Floor 1 "Wheel": 1-1
* Hatbot --> "XornKokokoko rolls 1d20+4 DC 10 and gets 22." [1d20=18]
* Hatbot --> "XornKokokoko rolls 1d20+4 DC 10 and gets 16." [1d20=12]
Shadow successfully swims between the purplish plants, reaching the top!
Shadow hurriedly tries to find whatever was needed to open the upward passageway.
Doesn't look like much of anything is needed. It's a little pull out panel, your hands and a little bit of oomph would suffice to do so.
Shadow opens the panel! It's about double the size of his head, removed and pulled back! It hides a gap upward of about a foot tall and the same width of the panel. There are deeper recesses in both walls if one wishes to poke one's head in and look. Further...the water stops at where the panel was! There are lungfuls of real air just waiting inside!
Shadow tests it with his sword first.  Poking all around for safety.
Shadow taps his sword around! Nothing comes out to impale it or damage it in any way.
Shadow hurries in for the healthy oxygen..and looks around above.
Air! Real, glorious air!
There are two little gaps facing each other. One has a pile of what looks to be loose paper and rubbish covering something. The other has a lever at the end that could be pulled out to trigger something, presumably.
Shadow checked the loose paper and rubbish.
Under the papers is a rod, colored black and blue.
Shadow takes the rod...then pulls the lever.
OOC: Normally I'd use a rope or something, but I'm kind of out of props. :(
Shadow obtains the ROD!
Shadow pulls the lever! The lever makes a gentle, creaking sound! The water is starting to lower - fast!
Shadow quickly glances down, what's below him?!
The water is down to his waist! It looks like the water is descending fast!
