Dragon quickstep
Since it worked properly to start with, I did take you for a fool, Seira admits. That said, I'm not sure what I've seen so far changes my opinion.
Well then, she might as well keep enraging Imix by treating him dismissively. Rather than rushing him, Seira merely uses the scroll she'd prepared. Waste not, want not~
She does connect the spot directly between herself and Imix to one directly between herself and his third and free avatar.
To recap, I'm 305ft away from Imix, two of his avatars are in Forcecages. There's some chaff around ImixPrime. My unarmed attacks have Superb Dispelling channeled. I also successfully cast Strength of the Dragon Princess and Endurance of the Dragon Princess.
Armbands of the Spark 1/10rnd
Space Compression 1/38rnd
All spells here are to be precast before leaving home [CL 38]. The spells under 'All' are shared with all party members unless explicitly refused.
All:
Glorious Rally [1min/lvl], Celestial Valor [1min/lvl], Foresight [10min/lvl], Visions of the Future [1hr/lvl], Dragonskin [10min/lvl], True Seeing [1min/lvl], Vision of the Omniscient Eye [1min/lvl], Detect Scrying [24hr], Greater Arcane Sight [1min/lvl], Freedom of Movement [10min/lvl], Pass Without Trace [1hr/lvl], Voice of the Dragon [10min/lvl], Greater Heroism [1min/lvl], Good Hope [1min/lvl], Nondetection [1hr/lvl], Mass Death Ward [1min/lvl], Heroes's Feast [12hr], Fortunate Fate [10min/lvl], Spell Turning [10min/lvl]
One-Off Spells: Sign (+4), Divine Insight (1hr/level, +15 insight), Greater Improvisation (10min/level, CLx3 luck points)
Self only:
Sensual Blessing [1min/lvl], Greater Anticipate Teleport [24hr], Bibliotheca Arcana [24hr], Mind Blank [A, 24hr], Many Moments of Prescience [1hr/lvl], Moment of Prescience [1hr/lvl]
Superb Dispelling channeled into unarmed attacks, Keen Edge cast on Razalim, Crystalvein weapons and natural weapons
Numerical benefits:
AC: +14 normal/+9 touch (+2 insight Foresight, +5 sacred Shield of Warding, +2 dodge Visions of the Future, +5 natural armor Dragonskin)
Attack: +26 (+4 sacred Celestial Valor, +20 morale Inspire Courage, +2 insight Strength of the Dragon Princess)
Damage: +26 (+4 sacred Celestial Valor, +20 morale Inspire Courage, +2 insight Strength of the Dragon Princess)
Fort Save: +12 (+4 sacred Celestial Valor, +6 morale Glorious Rally, +2 insight Endurance of the Dragon Princess)
Will Save: +10 (+4 sacred Celestial Valor, +6 morale Glorious Rally)
Ref Save +13 (+5 sacred Shield of Warding, +6 morale Glorious Rally, +2 insight Foresight)
Ability Checks: +2 (+2 morale from Good Hope)
76 temp hp
Also immunity to all death spells, magical death effects, energy drain, and any negative energy effects (Mass Death Ward), immunity to poison and fear (Heroes's Feast), being a difficult target to divination (Nondetection), becoming impossible to track without magic, and limiting the usefulness of scent (Pass Without Trace), moving and attacking normally everywhere, as well as receiving +15 to CMD vs grapples (Freedom of Movement), being healed with 150hp once if dropped below 0 (Fortunate Fate), reflecting 1d4+6 spell levels of spells that have you as a target and aren't touch spells (Spell Turning), +10 enhancement bonus on Bluff, Diplomacy, and Intimidate checks and a really nice and deep commanding voice (Voice of the Dragon), true seeing, +10 to perception and immunity to being dazzled or blinded (Vision of the Omniscient Eye), immediate ability to analyze magic (Greater Arcane Sight) and for Seira only the combo of detecting when someone's scrying on you and blocking their teleport for 3 rounds any time they try to teleport within a 190ft radius of you.
