Mending RAW only repairs breaks and tears, not this sort of damage. However I feel this is reasonable so I'll allow it.
The scroll reads as follows.
Prepare for the red path to be traveled. Ensure that the way is prepared for Hiwa and Hiya, for they will come to smite the enemy by command of destiny. Defend the way and retreat to the Water Keep if you must, the password is baleful awakening.
'Tepen. We have found a scroll with information that may be relevant. It reads as follows: Prepare for the red path to be traveled. Ensure that the way is prepared for Hiwa and Hiya, for they will come to smite the enemy by command of destiny. Defend the way and retreat to the Water Keep if you must, the password is baleful awakening.' Tryll shares. 'Please disburse information as needed.'
'Understood,' Tepen replies, 'Please be advised that Hiya and Hiwa are high priority targets of extreme strength. Only officers should engage them.'
To Tepen, Surraruthru sends, 'What do we know about Hiya and Hiwa? What should we watch for?'
To his force, he sends, 'Let's keep moving. We need to secure these tunnels so we can go top-side and help.'
'They're children of Semyaza and a sorceress, exceedingly powerful tyrants. Repeat, do not let the common troops engage them,' Tepen replies.
Surraruthru passes this to the underground troops, with orders to fall back and report only if they see anything that might be these two, and continues through the tunnels, searching.
> roll 1d100
<Rei-chan> Koaway rolled : 1d100 --> [ 1d100=48 ]{48}
Your army continues on. As you go past the grate, your scout courre quickly come flying back, "TIDAL WAVE!" they cry, "INCOMING!"
Tryll crafts a wall of ectoplasm in the tunnel ahead of the group!
Tryll
HP: 246/246
AC: 47
Touch AC: 30
Flatfooted AC: 39
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 26), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 25), Create Magic Tattoo (+1 luck bonus to attack rolls, CL 26), Create Magic Tattoo (+2 competence bonus to attack rolls, CL 26), Energy Absorption (CL 26), Elemental Body (CL 26), Surraruthru's Stupendous Dragonskin, (+10 armor bonus & DR 10/magic CL 26), Agility of the Dragon Princess (+4 insight to dexterity, CL 26), Strength of the Dragon Princess (+4 insight to strength, CL 26), Mind of the Dragon Princess (+4 insight to intelligence, CL 26), Stoneskin (DR 10/adamantine, CL 26), Spell Turning (CL 26), True Seeing (CL 26)
PP: 605
Spells Expended: Mending
Calleigh
HP: 123/123
AC: 49
Touch AC: 27
Flatfooted AC: 36
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 26), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Create Magic Tattoo (+1 luck bonus to attack rolls, CL 26), Create Magic Tattoo (+2 competence bonus to attack rolls, CL 26), Energy Absorption (CL 26), Elemental Body (CL 26), Surraruthru's Stupendous Dragonskin, (+10 armor bonus & DR 10/magic CL 26), Agility of the Dragon Princess (+4 insight to dexterity, CL 26), Strength of the Dragon Princess (+4 insight to strength, CL 26), Mind of the Dragon Princess (+4 insight to intelligence, CL 26), Stoneskin (DR 10/adamantine, CL 26), Spell Turning (CL 26), True Seeing (CL 26)
Psicrystal
HP: 123/123
AC: 31
Touch AC: 14
Flatfooted AC: 29
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 25), True Seeing (CL 26)
"Everyone take cover or into the ground, water elementals try to control it, Earth elementals be ready to make another wall or divert it if it fails!"
Surraruthru braces behind the Ectoplasm wall.
Wall of Ectoplasm. Same as it says on the box.
Orders are followed and the wall of ectoplasm goes up.
"It doesn't listen," One of the water elementals cries as it comes into view. A massive surge of water, filling the entire tunnel, "Magic is controlling it." It's coming towards the wall of ectoplasm fast.
You have a chance for any further actions if you want, it's coming fast but you know it's coming.
Can I get a spellcraft check to get a guess at spell level for a dispel?
Sure, but that will take up your action here, so someone else would need to dispel.
Bah.
Surraruthru calls on his magic, beginning to cast is magical might against the oncoming wave!
Dispel Magic, Greater, CL 31, CL goes up +1/+2 vs. Evil/Subtype. No Save/SR.
> roll 1d20+20 Dispel
<Rei-chan> Iddy rolled : 1d20+20 Dispel --> [ 1d20=17 ]{37}
