Indexes
Started by Corwin, July 14, 2010, 03:23:18 PM
So I've been thinking that it might help to keep track of things, given threads of 66+ pages. I'll do the loot one now, and reserve a couple more. Feel free to suggest other stuff to index either from existing threads that I've overlooked, or new threads.
Loot index
Gamestart:
http://www.soulriders.net/forum/index.php?topic=100062.0
Uatu ruins:
http://www.soulriders.net/forum/index.php?topic=100062.120
Kondrux's hoard:
http://www.soulriders.net/forum/index.php?topic=100062.150
Balmuria ruins, fifth resort section:
http://www.soulriders.net/forum/index.php?topic=100062.195
Lagann:
http://www.soulriders.net/forum/index.php?topic=100062.msg1006669#msg1006669
Irenes's fortress in the Wastes:
http://www.soulriders.net/forum/index.php?topic=100062.285
Ferdi:
http://www.soulriders.net/forum/index.php?topic=100062.msg1007947#msg1007947
Desert fiefdoms devil invasion:
http://www.soulriders.net/forum/index.php?topic=100062.msg1008265#msg1008265
More Balmuria ruins:
http://www.soulriders.net/forum/index.php?topic=100062.390
Silver dragon in Pallanth:
http://www.soulriders.net/forum/index.php?topic=100062.435
David in Kelara:
http://www.soulriders.net/forum/index.php?topic=100062.msg1010227#msg1010227
Pyroclastic dragon scales:
http://www.soulriders.net/forum/index.php?topic=100062.msg1010894#msg1010894
Kesse's nobles and Tura (Inevitable):
http://www.soulriders.net/forum/index.php?topic=100062.510
Helm's hidden temple in the desert:
http://www.soulriders.net/forum/index.php?topic=100062.msg1011717#msg1011717
http://www.soulriders.net/forum/index.php?topic=100062.msg1011874#msg1011874
Pallanth, darts of Arcane Fire:
http://www.soulriders.net/forum/index.php?topic=100062.msg1011886#msg1011886
Jungle ruins:
http://www.soulriders.net/forum/index.php?topic=100062.msg1012120#msg1012120
Tablet of Armageddon:
http://www.soulriders.net/forum/index.php?topic=100062.msg1012155#msg1012155
Esthan:
http://www.soulriders.net/forum/index.php?topic=100062.msg1012200#msg1012200
Taldeer's NEWT potions class:
http://www.soulriders.net/forum/index.php?topic=100062.msg1012222#msg1012222
The (reworked) Third Resort:
http://www.soulriders.net/forum/index.php?topic=100062.msg1012225#msg1012225
Dark Six attack on Prime and Dark Six fortess on Prime:
http://www.soulriders.net/forum/index.php?topic=100062.780
Lumenvolo:
http://www.soulriders.net/forum/index.php?topic=100062.msg1013240#msg1013240
Abyss:
http://www.soulriders.net/forum/index.php?topic=100062.msg1013363#msg1013363
Deme's items:
http://www.soulriders.net/forum/index.php?topic=100062.msg1013528#msg1013528
Kesse #2, the DiploQuest:
http://www.soulriders.net/forum/index.php?topic=100062.msg1013770#msg1013770
Gerelethen:
http://www.soulriders.net/forum/index.php?topic=100062.msg1013881#msg1013881
Astral fortress:
http://www.soulriders.net/forum/index.php?topic=100062.msg1014516#msg1014516
Anti-Agares Avernus crusade:
http://www.soulriders.net/forum/index.php?topic=100062.msg1014952#msg1014952
Latha's armors:
http://www.soulriders.net/forum/index.php?topic=100062.msg1015210#msg1015210
#3
Not really sure whether the Library or this is the best place. Anyway, I listed some banned spells I recalled/came across. So this listing would be for altered spells. I'll add more later once I comb the loot/misc thread again.
Raging Flame, lvl1 [SC, p164, only affects nonmagical fires].
Balor Nimbus, lvl2 [SC, p24, level adjusted to lvl3].
Dragonskin, lvl3 [As Dragonskin, but without energy resistance, SC, page 73]
Greater Mirror Image, lvl4 (Change the duration to 1/round level and it's fine. It's a good combat spell but a little better balanced then, PHB2, p121)
Energy Immunity, lvl7 (24hr, SC p80) - I'm of the opinion energy immunity should be in epic. I have no problem with this spell, but not at level 7.  I would approve a level 10 version.
Altered spells:
Freedom of Movement
Abjuration
Level:    Brd 4, Clr 4, Drd 4, Luck 4, Rgr 4
Components:    V, S, M, DF
Casting Time:    1 standard action
Range:    Personal or touch
Target:    You or creature touched
Duration:    10 min./level
Saving Throw:    Will negates (harmless)
Spell Resistance:    Yes (harmless)
This spell enables you or a creature you touch to move and attack normally for the duration of the spell, even under the influence of magic that usually impedes movement, such as paralysis, solid fog, slow, and web. The subject gains a +15 bonus on any grapple check made to resist a grapple attempt, as well as on grapple checks or Escape Artist checks made to escape a grapple or a pin.
The spell also allows the subject to move and attack normally while underwater, even with slashing weapons such as axes and swords or with bludgeoning weapons such as flails, hammers, and maces, provided that the weapon is wielded in the hand rather than hurled. The freedom of movement spell does not, however, allow water breathing.
Material Component
A leather thong, bound around the arm or a similar appendage.
Magic Disjunction
Abjuration
Level: Magic 9, Sor/Wiz 9, Clr 9, Drd 9
Components: V
Area: All magical effects and magic items within a 40-ft.-radius burst
Duration: Instantaneous
Spell Resistance: No
All magical effects and magic items within the radius of the spell, except for those that you carry or touch, are treated as being affected as by a targeted dispel attempt. The dispel check uses a modifier equal to your caster level, maximum+30.
You also have a 1% chance per caster level of destroying an antimagic field. If the antimagic field survives the disjunction, no items within it are dispelled.
Artifacts and divinities are unaffected by mortal magic such as this.
Note: Mage's Disjunction has been changed from RAW. In the event an ability references mage's disjunction working on it, the DM should assign a caster level and allow the dispel check to work as normal.
#4
Banned SRD spells:
Polymorph
Baleful Polymorph
Circle of Death
Undeath to Death
Finger of Death
Symbol of Death
Polymorph Any Object
Power Word: Kill
Wail of the Banshee
Banned non-SRD spells:
Scintillating Scales
Serene Visage
Celerity (+Lesser/Greater variants)
Make Manifest
Battle Hymn
Thunderlance
Wraithstrike
Sound Lance
*In general, the Polymorph subschool has been restricted.
