Sunshine
Started by Anastasia, April 30, 2021, 01:44:19 PM
Decided to make a small cavern underground instead of using Screen. Meant to mention it but it slipped my mind. If this is a big temple, then Malar will likely be watching the immediate area to some degree and an illusion is easy to see through.
Okay, since you changed the plan and didn't post about it, just lay the entire thing out again so we're both on the same page.
Xorn Movement to in range for the Lizards to get there, shake it down, and get back. Once there, create a small cavern (everyone will be Shrink Person'd to keep it small as possible). Deploy lizards, shake it down, call them back, extract.
Only thing that changed is replacing Screen with a small cavern.
Okay, stealth check real quick then.
Stealth/Cunning Knowledge:
[blockquote]Rolled 1d20+109 : 5 + 109, total 114[/blockquote]
Slowly and carefully you sneak over, coming towards the tower without any obvious incident.
Alyssa gives the lizards their instructions, and provide a mental image of each groups target location, casts telepathic bond on them, and then lets them go!
I have no idea how to really "describe" what locations since we never went over the architecture, but I did previously mention to Emily I wanted some sort of intel on it and she said she'd get it.
Okay, I assume they're competent enough to give it done anyway with prep.
As you prepare them?
'Ready?' Emily sends back to you.
'As much as we can be.'
'Then let's do this, Alyssa.' Emily sends back.
Alyssa nods and sends the lizards out!
Thus the lizards go and begin, burrowing and preparing on your command.
'Good,' Honeydip calls, 'The first part is begun.'
Alyssa maintains her telepathic link to the lizards, waiting for them to get into position.
That all goes well enough, lizards getting into position.
Alyssa sends to everyone, 'They're in position. We all ready?'
