Latha's sunrise (Moore and Tryll; 84 days left)
Started by Anastasia, September 28, 2017, 10:51:07 PM
"Well, sure, I guess. But I didn't get them from Crystalle to just make money." Moore says with a smile. "If I wanted to just go be rich I may as well just go live out the rest of my life in Celestia where everything will be provided for me and I don't have to want for anything ever again."
'No, Moore. Your bargain with Crystalle made this possible. Do not diminish your own part in this. This was a far off dream before you intervened. The amount of adamantine would have cost millions to acquire. Tens or hundreds. Perhaps more. Your efforts should be lauded.' Troll says.
Moore laughs a little bit and smiles. "Don't worry, I know the monetary part of it was a large hurdle. Once this is over and Lifasa is freed, I'll spend some time working to repay Crystalle on the mission he assigned me. Either way, now what? Do you want to try and perform your ritual, or...?"
'The golem must be awakened, though I'd prefer that be done by someone else with more experience. I believe Afina is skilled in this. For now, let's see to the ritual. It's time-consuming enough that it needs to be done as soon as possible.' Tryll replies.
"Elena, can you make sure Afina gets the message to awaken this when she's back?" Moore calls out. "But either way, let's go ahead and prepare for it. How can I help?"
"We can reimburse her for any costs required! Thanks!" Calleigh pipes in.
'There is a broad spectrum of knowledge I will need in order to press through the ritual. Some of them are not my area of focus. I was hoping you could assist me.'
Sounds like Moore is going to help with the knowledge checks and so on for the ritual for Tryll.
Okay, ready for the ritual then? What sorta prep are we talking about?
So how is the ritual laid out? Magic circles, candles, ritual virgin sacrifices, etc.?
Moore will have spells like Greater Improvisation, Share Skills, Biblotecha Arcana and so on pre-cast on himself. They may not all be able to work at all times but he'll want as much of an edge as he can get.
Magic circles, candles, self purifications and reflections, that sort of thing. I'm not planning to get into depth here since we usually don't and it's not critical. Tell me about the checks you know you need to make, so we're on the same page.
Quote- The ritual itself will require several K:A, K:P and Spellcraft checks. Failure results in the ritual failing and the reagents being wasted. The person conducting the ritual does not need to be the person seeking to become a paragon.
Great, thanks. Moore or whomever is doing the checks, I need the following checks.
- 10 K:A checks.
- 8 K:P checks.
- 10 Spellcraft checks.
