Eternal Warfare (Moore)
Started by Anastasia, January 08, 2018, 10:24:08 PM
"FORWARD!" Gisfal shouts, voice booming over the battlefield. The devils are pushed back by the fall of their leader, as...
> roll 1d20+52 (+6 Moore stuff) Gisfal
<Rei-chan> Kotono rolled : 1d20+52 (+6 Moore stuff) Gisfal --> [ 1d20=20 ]{72}
> roll 1d20+40 (-4 dead leader)
<Rei-chan> Kotono rolled : 1d20+40 (-4 dead leader) --> [ 1d20=12 ]{52}
> roll 1d100
<Rei-chan> Kotono rolled : 1d100 --> [ 1d100=74 ]{74}
With this chance the forces surge forward, attacking this part of the battle, trying to thrust in and collapse this segment of the devils.
Your call on what you're doing here.
Moore will resume his post singing, but this time will stay close to Gisfal -- the soldiers in the back may not be able to hear him, but if needs be he can relocate.
He will restart Inspire Courage-ing and move along with Gisfal.
[blockquote]Rolled 3d4 : 1, 2, 4, total 7[/blockquote] nonlethal
[11:46] <Nephrite> roll 1d20+51+13
[11:46] <Rei-chan> Nephrite rolled : 1d20+51+13 --> [ 1d20=2 ]{66}
Using 13/84 luck points.
Four Reflex saves, two Fortitude saves and one Will save.
[13:03] <Nephrite> roll 4#1d20+54 evasion
[13:03] <Rei-chan> Nephrite rolled : 4#1d20+54 evasion --> [ 1d20=5 ]{59}, [ 1d20=3 ]{57}, [ 1d20=15 ]{69}, [ 1d20=14 ]{68}
[13:04] <Nephrite> roll 2#1d20+48 mettle, +2 against evil outsiders
[13:04] <Rei-chan> Nephrite rolled : 2#1d20+48 mettle, +2 against evil outsiders --> [ 1d20=18 ]{66}, [ 1d20=16 ]{64}
[13:04] <Nephrite> roll 1d20+54 will, mettle
[13:04] <Rei-chan> Nephrite rolled : 1d20+54 will, mettle --> [ 1d20=19 ]{73}
War is chaos and is it true.
You dodge fireballs, duck lightning, endure cones of cold. Magic beats against you all over, wild and uncontrolled. Yet your blessings and speed serve you well, not a one injuring you. Gisfal leads his charge and...
> roll 1d20+52 (+6 Moore) Gisfal
<Rei-chan> Kotono rolled : 1d20+52 (+6 Moore) Gisfal --> [ 1d20=18 ]{70}
> roll 1d20+42 (-2 only because secondary leader has taken command)
<Rei-chan> Kotono rolled : 1d20+42 (-2 only because secondary leader has taken command) --> [ 1d20=15 ]{57}
> roll 1d100
<Rei-chan> Kotono rolled : 1d100 --> [ 1d100=36 ]{36}
> roll 1d20+38 master
<Rei-chan> Kotono rolled : 1d20+38 master --> [ 1d20=12 ]{50}
It's working. It's a sharp battle everyone, but Hell is being checked. Some of the portals are shut down, slowed, disrupted. Others open yet momentum is on Aurora's side - at least for now. You're watching soldiers go, some falling around you, dead or wounded, replacements hurrying in.
A chance if you want to heal or do anything to help with this.
Moore will activate the gift he received from Chauntea and use the ioun stone to mass heal everyone he can reach!
It's a CL 20 Mass Heal, he'll target the largest cluster and then expand as far as he can make it go for 200 HP.
This isn't it, though, is it? Bel and Taelfagn are hiding somewhere, waiting, plotting, scheming...
Healing spreads through the troops as...
Can you see invisible in any way?
I do, in fact, have an always-on True Seeing!
There is a shimmer near you as an unseen figure appears - a dogai, clearly unhidden to your eyes. It's coming at you and...!
Init.
[13:38] <Nephrite> roll 1d20+44 init
[13:38] <Rei-chan> Nephrite rolled : 1d20+44 init --> [ 1d20=2 ]{46}
If Gisfal gets included he gets +16 to his
"Dogai!" Moore calls out.
And with that, he reveals it for all the allies around to deal with - and any others that might be nearby!
Invisibility Purge, 85ft globe. Try again, assassin!
Surrounded and exposed, the dogai takes his one chance and lunges at you, as soldiers turn around and...
> roll 1d20+42
<Rei-chan> Kotono rolled : 1d20+42 --> [ 1d20=6 ]{48}
The blow misses and then soldiers all around him attack, the dogai surrounded and...
Chance to contribute to this.
