Eternal Warfare (Moore)
Started by Anastasia, January 08, 2018, 10:24:08 PM
Okay, you're going out under Gisfal's command. Any preparations or spells to cast before you all scramble out? You're on a tight timetable here since Hell's attacking, so bear that in mind.
Arch (although that may be assumed) Righteous Halo and Greater Improvisation are the ones he'd want to get off before going anywhere, in that order.
Chaos.
Forces are racing out, mobilizing.
Flashes of faces, of weapons raises as their wielders rush out to battle.
Gisfal besides you quickly, "I want you boosting as many warriors as much as you can," he says, right to the point. "Hurry!"
I don't know what sort of Initiative we're working with here, so I'll just list the things he can do and the order he does them in and you can take it from there.
Round 1:
Standard: Carrying Voice (increases the radius people can hear him to 500 ft)
Swift: Inspirational Boost (increases Inspire Courage bonus by +1, morale)
Round 2:
Standard: Harmonize (Starting bardic music requires move action)
Immediate: Use Belt, increases the bonus of inspire courage by 2, non-typed
Move action: Words of Creation Inspire Courage
[blockquote]Rolled 3d4 : 4, 2, 2, total 8[/blockquote]
Any Fey who hear it get +2 to the bonus on top of everything else. With the +3 bonus, this goes up to 19 for anyone and 21 for fey. This affects anyone in a 500 ft radius of Moore.
In addition, anyone in his radius gets a +16 bonus to Initiative in case we end up needing to use that here or what have you.
I will leave it at two rounds for right now and we can take it from there.
I'd presume you're positioning yourself in the general middle of the forces so your voice covers as much as possible, or do you have something else in mind?
No, you are correct. Note to self, create Greater Carrying Voice with a larger effect radius after this.
I think I said I was going to and then never did.
You sing. You call. You inspire.
Your words echo amid the battlefield, inspiring more. Soldiers surge, even as you barely notice arrows raining down on you.
What's your AC and such right now, before I get to rolling any thing that matters about it?
AC appears to be 72, with immunity to crits and 20% miss chance for your reference. Still working on the statblock but that lets you get started.
Moore will cast Greater Mirror Images in response to anything more serious than a few arrows, like actual devils trying to attack him.
> roll 1d20 this is a 20 check
<Rei-chan> Kotono rolled : 1d20 this is a 20 check --> [ 1d20=4 ]{4}
<Rei-chan> Kotono rolled : 1d20 this is a 20 check --> [ 1d20=15 ]{15}
<Rei-chan> Kotono rolled : 1d20 this is a 20 check --> [ 1d20=14 ]{14}
Will narrate this all out when it's all done. For now, make a pair of Reflex saves.
[13:50] <Nephrite> roll 2#1d20+54
[13:50] <Rei-chan> Nephrite rolled : 2#1d20+54 --> [ 1d20=9 ]{63}, [ 1d20=8 ]{62}
Evasion and such.
Statblock
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 24), True Seeing (CL10), Bibliotecha Arcana (CL27), Tapestry Buffs
HP: (8)417/417+20
AC: 62(72), 46 (56) touch, 52 (62) flatfooted 20% miss chance, SR 41, 30 resist all to elements
31/32 Bardic music uses 3/3 Refrain
Saves: Fort +36(48), Ref +40(54), Will +41(51) (+6 due to Superior Resistance)
Stats: STR 18(22) (+6) DEX 31(35) (+12) CON 26(30) (+10) INT 32(36) (+13) WIS 22 (+6) CHA 35(43) (+16)
Spells:
0th - 4/4 (DC 22)
1st - 6/7
2nd - 6/7
3rd - 6/7
4th - 7/7
5th - 6/6
6th - 6/6
7th - 5/6
8th - 5/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 8/8
7th - 6/6
8th - 3/4
Surru's Tapestry Buffs
Elemental Body (fire) CL 28, 28 hour duration,
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Endurance of the Dragon Princess, CL 28, 28 hour duration
Beauty of the Dragon Princess, CL 28, 28 hour duration
Create Magic Tattoo, CL 24, 24 hour duration (+1 luck bonus to attack)
Create Magic Tattoo, CL 24, 24 hour duration (+2 morale bonus to attack)
Create Magic Tattoo, CL 24, 24 hour duration (+1 caster level)
Energy Immunity (x4) CL 26, 24 hour duration (Grants complete protection agianst: acid, cold, electricity, sonic)
Evacuation Rune, CL 25, 24 hour duration.
[/spoiler]
Moore dodges.
It's all he can do as arrows rain down on him. He dodges bursts of black fire and red lightning, untouched as allies go down. He puts it all into his performance, safe within the lines for now. His part of the line is doing well, better, pushing the devils back and holding it as others are checked.
A flash - seeing Gisfal leading a charge against a looming pit fiend with a lance of flame atop a vast nightmare - echos across Moore's vision. Overall he can see the line is doing well, but only those within his hearing. At the head of it is Gisfal, facing his opponent.
What do you do?
#14
The best he can do is sing -- bolster the ability of those who can hear him. Erathaol, we could use the wisdom of Celestia right about now!
He raises his voice -- somehow, as he continues to ensure his allies see victory this day.
Destined Strike, this gives everyone who can hear him +3 to attack and weapon damage rolls, Improved Crit Feat and +16 to threat confirmations.
He's also going to try and Wall of Stone off an area of devils to just stop them from advancing on Gisfal's flank while he's dealing with the pit fiend. He has 140 ft to work with, so a thicker but shorter wall is what he'd go for. He's not concerned about flying units since a wall wouldn't stop them anyway.
