Go ahead and go, Tryll. Spellcraft. Make a check as well to help if you're helping, Afina. If you two want to talk more first, go ahead.
[21:44] <@Ebiris> roll 1d20+47 helping spellcraft
[21:44] <Serith> Ebiris roll for Serith < 51 > [d20=4]
<Serith> Mushroom_Cid roll for Serith < 67 > [d20=4]
[21:51] <@Ebiris> roll 1d20+43 listen
[21:52] <Serith> Ebiris roll for Serith < 54 > [d20=11]
<Serith> Mushroom_Cid roll for Serith < 56 > [d20=12]
Both of you are absorbed, just barely holding the work you're doing from disaster. Yet both of you hear a soft crack of stone above, looking up. A large chunk of stone is falling from straight above the orb, plunging at it unnaturally fast.
React you two. You have a single action each, use it wisely and bear in mind you're elbows deep in this work. The more you do, the harder your next check will be.
"I have it," Afina says, casting a simple first level spell to place a floating disk of force above the orb.
Floating disk can bear up 2500lbs
Afina: 239/287, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), see invisibility (CL 25), greater heroism (CL 25), interplanar telepathic bond (CL 24), shield (CL 25), magic tattoo (CL 26), magic tattoo (CL 26), energy absorption (CL 26), stupendous dragonskin (CL 26), seira's agility (CL 26), seira's strength (CL 26), seira's mind (CL 26), mind blank (CL 27), stoneskin (CL 26), control weather (CL 27), scalding touch (CL 27, SR 45), shadow form (CL 25), moment of prescience (CL 25), spell turning (CL 26), haste (CL 25)
AC 98, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, 50% miss chance, freedom of movement
Spell charges: 5/0/7/3/1/8/4/4/0/0/0/1
20 uses left on blistering/searing scalding touch
Fenrir: 322/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25)
AC 43, spell resistance 25, freedom of movement, immunity to electricity, exhaustion, mind affecting, fatigue, fear, poison
Garm: 92/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25)
Attack: +39 (2d6+25) +10d6 skirmish, dimensional anchor
Didn't you use all of your first level spells?
You can use higher level slots on lower level spells.
The floating disc appears and stops it cold, even as Afina has to tear her attention away. Meanwhile...
You're up, Surraruthru.
Surraruthru continues his charge towards Tryll, figuring from his description he's down below, but sending to Tepen and the others, 'Tepen, check in with Bubbles, she might need back up; we're not there to assist her.'
You race ahead, throwing the doors open and finding the other two. Made it!
At this moment we're going to go out of init. Tryll make a Spellcraft check. Afina's magical save bailed you out but stops her aid this round. After this one all three will be alive to go go go and help.
<Serith> Yu roll for Serith < 67 > [d20=4]
You're just barely holding on. Worse it's surging - you're running out of time before a disaster. You need to disarm this and make progress, fast.
