Wolfwood, Mihoshi and Kiyone: Strength in Numbers!
Started by Bean Bandit, December 02, 2002, 01:45:45 AM
Ginnezumusha
Ginn ducked back down, and moved another 10 paces under the cover of the dune, before popping back up and taking aim this time, before firing again.
CyMage
"I'm going to open this door, hopefuly there is nothing dangerous behind it."
With that Kiyone kept the blaster ready in her right hand, and turned the knob with her left.
CyMage
Cy shook his head.  "An airlock doesn't mean we're in space.  It be a spaceship, but it could still be on the ground."
Grinning at his partner he asked.  "Want to check it out with me?"
Ginnezumusha
Ginn brought up the back, checking behind him every so often for those robots.
OOC:  Long time no post.  ~_~
Bean Bandit
OOC: My apologies for an unexplained and prolonged absence. @_@
IC: Vash nodded, winking at Kiyone. "Whatever you say, cutie." he grinned, and began marching down the hall.
A few feet away, he turned and called back to the group. "The patrol routes start again at the end of this corridor..." he warned.
calendar
Calendar nodded slightly, then looked to Cy.  She could deal with them, and if worse came to worse... her hand rested lightly upon her leg as she walked.
She had her blaster, and this time around, she would shoot.
Of course, she had never exactly shot off a weapon before, so she'd probably miss, but the comfort was nice.
 Princess_Herb turns into the sexy girl soldier, Sailor_Dragon
*** Princess_Herb is now known as Sailor_Dragon
* Unseen is vaguely creeped out
<Calendar> Only vaguely?
Bean Bandit
Vash came to the end of the corridor, and he glanced cautiously around the corner.
"Wai! Coast is clear!" He shouted cheerfully, and began walking down the joined corridor, headed in roughly the same direction Kiyone and Mishoshi had come from.
CyMage
"Cool.  Lets go then."  Kiyone followed Vash down the hall.
Ginnezumusha
Ginn brought up the rear, checking behind him for enemy robots.
Bean Bandit
For the most part the corridor they had turned into was a virtual match for the others. There was no sound except for Vash's humming as they wandered through the semi-darkened corridors...
Ginnezumusha
Bean Bandit
Vash smiled over his shoulder. "The central power node controls should be nearby." he called back to Wolfwood. "The moment we shut down the power there, the robots should shut down."
Ginnezumusha
Ginn follows cautiously, hoping that they get there soon.
Bean Bandit
Vash finally leads them to a raised platform, overlooking a huge room, several times larger than the area Kiyone and Mihoshi first entered, almost the size of a sports arena.
There are several man-sized glass storage units scattered about the room, and, in the center, a large, opaque room can be seen, towering above the glass cases, a small building in it's own right, though sleek and rounded, futuristic looking, with a single window in it, allowing a glimpse of electronics within.
Unfortunately, at nearly the exact moment they looked out over the railing, the lower bay doors entering into the large room opened, and what looked like scores of the robots that they'd faced began pouring into the room...
Ginnezumusha
Ginn calmly (externally) turns to his party and poses a question.
"Shoot first, ask questions later?  Or flee like rabbits?"
