Tomb Vs Animeverse, Act 3 (Recovered)
Started by Dracos, March 07, 2003, 09:29:34 PM
kpjam
Alita moved back about twenty feet and took a kneeling position.
"Anytime," she said.
She then turned her head, looking at the corridor behind them for any movement.  Assuming there's no movement behind her, she'll keep facing that way until she hear Mercury cry out or she hears firing.
Figment
Moving back six feet, Huiztil positioned himself on the right side of the corridor, and placed a forcefield over the door.
"I will hold the door while you move into position Bio-unit Mercury."
The Gargoyle roars and stalks across the room.
Fearless Leader
thepanda
Mercury dropped the shield and activated her flight ability, moving toward the ceiling and away from the door. She scanned with the mercury computer to try to find a weak point to strike at the monstrosity while preparing a freezing Shine Aqua Illusion.
The Mercury computer did not detect any noticable weakpoints in the creature.
Fearless leader
Recca rushed backwards, as he summoned Nadare, stopping once his back was almost against the sidewall in the main corridor. As the fireballs came into being, he merged them into one large fireball, ready to launch it across the side corridor he'd just exit from once everyone was clear.
kpjam
Seeing Recca's fireball, Alita moved out of the side corridor and out from inbetween her and fire and into the first room again.  She had already experienced enough fire in this campaign.
thepanda
Mercury almost cursed. There didn't appear to be any easily exploitable weakness to the creature.
"I'll try to freeze it in place," She called out to the others. "Recca should follow that up with a concentrated fire ball. Try to immobilize it. Take out the legs or head. Huitzil and Alita should be able to finish it off from there."
Mercury will wait until the gargoyle tries to enter and release her freezing Shine Aqua Illusion. She'll try to freeze it in the doorway.
Stalks up to the doorway before leaping up, disappearing from view.
Fearless Leader
thepanda
"Huitzil, can you see the gargoyle from where you are? Has it returned to its starting position?" Mercury called out.
Figment
Huitzil used his x-ray scanners, looking to see if he could detect where the creature was.
The x-ray scanners returned that the gargoyle was moving up along the wall back towards the roof.
Fearless Leader
Figment
"It is moving up the wall towards the ceiling."
Recca blinked at the robot's commentary. As he let the giant fireball dissipate into nothingness, he scratched his head and said. "Well, that was kinda... anticlimatic. Now what?"
thepanda
"The trap appears to be a limited to the room," Mercury said, floating gently to the ground. "I'm not sure what the mechanism for activation is, however. Probably motion activated. We also don't know whether it just moves along its programmed path, though I seriously doubt that to be the case. Huitzil, we'll need another body. Oh, and tell Alita to come back while you're at it."
