The tidal wave sputters out and breaks apart. A lot of water comes your way, but it's disorganized now, just a gush. Much of it goes backwards as well, and what does hits your wall of ectoplasm. It holds, a few droplets getting through but nothing serious. Slowly the water level drops ahead, a quiet cheer going up from the courre.
'They had the same idea as us, at least on a basic level. But if they're flooding the tunnels, then they're getting desperate. It would restrict their own mobility. Let's keep pushing. Scouts, excellent job.'
"Put the water elementals up front, so we can keep a line if we're hit. They won't drown and can probably hold their place, loves," Bubbles says.
Surraruthru keeps going, ordering the shuffle in lines that Bubbles suggested with a nod to her for the suggestion.
Easy enough to do and you barely et 100ft before the courre come running back, "Another wave!"
Surraruthru takes cover behind the wall, deciding that expending more magic on this type of tactic may not be the wisest choice; he needs to save some dispels for when they find whatever is doing it after all.
As it happens, there is a distant but loud thunderclap, then another. It's enough to shake the wave a good deal, some of it coming apart from the boom.
"What was THAT?!" Bubbles looks around as many soldiers do the same. "Elementals, worry about getting a second wall up!" she cals.
'Well, it was either very good or very bad. Until Tepen tells us otherwise, we keeping going, however. Courre, some of you fall back to watch the rear. Whatever that was, we don't want it catching us from behind.'
Surraruthru
HP: 347/347, Speed: 100 ft, 140 ft fly, 100 ft swim.
AC: 64 = 38+20(EMA)+4(Deflection)+2(Stat)
Touch AC: 21, Flat Footed: 24, SR: 35, CMB: 29, CMD: 45
Init: +13, Touch Atk: 38, ATK: 38/35/28/23
Active: DR 10/magic, 10/adamantine, +2 Init, +5 ATK, +2 AC, Resistance 10 Acid/Cold/Elec/Sonic, Immunity to poison/sleep/paralysis/stunning/crits/flanking, +1 ATK in water, Drench
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Energy Absorption CL 26, Elemental Body: Water CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Mind Blank CL 26, Stoneskin CL 26 (260 min), Spell Turning CL 26 (260 min), Moment of Prescience CL 26, Superior Mighty Wallop CL 26, Epic Mage Armor CL 26
Magic Items
Gauntlets of Fell the Greatest Foe: +1d6 damage to target for every size category larger than you it is
Boots of Swift Passage: 20-foot teleportation as a move action 5/day.
Headband of Conscious Effort +15: +15 Competence bonus to Concentration checks, 1/day make a Concentration check in place of Fort save.
Wounding Amulet of Natural Attacks and Adaptation +8: +8 to Natural Attacks (Bite, Claw, Claw), all attacks deal 1 Constitution Damage, immune to all harmful vapors and gases (such as cloudkill and stinking cloud effects, as well as inhaled poisons) and allowing him to breathe, even underwater or in a vacuum.
Meanwhile the remaining water hits the barrier. It holds, slowly starting to level off again. Another wall of ectoplasm, another hold.
'Interesting.' Tryll remarks, examining the area with Detect Psionics. To Tepen, he sends, 'Tepen, did you just hear a short series of very loud thunderclaps?'
'Earth Elementals, a few of you go into the walls and scout ahead. We need a location on whatever is causing these waves. Water Elementals, do you think a few of you could swim through the next wave back to the source to help scout for it?'
Turning to Tryll and Calleigh, Surraruthru sends, 'How much longer can you keep the walls going to counter the waves? Should we have the Earth Elementals take over with walls of stone or something?'
'Longer than it will take to clear these sewers, though I may not be good for much else. We need to find the one creating the floods.'
'Yes,' Tepen sends back to Tryll. 'Hiwa and Hiya have appeared in the skies. For now proceed, more information will be coming shortly.'
Tryll doesn't detect any magic beyond the fading magic around the waves, broken with each one that's stopped.
'If they're out then we'll need to conserve our strength as much as possible. Keep your walls ready, but let the Earth and Mineral Elementals do most of the breaking work with earth and walls.'
