Latha's sunrise (Moore and Tryll; 84 days left)
Started by Anastasia, September 28, 2017, 10:51:07 PM
Jesus Christ. Okay, Moore. How do you think we should do this?
#151
I can handle all of them without issue.
In preparatory I cast the following:
Bibliotecha Arcana - +15 insight
Greater Improvisation - +13 luck, I will recast this as necessary (I can cast it 6 times per day, not sure if this ritual takes place over days or hours or what but either way I've got plenty)
Share Talents - Cast on Tryll, gives an untyped +2 bonus
Surge of Hope - Morale bonus. Cast as many times as he needs to, each casting is 27m long. He can also cast this 6 times.
I think it's a bit unreasonable to believe Moore could do any of his Inspire routine while focusing on the checks, so I will leave those off the table.
With all of that said and done, that gives 82 on K:A and K:P and 87 on the Spellcraft checks. This is assuming he can take 10 on them. If this is not the case let me know.
Alright. So.
Does it matter to the ritual if Moore makes the checks and Tryll/Calleigh assist?
Is it possible to do the ritual for both Tryll and Calleigh at the same time?
The checks are too intensive for taking 10, so go ahead and roll them.
Tryll and Calleigh can assist, sure.
For the sake of brevity, we'll assume one ritual for them since they're bonded.
[13:00] <Nephrite> roll 10#1d20+74 K:A
[13:00] <Rei-chan> Nephrite rolled : 10#1d20+74 K:A --> [ 1d20=6 ]{80}, [ 1d20=6 ]{80}, [ 1d20=20 ]{94}, [ 1d20=7 ]{81}, [ 1d20=15 ]{89}, [ 1d20=19 ]{93}, [ 1d20=4 ]{78}, [ 1d20=10 ]{84}, [ 1d20=4 ]{78}, [ 1d20=20 ]{94}
[13:00] <Nephrite> roll 8#1d20+74 K:P
[13:00] <Rei-chan> Nephrite rolled : 8#1d20+74 K:P --> [ 1d20=1 ]{75}, [ 1d20=6 ]{80}, [ 1d20=15 ]{89}, [ 1d20=2 ]{76}, [ 1d20=20 ]{94}, [ 1d20=2 ]{76}, [ 1d20=19 ]{93}, [ 1d20=9 ]{83}
[13:01] <Nephrite> roll 10#1d20+79 Spellcraft
[13:01] <Rei-chan> Nephrite rolled : 10#1d20+79 Spellcraft --> [ 1d20=14 ]{93}, [ 1d20=2 ]{81}, [ 1d20=13 ]{92}, [ 1d20=6 ]{85}, [ 1d20=11 ]{90}, [ 1d20=2 ]{81}, [ 1d20=7 ]{86}, [ 1d20=6 ]{85}, [ 1d20=12 ]{91}, [ 1d20=13 ]{92}
I'd like the following from Calleigh and Tryll, both of them:
- An Intelligence check.
- A Wisdom check.
- A Charisma check.
- A Constitution check.
In that order. If you lack one of those abilities (I think Tryll lacks a Con score), then skip it.
You guys would get +4 to the checks due to Surge of Hope, so good luck!
Tryll
Intelligence[blockquote]Rolled 1d20+15 : 5 + 15, total 20[/blockquote]
Wisdom[blockquote]Rolled 1d20+10 : 9 + 10, total 19[/blockquote]
Charisma[blockquote]Rolled 1d20+11 : 15 + 11, total 26[/blockquote]
Constitution[blockquote]Rolled 1d20+10 : 2 + 10, total 12[/blockquote]
Calleigh
Intelligence[blockquote]Rolled 1d20+7 : 6 + 7, total 13[/blockquote]
Wisdom[blockquote]Rolled 1d20+6 : 13 + 6, total 19[/blockquote]
Charisma[blockquote]Rolled 1d20+8 : 4 + 8, total 12[/blockquote]
Constitution[blockquote]Rolled 1d20+7 : 11 + 7, total 18[/blockquote]
Not your best rolling, no.
Moore, would you also make a Fortitude save?
[13:26] <Nephrite> roll 1d20+59 fort (doublt mettle applies here but you never know)
[13:26] <Rei-chan> Nephrite rolled : 1d20+59 fort (doublt mettle applies here but you never know) --> [ 1d20=18 ]{77}
Okay, interesting. Make a Fortitude save as well, Calleigh and Tryll. +2 circumstance bonus.