My unaltered stats (dragon)
Supreme Initiative: (+21 vs DvR6)
Armor Class: 104 (Touch AC 74)
Base Attack/CMB/CMD: +37/+90/168
Attack: +82 [Good, Lawful and Epic] (+24 Str, Haste, K:D +5, DvR6, Luck +3, +10 Enhancement, BAB=HD)
Full Attack: +82/+82/+82/+82/+77/+72/+67 (6d10+104) and bite +77 (4d6+97) and claws +77/+77 (2d8+97) and wings +77/+77 (2d6+97) and tail slap +77 (2d8+121) [19-20 x2]
Full Attack (flanking): +86/+86/+86/+86/+81/+76/+71 (6d10+127) and bite +81 (4d6+120) and claws +81/+81 (2d8+120) and wings +81/+81 (2d6+120) and tail slap +81 (2d8+144) [19-20 x2, +23d6 and 2 Str damage]
Saves: Fort +87, Ref +72, Will +80
Abilities: STR 57+2 (23+1), DEX 26 (8), CON 47+6 (18+3), WIS 30+6 (10+3), INT 50+6 (20+3), CHA 41 (15)
Darkstalker, Improved Evasion, Improved Uncanny Dodge, Spell Reflection, Aegis, Damage reduction 20/epic adamantine weapons that are colorlessand, 12 regeneration, immunity to acid, electricity and fire, immunity to paralysis and sleep, spell resistance 50, vulnerability to cold, darkvision 6 miles, low-light vision 6 miles
Space/Reach: 20ft/15ft (Reach 20ft with bite)
Special Attacks: Breath weapon 22d10 fire+4d10holy (60ft cone, 120ft line) Ref DC53 half, prismatic breath 5x18d8 (60ft cone, 120ft line) Ref DC49 (energy, 5x half hd)/prismatic spray (60ft cone) DC49 (depending on the result of d8)
Init is Seira (Supreme) > Sanzha (59) > Imix Avatars (54) > Imix (53) > Ranbar (35) > Donald (14)
Do you need support after all, Seira?
It's just a nullifying barrier at three hundred feet, but his avatars didn't have it and it didn't touch any of my spells or interrupt with regular casting. The best all of you could do is take down an avatar quickly and join me to deal with Imix himself.
> roll 1d20+102 (+2 charge, +4 sacred, +20 morale, +16 melody of water, +2 flood)
<Rei-chan> Kotono rolled : 1d20+102 (+2 charge, +4 sacred, +20 morale, +16 melody of water, +2 flood) --> [ 1d20=16 ]{118}
> roll 1d100 vs ???
<Rei-chan> Kotono rolled : 1d100 vs ??? --> [ 1d100=5 ]{5}
Directness. Flames part as Sanzha swims through the air like water. A dart fast as the onrushing flame, going to meet the avatar head on. The two clash, a series of blows powerful but not decisive. Flame meets trident, neither triumphant over the other as...
> roll 2#1d20
<Rei-chan> Kotono rolled : 2#1d20 --> [ 1d20=20 ]{20}, [ 1d20=9 ]{9}
Two of the avatars simply disintegrate the cages around them, disintegration the perfect counter to force cage. They draw in strength around themselves as the one Sanzha faces duels with her.
SUFFER!
No. There's been enough of that. Your turn.
> roll 1d20+128 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike)
<Rei-chan> Kotono rolled : 1d20+128 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=9 ]{137}
<Rei-chan> Kotono rolled : 1d20+128 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=12 ]{140}
<Rei-chan> Kotono rolled : 1d20+128 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=5 ]{133}
<Rei-chan> Kotono rolled : 1d20+128 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=13 ]{141}
<Rei-chan> Kotono rolled : 1d20+128 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=19 ]{147}
-10 for all of those, I forgot to subtract his divine bonus in all the math. They all still hit, however.
> roll 1d20+10
<Rei-chan> Kotono rolled : 1d20+10 --> [ 1d20=6 ]{16}
> OOC: +4 more for strata.
> roll 1d20+1 could get a 20 at least
<Rei-chan> Kotono rolled : 1d20+1 could get a 20 at least --> [ 1d20=6 ]{7}
Fire immunity bypassed.
