Floor 1 "Wheel": 1-1
Shadow tries to enter, seeing what's in there.
Clarification since I'm a dumbass: Did you mean the crack, or the passage under the grate as you swum up?
OOC: The passage under the grate as I swam up
Air is 16/24 then. Right-o.
It's a pretty narrow, snaking passage. Shadow can see that it'll take time and effort to swim down, and it'll also be dangerous to do so. Not dangerous in an immediate sense, but getting out could be difficult when one is short on air.
Shadow headed in, trying to get a look further down, staying only a moment before rushing back.
Shadow swims deeper! He pokes his head in and swims 15 feet! 75 feet ahead there is an upward swing in the water tunnel.
Shadow rushes toward the upward swing~
Shadow swims ahead! The passage goes thirty feet up! There is a little pull-panel built into the dead end there, as if the ceiling has a compartment to open up. However, the walls are lined with a purplish, wavy sort of plant. It lines the outsides of the small passage, making only a small center passage through it.
Shadow yanks out a sword and stabs through that center to test it.
Shadow stabs the clear center! Nothing happens in it, though the purplish strands of plants crackle and flash white when the blade comes close.
ooc: don't drown, Shadow! Varian doesn't want to have to apply mouth-to-mouth!
Shadow tries cutting the purple stuff nearby, since he noticed it reacted to the blade, trying to hack a bit of a path.
Shadow hacks at the purplish seaweed! It's fairly tough, flashing white as his blade touches it! A bit is cut off to no ill effect, falling down and crumbling away on the slicing!
Shadow hurries on past it, trying not to touch any of it as he went on to the passage.
