A taste of the southern wind (Jaela, 89 days left)
Started by Anastasia, June 15, 2017, 02:14:42 PM
Okay, where precisely are you three gating to?
#61
I won't bother rolling Heroes's Feast's temp hp since I'm precasting Greater Heroism.
Anyways!
We're all gating 1000ft above the main fortress, and those who cannot fly innately will have Fly or Overland Flight precast upon them (CL26).
Groups to attack the four towers of the main fortress complex: Candy and the Master, Mom and Ram, Mirajane and Finnegan, Ebony and Dana.
NPCs coming with us: 27.
Group Spells: Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Heroes's Feast CL20, Mind Blank CL17, Fortunate Fate CL15, Planar Tolerance CL7. Tepen will also cast Interplanar Telepathic Bond between all of us and Tepen (CL26).
Group Short Duration Spells: Recitation CL30, Holy Aura CL27, Mirajane will also cast Celestial Valor on all of us (CL26).
Jaela's Personal Spells: Sign CL30, Conviction CL31, Vision of the Omniscient Eye CL30, Shield of Warding CL31, Invisibility Purge CL30, Crown of Flames CL30, Greater Heroism CL30, Spell Turning CL26, Foresight CL27.
Jaela's Personal Short Duration Spells: Grace CL30, Moonlight Revelation CL30.
Twinned Disintegrate -> Gae Trocaire
#63
All looks good.
edit: Actually she'll haste everyone before we go. Nearly 3 minutes worth so it'll help the NPCs a little.
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 27), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), sublime revelry (CL 31), death ward (CL 30), good hope (CL 30), celestial valor (CL 26), recitation (CL 30), holy aura (CL 27), interplanar telepathic bond (CL 26), haste (CL 27)
defences: AC 101 (touch 65), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, 50% miss chance, freedom of movement
spell slots: 6/9/10/9/9/9/8/8/8/8/7/4/3
Okay, one last call since both you have had 'oh, and let me add this' moments. Post that you're ready and that's final once you do.
Group Spells: Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Heroes's Feast CL20, Mind Blank CL17, Fortunate Fate CL15, Planar Tolerance CL7, Tepen will also cast Interplanar Telepathic Bond between all of us and Tepen (CL26).
Group Short Duration Spells: Recitation CL30, Holy Aura CL27, Haste CL27, Mirajane will also cast Celestial Valor on all of us (CL26).
Fire.
What else can it be but fire.
The air is thick and bitter here with smoke, sooty smoke that rises from the ground itself.
The fortress below is as described, a vast keep of stone and squares, surely crawling with devils below.
"Go," Ebony whispers, "Let us bring justice to them all."
"Stay in touch and advise of any surprises," Afina says as she orients herself towards the larger central fortress and plummets downwards at high speed!
Following suit, Jaela aims to meet the root with Gae Dioltas and make an opening through it, giving Afina the honor of breaking through the next level of the structure a moment later!
Jaela plunges down like a meteorite, clad in the power of the Triune. She shines like one of the lost stars in the sky, come down to wreck vengeance on the devils.
Afina is stealthier, a blurry bolt of speed and rainbows hurtling down at the roof.
27 simply follows, falling more than flying, but keeping up nonetheless.
As you plunge down, you see devils on the battlements, erinyes and common soldiers, barbazu and others spotted. But only in passing as...
This is essentially a surprise round, so go for it.
While Jaela does her part to smash the roof, can I ask if our intel from Bahamut tells us how many floors are between the roof and the inner sanctum?