> roll 4d8+57+3d8+13d4-25 at least it doesn't beat her DR
<Rei-chan> Kotono rolled : 4d8+57+3d8+13d4-25 at least it doesn't beat her DR --> [ 4d8=11 3d8=18 13d4=40 ]{101}
<Rei-chan> Kotono rolled : 4d8+57+3d8+13d4-25 at least it doesn't beat her DR --> [ 4d8=8 3d8=6 13d4=34 ]{80}
<Rei-chan> Kotono rolled : 4d8+57+3d8+13d4-25 at least it doesn't beat her DR --> [ 4d8=21 3d8=18 13d4=38 ]{109}
<Rei-chan> Kotono rolled : 4d8+57+3d8+13d4-25 at least it doesn't beat her DR --> [ 4d8=17 3d8=18 13d4=31 ]{98}
<Rei-chan> Kotono rolled : 4d8+57+3d8+13d4-25 at least it doesn't beat her DR --> [ 4d8=14 3d8=7 13d4=32 ]{85}
<Rei-chan> Kotono rolled : 4d8+57+3d8+13d4-25 at least it doesn't beat her DR --> [ 4d8=17 3d8=13 13d4=33 ]{95}
> roll 101+80+109+98+85+95
<Rei-chan> Kotono rolled : 101+80+109+98+85+95 --> {568}
Ow.
> roll 568-37 temp HP from madalani
<Rei-chan> Kotono rolled : 568-37 temp HP from madalani --> {531}
The avatar of Imix strikes with fury, his flaming tendrils raking across Sanzha's body. Deep, burning welts are left behind, gouges carved out of her and seared too fast to bleed. Sanzha reels back from it as that Imix screams, screams loud enough to engulf Sanzha in yet more fire and flame.
Quickened Imix's Burning Screamx2 with two swifts thanks to multiaction.
> roll 1d20+55 Fort Sanzha
<Rei-chan> Kotono rolled : 1d20+55 Fort Sanzha --> [ 1d20=14 ]{69}
<Rei-chan> Kotono rolled : 1d20+55 Fort Sanzha --> [ 1d20=12 ]{67}
> roll 50d6 havled
> roll 50d6 havled
<Rei-chan> Kotono rolled : 50d6 havled --> [ 50d6=185 ]{185}
<Rei-chan> Kotono rolled : 50d6 havled --> [ 50d6=152 ]{152}
> roll 185+152
<Rei-chan> Kotono rolled : 185+152 --> {337}
> roll 337/2
<Rei-chan> Kotono rolled : 337/2 --> {168}=
The screams catch Sanzha ablaze, unyielding fires burning her body. As she is assaulted the last of the Imix avatars holds while...
Last one is holding. Imix.
Grovel before me and live, Seira.
Seira's Majestic Visage on Ranbar.
+20 inspire courage (attacks, weapon damage, saves vs fear)
Sanzha gets melody of water on herself.
Add greater divine power to Ranbar's block.
All:
Numerical benefits:
Attack: +10 (+4 sacred Celestial Valor, +6 morale Glorious Rally)
Damage: +10 (+4 sacred Celestial Valor, +6 morale Glorious Rally)
Fort and Will Saves: +10 (+4 sacred Celestial Valor, +6 morale Glorious Rally)
76 temp hp
Donald
HP: 890/890
Aura: Divine 10ft (various)
Resources: Protection Devotion 1/1 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1 Armor Haste 14/15 Breath Weapon Boost 3/3 Weapon Damage Dice Boost 3/3 Strength Domain 1/1 Luck Domain 1/1 Protection Domain 1/1
Spells Used: 2 9th
SLAs Used:
Spells Active:
Notes: Two quickened spells/round when under armor's haste, unkillable allows Con saves to not be reduced below 1 HP. Slashing flurry enables extra attacks for penalties.
