Floor 1 "Wheel": 1-1
OOC: Two errata, both proof I shouldn't post while stupid. It takes four rounds to reach the door and the door is open. 20/24 air, Drac. Sorry.
The door is already open, there is no need to open it. Ahead Shadow can see a watery hall that goes on for the sixty feet, then a downward slope. All waterlogged, of course. About thirty feet ahead, Shadow can see a narrow crack has opened in the floor.
OOC: How far can I go in a round?  Heh, without that I can't judge the swim distance versus rounds :)
http://www.d20srd.org/srd/skills/Swim.htm
Basically half your move or a quarter depending on the action type. Assuming half unless you want to do something zany or wacky while swimming.
Shadow heads that 30 feet in, taking a check down the crack.
Shadow reaches the crack without incident! Water is trickling down it. The sides around the crack are quite loose and damaged, almost falling apart. The crack is quite dark and narrow to see in. You'd need ot spend a little time, a round, to peer down and have a chance to discern anything.
Shadow continues  on, checking the downward slant ahead.
Shadow swims further! There's a gap in the roof leading up, more swimming space in an alternate passage. The tunnel also continues onward.
Shadow checks the gap leading upward, seeing if there's air here.
Taking a round to swim up, Shadow finds no air! There is a heavy steel grate just at where the water seems to break. However, there is a small passage just below the grate, a part of the wall having slid away.
Shadow checks the passage out, seeing where it leads.
Swimming 30 more feet up, Shadow passes two empty pedestals built into the wall. It looks like something was once there, but not anymore. The new hole is four more rounds of swimming away.
Shadow takes the time to head back to Varian, "I'm going to take another look," He hung at the side for a moment catching his breath properly.
"Long path underwater?" Varian asks curiously.
OOC: ANd there's my bad.
IC:
"Yeah..." Shadow described what he'd seen.  "Possibly a mid way air stop though...going to check."
Shadow headed back to the secret wall part and looked there, not stopping at all on the way this time.
18/24, air refreshed and six rounds to get there.
Shadow returns to the crack without incident!
