The hunt for companionship (Calleigh)
Started by Anastasia, August 30, 2016, 03:44:42 PM
'So we need to prioritize countermeasures or learning how he does it, so that we may do the same.'
"Yes," Mirajane nods, "That would align well with your current goal as well, wouldn't it?"
'It would, yes. Have any suggestions?'
"Moore's been dealing with destiny, he's a good place to start," Mirajane asks, "On a related subject, what did you find out about paragons?"
'Not much. Lathander stated that paragons at their core are the pinnacle of what their race represents. We must become children of destiny. No ideas on how, though.'
"What does your race represent, then?" Mirajane asks, leading you through a portal to the officer's quarters. It's quieter here, no one immediately about.
'Very little, really. The irrigo, as a race, barely exist.'
You slip past several rooms, until you come into one that seems unused. Mirajane closes the door behind all of you.
"That's the problem then, isn't it? The irrigo are a forgotten memory. What destiny do they have? They've been left behind in the sands of time." Mirajane says, "What destiny could be wrought from a race like that?"
'That's true. I've not seen another of my kind since our Prime was...well. Since the irrigo ascended and a very few of us elected to remain behind. Our destiny was likely "to ascend," and once that was met, the rest of us were left without a direction.'
"Then you need to choose a new direction, one that represents your entire race or what's left of it." Mirajane says. "That's what I think, anyway. Otherwise, however will your race's destiny matter at all?"
A moment of silence, then: 'Yes...yes I believe that is what I will have to do. If the irrigo no longer have a destiny, then I will have to forge one myself.'
Mirajane nods, "We can't escape destiny, so we need to use it to our benefit. Then, what will you try and make as the irrigo's new destiny?"
'That's...an excellent question. Can it be simple? Must it be complex and vague?'
"I don't have the foggiest," Mirajane admits, looking away momentarily. "I believe you should start with simple, however, and see from there."
'Very well. My destiny is to cross this room.' Tryll says, crossing the room.