Lady Sanzha
HP: 73(-1)/866(792) (fast healing 3)
Resources: Channel Elements 17/17 Bardic Music 36/36 Water Devotion 1/1 Trident Elemental Damage 3/3 Nobility Domain 1/1
Spells Used:
SLAs Used:
Spells Active:
Notes:
Ranbar
HP: 721/818
Aura:
Resources: Channel Energy 14/14 Inspiration 28/29 Cunning Save 4/4
Spells Used: Greater divine power,
SLAs Used:
Spells Active:
Notes: Baseline cunning insight is +4 from feats, exalted adds +6, ring adds +1, total of +11 if used in tandem with that.
Actually manage to tag me first, Imix, Seira tells him scornfully, before her voice speaks for her friends's ears alone. Donald, Ranbar, how about ganging up on Sanzha's opponent? Since entrapping all of them failed, reduce their numbers to three and then you'll each have a single one to deal with properly.
Post will be awhile since not feeling great, so reminder for self: Rank check and HP correction for Sanzha.
Sanzha HP correction first, since she won the rank check not to take extra fire damage. I used Imix's total for the rank check, not the avatar's. Whoops. This removes 3d8 from the melee attacks.
> roll 18+6+18+18+7+13
<Rei-chan> Kotono rolled : 18+6+18+18+7+13 --> {80}
80 HP.
Additionally this removes half the damage taken from the Imix's Burning Screams.
> roll 168/2
<Rei-chan> Kotono rolled : 168/2 --> {84}
84 more for a total of 164 hit points refunded.
More in the next post.
All:
Numerical benefits:
76 temp hp
Donald
HP: 890/890
Spells Used: 2 9th
SLAs Used:
Spells Active:
Lady Sanzha
HP: 237(163)/866(792) (fast healing 3)
Spells Used:
SLAs Used:
Spells Active:
Notes:
Ranbar
HP: 721/818
Aura:
SLAs Used:
Spells Active:
Space begins to twist around all of you, as...
All of you are entitled to rank checks against Imix here, so go ahead.
18:34 <Corwin> roll 1d20+6
18:34 <Rei-chan> Corwin rolled : 1d20+6 --> [ 1d20=15 ]{21}
> roll 1d20+1 Donald
<Rei-chan> Kotono rolled : 1d20+1 Donald --> [ 1d20=5 ]{6}
> roll 1d20+1 Sanzha
<Rei-chan> Kotono rolled : 1d20+1 Sanzha --> [ 1d20=10 ]{11}
> roll 1d20 Ranbar
<Rei-chan> Kotono rolled : 1d20 Ranbar --> [ 1d20=12 ]{12}
> roll 1d20+10 +4 vs Donald and Sanzha, +8 vs Ranbar so this is basically just against Seira
<Rei-chan> Kotono rolled : 1d20+10 +4 vs Donald and Sanzha, +8 vs Ranbar so this is basically just against Seira --> [ 1d20=12 ]{22}
Space twists, more and more and more. Imix is now 3000ft away on his volcano, everything here responding to his will. At the same time the avatar that held is right behind you as it hisses, "Time to die, Seira," it declares in Ignan.
> roll 1d20+118 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike)
<Rei-chan> Kotono rolled : 1d20+118 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=6 ]{124}
<Rei-chan> Kotono rolled : 1d20+118 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=7 ]{125}
<Rei-chan> Kotono rolled : 1d20+118 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=11 ]{129}
<Rei-chan> Kotono rolled : 1d20+118 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=2 ]{120}
<Rei-chan> Kotono rolled : 1d20+118 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=17 ]{135}
<Rei-chan> Kotono rolled : 1d20+118 (+2 ???, +5 ???, +12 ???, +10 ???, +13 arcane strike) --> [ 1d20=8 ]{126}
AC?
AC right now is 119, but wasn't the attack with the same bonuses +128 vs Sanzha?
Yes, but if you read the post of it, I noted right after I forgot to remove the -10 for divine rank. Therefore, this is that with that properly removed instead of manually removed after. Any miss chance before I get to damage rolling?
Okay then.
> roll 1d20
<Rei-chan> Kotono rolled : 1d20 --> [ 1d20=16 ]{16}
You don't auto win this since the avatar rolled well, so rank check.
19:21 <Corwin> roll 1d20+6
19:21 <Rei-chan> Corwin rolled : 1d20+6 --> [ 1d20=9 ]{15}
