A taste of the southern wind (Jaela, 89 days left)
Started by Anastasia, June 15, 2017, 02:14:42 PM
[22:06] <@Annerose> roll 1d20+31+8 can I miss the roof? 20PA
[22:06] <Rei-chan> Annerose rolled : 1d20+31+8 can I miss the roof? 20PA --> [ 1d20=5 ]{44}
[22:08] <@Annerose> roll 16d8+144+160 die, evil roof
[22:08] <Rei-chan> Annerose rolled : 16d8+144+160 die, evil roof --> [ 16d8=84 ]{388}
For the purpose of Hidden Dawn, the default partner is Mirajane.
Hidden Dawn
Golden Bracers (Hidden Dawn): Ranks are unlocked by using them in battles of the appropriate CR or higher. Multiple ranks can be unlocked in a particular battle if it meets the CR requirements and is particularly epic.
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane.
I'm waiting to see what gets revealed by Jaela's strike before acting, in case you're waiting on me Dune
Jaela plunges into the roof like a cometfall, shattering the stone and causing it to collapse. Below is a wide room full of boxes, barrels and supplies. A few humanoid soldiers are here, armored and just beginning to react - or be crushed under debris - as...
Afina, go.
Flitting down into the same space as Jaela, Afina accelerates herself rapidly so she can fire down a flurry of disintegrates, coring through the redoubt to reach the all-important inner sanctum below!
8th level slot for 3 rounds of time stop, disintegrate cast 3 times during time stop and once in normal time
[17:43] <@Ebiris> roll 4#1d20+51 disintegrate spam ranged touch
[17:43] <Rei-chan> Ebiris rolled : 4#1d20+51 disintegrate spam ranged touch --> [ 1d20=10 ]{61}, [ 1d20=19 ]{70}, [ 1d20=15 ]{66}, [ 1d20=20 ]{71}
[17:44] <@Ebiris> roll 1d20+30 init for after surprise round
[17:44] <Rei-chan> Ebiris rolled : 1d20+30 init for after surprise round --> [ 1d20=5 ]{35}
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 27), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), sublime revelry (CL 31), death ward (CL 30), good hope (CL 30), celestial valor (CL 26), recitation (CL 30), holy aura (CL 27), interplanar telepathic bond (CL 26), haste (CL 27)
defences: AC 101 (touch 65), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, 50% miss chance, freedom of movement
spell slots: 6/9/10/9/8/9/8/8/8/8/7/4/3
[19:46] <@Annerose> roll 1d20+15 init
[19:46] <Rei-chan> Annerose rolled : 1d20+15 init --> [ 1d20=9 ]{24}
Actually should be +17, so 26. Might as well get this out of the way~
The third floor opens into a hallway. The second floor opens into the middle of a barracks. The first floor opens into what looks to be some sort of keep, a half dozen cornugons and a single pit fiend below. Beneath that, the last disintegration opens up a path into what looks to be some sort of underground tunnel.
> roll 1d20+7 cornugons
<Rei-chan> Kotono rolled : 1d20+7 cornugons --> [ 1d20=18 ]{25}
> roll 1d20+12 pit fiend
<Rei-chan> Kotono rolled : 1d20+12 pit fiend --> [ 1d20=9 ]{21}
> roll 1d20+11 27
<Rei-chan> Kotono rolled : 1d20+11 7 --> [ 1d20=8 ]{19}
Init is Afina (35) > Cornugons (25) > Jaela (24) > Pit fiend (21) > 27 (19)
Go Afina.
Reminder that my init is 26 and I go after Afina~
'Jaela, move away from the hole we just made. You're going to need the cover in a second,' Afina warns via telepathically as she gestures down to the underground tunnel. "Burn for Lifasa!" she calls as rock crumbles away to be replaced by searing hot lava!
Searing/Blistering Volcanic Genesis cast (blistering added for free via hat) with benefit of spell enhancer.
The DC against its various effects is 40.
Round 1: 20 foot radius vein of magma appears, anyone in the area has to make a reflex save or fall in where they'll take 20d6+22 fire damage that ignores immunity/resistance per round of exposure.
Additionally black sulpherous gases rise up 30 feet in height and spread through a 290 foot radius. These gases block vision and do 5d6+22 fire damage that ignores resistance/immunity and makes anyone exposed nauseated. A fortitude save halves the damage and reduces the condition to sickened.
[18:22] <@Ebiris> roll 20d6+22 damage if anyone falls in
[18:22] <Rei-chan> Ebiris rolled : 20d6+22 damage if anyone falls in --> [ 20d6=81 ]{103}
[18:22] <@Ebiris> roll 5d6+22 damage from spreading gases
[18:22] <Rei-chan> Ebiris rolled : 5d6+22 damage from spreading gases --> [ 5d6=25 ]{47}
Anyone that takes damage from this will also take a -2 penalty on attack rolls for one round
As her volcano takes shape she then darts thirty foot to the left, so the fortress itself will provide her with cover against the violently ejected rocks that will be coming in a few seconds.
Afina 329+20/329
spell slots: 6/9/10/9/7/9/8/8/8/8/7/4/2
1 of 29 rounds for volcanic genesis
> roll 1d20+16 cornugons
<Rei-chan> Kotono rolled : 1d20+16 cornugons --> [ 1d20=1 ]{17}
> roll 1d20+19 pit fiend
<Rei-chan> Kotono rolled : 1d20+19 pit fiend --> [ 1d20=6 ]{25}
Fire and gas fill up the room below as a newborn volcano begins to erupt, searing lava and choking gases spreading everywhere as...
Jaela.
Jaela can't quite walk away from this, and devils teleport anyway-- wait, they can't teleport here! Aiming Gae Dioltas at the devils she can see below, Jaela adds her own cry to Afina's! "Die, bitches!"
[20:40] <@Annerose> roll 1d20+35+8 ranged touch
[20:40] <Rei-chan> Annerose rolled : 1d20+35+8 ranged touch --> [ 1d20=18 ]{61}
[20:41] <@Annerose> roll 1d20+30 SR
[20:41] <Rei-chan> Annerose rolled : 1d20+30 SR --> [ 1d20=3 ]{33}
[20:41] <@Annerose> roll 30d12 die just die
[20:41] <Rei-chan> Annerose rolled : 30d12 die just die --> [ 30d12=196 ]{196}
Burst of Glory! On all the devils.
Already wounded by Jaela's fires, the cornugons and pit fiend are struck hard. They burst apart into hunks of obsidian, slaughtered to the last by your overwhelming sneak attack. They don't even have time to defend themselves as...
Free act. Ow.
Moving out of the way due to Afina's warning, Jaela sends to the other groups, 'We're done here. Ready to go?'
'Need more time,' Dana sends back, 'We're just getting started.'
"Back off," Afina says, starting to fly up and away. "The volcano will destroy the entire fortress soon enough, but I have a way of hastening the process. We don't want to be close by for it though."
Flying up several hundred feet and backing off a similar distance, as rumblings and tremors below sound from blasts of molten rock slamming through fortress walls and expanding magma devours the foundations, she conjures forth a giant iceberg in the sky which plummets straight down through the hole they made through the fortress, adding several hundred tons worth of water to the magma where it will react explosively.
Casting Iceberg and dropping it into the volcano to let physics do the rest.
Afina 329+20/329
spell slots: 6/9/10/9/7/9/8/8/8/7/7/4/2
Jaela can't see how an Earthquake would possibly make things worse, and summons one from beneath the doomed fortress as she raises. 'Everyone, pull back to our arrival point.'
