Alright, good news. You don't immediately blow things up. You'll be joining init when I roll it and working on this on your turn. One moment, please.
Abruptly time speeds up and then water rises, Surraruthru and Afina seeing it flood into the fortress. Devils call out in alarm as it does, as meanwhile above, the rest of them hear the shouts and the outbreak of hostilities.
Init everyone.
> roll 1d20+13 Init
<Serith> Iddy roll for Serith < 21 > [d20=8]
<Serith> Yu roll for Serith < 22 > [d20=14] Tryll
<Serith> Yu roll for Serith < 22 > [d20=13] Calleigh
[19:56] <@Ebiris> roll 1d20+32 Afina init, not rolling for dogs as they're just part of the general order of troops for this one and will cover the air above the fortress.
[19:56] <Serith> Ebiris roll for Serith < 44 > [d20=12]
> roll 1d20+5 Dana will come charging on down since she's Dana
<Serith> Space_Cat roll for Serith < 13 > [d20=8]
> roll 1d20+8 Misalea follows to represent elegance and hopefully not dying
<Serith> Space_Cat roll for Serith < 22 > [d20=14]
> roll 1d20+13 Bubbles follows to play healer, since it's safer
<Serith> Space_Cat roll for Serith < 14 > [d20=1]
> roll 1d20+9 devils
<Serith> Space_Cat roll for Serith < 27 > [d20=18]
> roll 1d20+49 ?!?!?!
<Serith> Space_Cat roll for Serith < 65 > [d20=16]
Init is ?!?!?!?! (65) > Afina (44) > Devils (27) > Calleigh = Tryll = Misalea (22) > Surraruthru (21) > Bubbles (14) > Dana (13)
?!?!?!?! does things you can't see. Afina, open.
Hasting herself and Surraruthru, Afina flies straight down and through the breach she created, racing for the centre of the fortress and knifing through the water with ease!
CL 25 haste
Afina: 239/287, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), see invisibility (CL 25), greater heroism (CL 25), interplanar telepathic bond (CL 24), shield (CL 25), magic tattoo (CL 26), magic tattoo (CL 26), energy absorption (CL 26), stupendous dragonskin (CL 26), seira's agility (CL 26), seira's strength (CL 26), seira's mind (CL 26), mind blank (CL 27), stoneskin (CL 26), control weather (CL 27), scalding touch (CL 27, SR 45), shadow form (CL 25), moment of prescience (CL 25), spell turning (CL 26), haste (CL 25)
AC 98, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, 50% miss chance, freedom of movement
Spell charges: 5/0/8/3/1/8/4/4/0/0/0/1
20 uses left on blistering/searing scalding touch
Fenrir: 322/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25)
AC 43, spell resistance 25, freedom of movement, immunity to electricity, exhaustion, mind affecting, fatigue, fear, poison
Garm: 92/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25)
Attack: +39 (2d6+25) +10d6 skirmish, dimensional anchor
Afina is a blur of speed. You go past the busted front line, ignoring the shouts of devils. Ahead you can see it's a smaller building within, door shut firmly as waters start to lap against it. You reach it, having to stop, unless you can go through it directly somehow.
Can you?
I can, I have shadow form to let me pass through walls of force/magical barriers/10 feet of solid material
You blur through the door in a hurry. Within are a few more barbed devils, starting to move, but you blow past them and into the next room, barely seeing them. Rooms are a blur as you move as fast as you can, moving and moving.
You're basically in transit this round, blurring past the enemy and through walls. More on this next round for you. Devils are up.
Outside the devils begin to rally. One hamatula comes forth and hisses, a new wall of force springing up. It partially blocks the hole in the barriers, greatly reducing the flood of water within.
They also have no visible enemy since Surraruthru's hidding and invisible while Afina blurred by. Tryll, you're up.
Meanwhile, Tryll works. He concentrates to the utmost, trying to adjust things carefully. He thinks he's in now, working away diligently.
Spellcraft.
<Serith> Yu roll for Serith < 64 > [d20=1]
REAL glad I went with 10 minutes.
You're working hard - and you hold on, barely. It's hard to even advance, but at least you don't trip it. As you struggle with this...
Misalea.
Misalea charges down below, as...
Surraruthru.
Surraruthru follows after Afina, rushing to get to Tryll to help with the magic and trusting the elemental forces to deal with the devils!
Keeping up invisibility, movement speed is 130 ft normal, 170ft fly, and 100ft swim. Like Afina, I'll move double to get there as fast as I can. Gotta love Monk speed bonus with haste. I can't phase through walls, though.
Surraruthru
HP: 294/347
AC: 68 =38+4+5+6+7+4+4 (Def/Barkskin/GMA/MoP/CV/Shield)
Init: +13, Touch Atk: 37, ATK/Damage: +8, +2 extra attacks (Haste/Slam), +2d6 Holy Damage
Active: Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance +6 Saves (CL20), See Invisibility (CL20), True Seeing (CL20), Death Ward (CL20), Barkskin (CL20), Greater Mage Armor (CL20), Celestial Valor (CL29), Might of the Planetar (CL26), Spell Turning (CL29)
You reach the doors as they open, a pair of hamatula coming out. They don't seem to notice you, but they aren't immediately moving out of the way, either. They're barking orders in Infernal, "Kill them and hold the line!"
Meanwhile Bubbles and Dana race down as well, as Calleigh and Tryll work. 'At last, the fated hour arrives,' A voice presses into Tryll and Calleigh's minds.
Meanwhile again, Afina races along. She can see there's a passage dead ahead with a few doors leading to the sides, as well as a stairway that goes down.
Afina's up, go. Feel free to react as well, Tryll and Calleigh.
'Tepen, we gotta problem! I think we have the Duke here! Someone's talking about fate in my head!' Calleigh sends to everyone.
