Eternal Warfare (Moore)
Started by Anastasia, January 08, 2018, 10:24:08 PM
They've all got Inspire Courage, I have faith they'll kick his ass without me doing anything else. Although...
"You really should've learned when we killed your paragon back on Benfal!" Moore shouts. "Leave this plane and never return!"
> roll 1d20+45 Rei
<Rei-chan> Kotono rolled : 1d20+45 Rei --> [ 1d20=17 ]{62}
> roll 20d8+100 Rei
<Rei-chan> Kotono rolled : 20d8+100 Rei --> [ 20d8=85 ]{185}
The dogai is assaulted, beaten and dogpiled. It's bloodied badly before it manages to vanish, sliced nearly to ribbons before teleportation allows it to escape.
"TOGETHER," Gisfal shouts, "MOORE, ABOVE!" Gisfal gestures with his blade, before leading his soldiers on the ground.
Moore takes to the sky over the soldiers to follow along with Gisfal's charge!
Moore will cast Foresight while all of this is going on, just to be safe.
Above you see it - celestials and mounted warriors battling winged devils. Great battles above - and you see Aurora is being pushed here, challenged hard, starting to crack.
His voice should still reach them -- the best he can do is empower them to try and give them an edge! The light of hope is with you!
If he thinks he could reach a majority of the allies from where he is (he has 500 ft to work with) he'll sing from here. Otherwise he'll Dimension Door up to get closer to them in order to do so.
[14:30] <Nephrite> roll 3d4 nonlethal
[14:30] <Rei-chan> Nephrite rolled : 3d4 nonlethal --> [ 3d4=9 ]{9}
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 24), True Seeing (CL10), Bibliotecha Arcana (CL27), Tapestry Buffs
HP: (24)417/417+20
AC: 62(72), 46 (56) touch, 52 (62) flatfooted 20% miss chance, SR 41, 30 resist all to elements
27/32 Bardic music uses 3/3 Refrain
Saves: Fort +36(48), Ref +40(54), Will +41(51) (+6 due to Superior Resistance)
Stats: STR 18(22) (+6) DEX 31(35) (+12) CON 26(30) (+10) INT 32(36) (+13) WIS 22 (+6) CHA 35(43) (+16)
Spells:
0th - 4/4 (DC 22)
1st - 6/7
2nd - 6/7
3rd - 6/7
4th - 7/7
5th - 6/6
6th - 6/6
7th - 5/6
8th - 4/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 7/8
5th - 8/8
6th - 7/8
7th - 6/6
8th - 3/4
Surru's Tapestry Buffs
Elemental Body (fire) CL 28, 28 hour duration,
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Endurance of the Dragon Princess, CL 28, 28 hour duration
Beauty of the Dragon Princess, CL 28, 28 hour duration
Create Magic Tattoo, CL 24, 24 hour duration (+1 luck bonus to attack)
Create Magic Tattoo, CL 24, 24 hour duration (+2 morale bonus to attack)
Create Magic Tattoo, CL 24, 24 hour duration (+1 caster level)
Energy Immunity (x4) CL 26, 24 hour duration (Grants complete protection agianst: acid, cold, electricity, sonic)
Evacuation Rune, CL 25, 24 hour duration.
[/spoiler]
DD it is. Mark the usage.
Fireballs streak through the air.
You speak.
A cornugon and an astral deva wrestle in the air, locked in deadly combat. As you speak, the deva throws the cornugon aside, summoning mace to hand. In a massive blow, the cornugon's skull is crushed, the devil slain.
You sing.
Spinagons swarm a wounded griffon rider - and as you sing, it rallies and breaks out, managing a fighting retreat at the last moment.
You pour your heart into every word.
Slowly, the forces in the sky begin to rally - but you see it. The sky cracks into bands of color - red, white, blue, green and black. Like tendrils they reach across the dying sky, as a vast roar echos about the battlefield, so loud as to...
Fortitude save vs stunning, Moore.
[14:43] <Nephrite> roll 1d20+48 mettle
[14:43] <Rei-chan> Nephrite rolled : 1d20+48 mettle --> [ 1d20=15 ]{63}
I should just include the +2 on every roll by default since what the heck else is any of this going to be at this point?
You endure while countless others - devils and heroes alike - reel back or fall. From the cracking sky it appears - a vast, five headed wyrm that blocks out the sky with its immense body. Five heads - white, red, blue, black and green, each roaring loud enough to crack the ground and shatter mountains.
Only Moore's magic saves him. Your shielded mind refuses to quail in horror at the impossible dragon that shadows an entire world. Its heads are rearing back, as if to breath down upon Lifasa itself.
Chance to react, knowledge check or whatever. K:R, Moore.
Take 10 for 64 to verify that for whatever the fuck reason Tiamat just appeared on our doorstep.
You know this and this manifestation. Above Aurora is an avatar is Tiamat, the World Destroyer. A dragon so vast as to take a world in her talons and shred it as a cat may shred a mouse. This avatar is made for war against entire worlds and planes, a manifestation of Tiamat's power and hatred.
Okay, really?! Really?! This is really starting to get absurd now!
Moore can't do anything except frown and manage to call out to the allies around him - thankfully, his voice carries far enough to be heard. "Everyone, back down to Gisfal! Let's regroup and wait to see what's going to come up this!" He shouts. There's no reason to fall to despair now -- their allies won't simply let this go and force them to deal with it by themselves.
Retreating back with them, Moore?
Yes, he'll fall back with them to Gisfal.
"BACK! BACK! HOLD!" Gisfal is screaming to hold his troops, as the devils recover faster, ready. They start to press in the wake of the terror in the sky, "ALL OFFICERS HOLD THE LINES!"
The forces are gathering perhaps 100ft from the ground, regrouping - those who haven't hit the ground or worse. It's a mess right now, Tiamat's entry shifting the battlefield further, pressing Aurora harshly.
What do you do?
This is what he's made for -- to not allow others to fail. Their allies are coming -- he can't show even a hint of cowardice.
He simply raises his voice to give his allies the bolster they need to hold on!
Redoing Inspire Courage fresh for everyone in the radius.
[15:07] <Nephrite> roll 3d4 nonlethal
[15:07] <Rei-chan> Nephrite rolled : 3d4 nonlethal --> [ 3d4=5 ]{5}
