Tomb Vs Animeverse, Act 3 (Recovered)
Started by Dracos, March 07, 2003, 09:29:34 PM
kpjam
Alita complied, concentrating on his right arm first.
The limbs began to fall apart under her assault, freeing his right arm.
Fearless leader
The Gargoyle almost stopped as the blades impacted against it, slicing deeply into it's stone waist.  It moved back for a moment before leaping high into the air towards Huitzil.
Fearless Leader
Figment
Very quickly taking a couple of steps to the right, Huitzil deployed his argon laser and used it to create a layer of ice where the gargoyle was going to land.
Recca grinned as he felt the pressure on his arm loosen. "Okay, you work on my left side, I'll work on my right side while keeping an eye on the big guys."
Careful not to hit Alita with his fire blade, he began to move his arm slowly, then aimed towards where the claws held him down on his right and above, so that he could free himself to the point he could lean down and work on his legs next. Occassionally, he looked towards the battling giants of stone and metal duking it out, watching for their distance from them.
The gargoyle landed, it's clawed feet digging into the slight layer of ice, and going through it as it propelled itself at Huitzil.
Fearless Leader
kpjam
Alita complied and started working to free the left side of Recca's body.
Figment
Deploying his blades again, but keeping them attached to the ends of his arms instead of throwing them on their short chains, Huitzil attempted to slam both blades into the cuts he had made earlier, bracing himself for the impact.
The gargoyle shifted, attempting to protect itself from the blades as it spun about, swinging two of it's arms to strike towards Huitzil's side, while it shielded itself with it's other arms.
Fearless Leader
Figment
Breaking off his attack on the gargoyle's midsection, Huitzil swung his left blade up at the limb that Alita had previously attacked, while using his right blade to deflect the other limb out and to the side.
The blade nearly severed the limb as he struck out, only to have his other blade barely manage to deflect the limb off as it was dented by the force of the blow, the gargoyle plowing into him, sending him back as it began swinging towards him with all four limbs.
Fearless Leader
thepanda
Mercury propelled herself into the air, her hands closing around the Mercury Harp. She prepares an Aqua Rhapsody in case the gargoyle presents an opening or tries to go airborn  again.
Figment
Attacking the damaged limb with his left blade again, Huitzil retracted the blade on his right arm and attempted to block the attacks coming from that side.
The gargoyle's blow smashed into Huitzil's block, nearly sending the golem spinning off balance ruining his aim as he again left a vicious cut in the weakened arm.
The gargoyle didn't seem to pause, striking again as it sought to bypass the blades.
Fearless Leader
kpjam
"Wait here," Alita said to Recca, "or get yourself out."
She took a step away from the wall, and looked at the combatants.   If she had a line of fire at the gargoyles eyes, she would fire twice at whichever one was visible, if neither eye were visible she'd move around the room until one was.
