Tomb Vs Animeverse, Act 3 (Recovered)
Started by Dracos, March 07, 2003, 09:29:34 PM
Figment
Huitzil deactivated his forcefield, and waited for a moment while he monitored the creature's movement.
"I just realized, but it might not be motion activated," Recca said after Mercury spoke. He was surprised he hadn't thought of it earlier, what with his abilities, but it couldn't be helped.
"The body Huitzil threw in was dead, but it should still be warm right? The gargoyle might be activated by heat sensors, not motion sensors. Actually, it might be both in the end."
The creature came to a stop in the position he'd formerly scanned it in.
Fearless Leader
Figment
"The creature has returned to it's previous position."
thepanda
"Just as I surmised," Mercury commented. "Where there any other bodies left Huitzil?"
Figment
"Yes."
Huitzil walked back into the larger room and picked up on the few remaining bodies before returning to where Mercury waited.
kpjam
Alita, seeing Huitzil return and pick up bodies, followed him until she sat along stride Recca.
Turnig to him, she asked, "What happened to BIG FIRE?"
thepanda
Set it down over there Huitzil," Mercury indicated a relatively vacant spot in the room.
Figment
Huitzil dropped the corpse in the place indicated.
thepanda
Mercury summoned chill water around the form. She concentrated and cause it swirl around the fallen figure, draining the lingering heat from its body without adding ice. Once that is done she returns to the same position she was in the first time they threw a body through the door.
"Everyone, get in position. We'll try this again."
Figment
Huitzil picked up the corpse, before moving back over to the open door.
kpjam
Deciding to stay in the vicinity this time, Alita only moved a few steps away from Recca, towards the first room, and away from his potential line of sight.  She wouldn't see what was happening, but she had compelte confidence that they would succeed without her.
Recca wondered if that gargoyle would attack the corpse one thrown in or not. Deciding to be prepared, he readied to pull backwards again, if necessary, and waited for the move from Huitzil.
Figment
Huitzil stepped up to the doorway once more and slid the corpse across the floor exactly as he had the first one, placing a forcefield across the door as soon as the corpse was away.
As before, the gargoyle slammed down from the ceiling, crushing the corpse, and tearing it to shreds with a brutal blow before looking around the room, it's four arms raised in challenge.
Fearless Leader
