? Yet Antenora's spear shines and plunges through it, into his chest and out his back. Antenora pulls her spear out, no blood. He hovers there, chest and heart torn apart and body weeping opal blue light.
Meanwhile the spear weeps. Globs of itself rain down to the ground as it slowly loses its shape.
Warmth. Your chest grows warm as the gem of truth glows. Above you. A crack in the air, reality wounded. A red hand as large as you are extends out, above you, ready to strike you.
> roll 1d20+13 Hand
<Kobot> Kotono rolled 1d20+13 Hand --> [ 1d20=6 ]{19}
Init is Alicia (Supreme) > Faranos (Fell Hunter) > Eye Horror (24) > Antenora (23) > Hand (19)
Go Alicia.
Antenora
HP: 789/959
Resources: Holy Fury 37/42 (enc) Divine Retribution 1/1 Smite Evil 11/13 Channel Energy 17/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 23/25 Divine Blast 18/18
Spells Used:
SLAs Used:
If stuff is teleporting/gating in, Alicia has greater anticipate teleportation up for 3 rounds of warning.
Alicia HP: 1150+60/1150
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/0/8/3/6/7/6/3
It's not a teleport/gate in that sense.
"This could keep dragging on, Antenora. Make for the castle, we need to solve this at its source," Alicia says, at least clearing the area to prevent immediate pursuit as she lays into the eye horror and then other targets that present themselves.
First attack is eye, second is hand, third is Faranos. Then all attacks are on the eye until it dies, at which point she switches to the hand, and then Faranos.
[18:54] <@Ebiris> roll 1d20+99 blinding speed, 14th level arcane strike, channelled maximised ravaging touch
[18:54] <Kobot> Ebiris rolled 1d20+99 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=16 ]{115}
[18:54] <Kobot> Ebiris rolled 1d20+99 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=1 ]{100}
[18:54] <Kobot> Ebiris rolled 1d20+99 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=12 ]{111}
[18:54] <Kobot> Ebiris rolled 1d20+99 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=5 ]{104}
[18:54] <@Ebiris> roll 1d20+94 blinding speed, 14th level arcane strike, channelled maximised ravaging touch
[18:54] <Kobot> Ebiris rolled 1d20+94 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=19 ]{113}
[18:54] <Kobot> Ebiris rolled 1d20+94 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=7 ]{101}
[18:54] <@Ebiris> roll 1d20+89 blinding speed, 14th level arcane strike, channelled maximised ravaging touch
[18:54] <Kobot> Ebiris rolled 1d20+89 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=12 ]{101}
[18:54] <Kobot> Ebiris rolled 1d20+89 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=3 ]{92}
[18:54] <@Ebiris> roll 1d20+84 blinding speed, 14th level arcane strike, channelled maximised ravaging touch
[18:54] <Kobot> Ebiris rolled 1d20+84 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=14 ]{98}
[18:54] <Kobot> Ebiris rolled 1d20+84 blinding speed, 14th level arcane strike, channelled maximised ravaging touch --> [ 1d20=12 ]{96}
[18:55] <@Ebiris> roll 1d20+94 crit check
[18:55] <Kobot> Ebiris rolled 1d20+94 crit check --> [ 1d20=11 ]{105}
[18:55] <@Ebiris> roll 1d20+51 SR on ravaging touch
[18:55] <Kobot> Ebiris rolled 1d20+51 SR on ravaging touch --> [ 1d20=15 ]{66}
[18:56] <@Ebiris> roll 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores
[18:56] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=21 2d6=7 3d6=6 14d4=30 ]{109}
[18:56] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=29 2d6=6 3d6=10 14d4=28 ]{118}
[18:56] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=23 2d6=4 3d6=8 14d4=28 ]{108}
[18:56] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=16 2d6=7 3d6=14 14d4=36 ]{118}
[18:56] <@Ebiris> roll 12d6+90+2d6+6d6+14d4 and 2 negative level and 20 ability drain to all ability scores if 113/105 was a crit
[18:57] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4 and 2 negative level and 20 ability drain to all ability scores if 113/105 was a crit --> [ 12d6=48 2d6=3 6d6=18 14d4=38 ]{197}
[18:57] <@Ebiris> roll 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores if it wasn't
[18:57] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores if it wasn't --> [ 6d6=25 2d6=9 3d6=12 14d4=29 ]{120}
[18:57] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=13 2d6=7 3d6=11 14d4=30 ]{106}
[18:57] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=17 2d6=10 3d6=12 14d4=32 ]{116}
[18:57] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=14 2d6=7 3d6=12 14d4=26 ]{104}
[18:57] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=21 2d6=5 3d6=7 14d4=38 ]{116}
[18:57] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4 and 1 negative level and 10 ability drain to all ability scores --> [ 6d6=27 2d6=8 3d6=6 14d4=41 ]{127}
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/0/8/3/6/7/5/3
Your blade is relentless. Faranos is torn and sent back, bloodied further and yet he does not bleed. The hand is chipped, bleeding red blood but little more. The eye? The eye deflates under your assault, slumping down. The metal umbilical cord for Faranos crumbles away as the eye goes still and silent.
Anything else this turn?
A pair of force walls appear between Antenora and Faranos as well as between the Hand and Alicia, buying them more time to retreat to the castle and make their way to 666's entrance rather than wasting more time here.
2x quickened wall of force. Each covers 180x190 feet.
Sorcerer spell slots: 6/16/16/12/9/9/14/7/9/0/8/3/6/7/5/3
Init is Alicia (Supreme) > Faranos (Fell Hunter) > Antenora (23) > Hand (19)
The wall indeed stalls Faranos. He retreats back and up, getting a line to Antenora. At the same time he concentrates, a spear of gray stone appearing in hand. Antenora wastes no time in the slightest, 'I understand, Alicia.' She flies as her wounds heal, hurrying along rapidly, towards the castle in a blur of opal blue light.
At the same time the great hand from above slams down and...
> roll 1d20+42 dispel check
<Kobot> Kotono rolled 1d20+42 dispel check --> [ 1d20=14 ]{56}
CL on the wall?
Antenora
HP: 959/959
Resources: Holy Fury 35/42 (enc) Divine Retribution 1/1 Smite Evil 11/13 Channel Energy 17/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 23/25 Divine Blast 18/18
Spells Used:
SLAs Used:
The wall crumbles away, broken by arcane might. But that's it, your path free for now.
Warmth on your bosom.
Coffins begin to rise from the wartorn ground, the heaps of the dead parting as stone coffins emerge. None open yet, but thousands emerge all around.
Go.
Alicia doesn't stick around, she flies right after Antenora towards the ruined elven castle at top speed!
