Tomb Vs Animeverse, Act 3 (Recovered)
Started by Dracos, March 07, 2003, 09:29:34 PM
Figment
Feeling the Gargoyle's impressive strength, Huitzil ceased his assault on the statue's back, instead attacking the Gargoyle's remaining right arm, cutting into it near the shoulder and applying steady pressure.
kpjam
Seeing that Huitzil wouldn't easily be able to push the gargoyle out of the room, Alita dashed in.  Taking her blade, she struck at the creatures exposed neck.
ooc: I'm assuming the creatures back is to me.
thepanda
Mercury scans for the controlling/activation mechanism for the gargoyle starting at the center of the room while keeping an eye out for the battle taking place below.
Mercury doesn't find one.
The Gargoyle looked to be falling apart anyways though as Alita's blade dug deep into it's neck.  Huitzil slowly cut through the stone, but at great cost as his armor began reaching it's breaking point, looking battered all over despite his shifting and molding of it.
Fearless leader
thepanda
Mercury flew to a point perpendicular of the battling titans and took careful aim at the gargoyle's legs. Making sure the bot isn't in her line of fire Mercury lets off another plant attack at the stone adversary.
kpjam
Alita hacks again at the gargoyles neck, aiming as closely as possible to her prior strike.
Mercury nearly swooned with exhastion as she let off another powerful blast, knocking off one of the Gargoyle's legs and sending him, Alita, and Huitzil spinning as it crashed towards the ground, it's head flying off from Alita's strike.  The creature while dangerous, seemed to be in it's death throes as it thrashed around with it's remaining three limbs.
Fearless Leader
kpjam
Alita did her best to regain her balance and move away from the gargoyle and the wall.
thepanda
Mercury lowered herself to the ground, not wanting to exhaust what energy she had left. She moved away from the fallen gargoyle while trying to get her breath back. Two planet attacks might not have been the greatest of ideas, but at least it worked.
Moving back away from the gargoyle, Mercury found stone arms grabbing her and digging into her flesh as they yanked her against the wall she'd gotten to close to.
Fearless Leader
Alita's luck was with her as she barely dodged under a swinging limb, managing to get out of reach of the monstrousity.
Fearless Leader
kpjam
Alita called out to Huitzil, "You okay?"
She was going to ignore her other comrades, since they had now both blown her up, and failed to neutrilize any threats.  She began wonderering if she would be safer with the enemies from now on, as she waited for the big guy to answer her.
Figment
Huitzil attempted to roll away from the gyrating bit of gravel.
Huitzil rolled away, but not before a vicious strike left a dangerous tear in his armor.
The stone creature continued to strike out but with nothing in range could do nothing.
Fearless Leader
kpjam
Seeing Huitzil move out of range of the creature.  Alita turned to the girl.
"Bitch, did it ever occur to you to warn people when you set off exposion in the middle of a melee fight, or does the welfare of your comrades not concern you?"
