Floor 1 "Wheel": 1-1
OOC: Meant am I lowering into spikes or anything?  Or is it safe to just go with the water down to ground level?
OOC: It looks safe enough if one stays with the water level.
Shadow stays with the water level, keeping an eye out for things of import as he lowers down.
Shadow descends down! The water level sinks down all the way to the bottom of this little upward area, sixty feet below. Not much of interest was revealed by this.
Shadow heads back to see how Varian is doing.
Varian awaits! Not much has happened while he waits, Shadow returning safely at last!
ooc: *peeks in and sees his cue!*
ic:
"What happened? You were gone for quite a while that time!" Varian asks, a strongly curious undertone in his voice.
OOC:...eh?  Hasn't he been lowered to the ground by the falling water level?  Thus providing a very obvious change?
OOC: The water lowered in the upward tunnel you explored. It's still normal here. Imagine it like a tower that drained out.
ooc: heh, yeah, I didn't see anything from Ana saying things lowered on my end so I assumed (correctly for once!). Still think "What happened?" is a valid question even if water level fell though. =) And on other notes.... *gnaws*
OOC: Ah... sorry!  Misinterpreted.
IC:
"Found a section inside with some air.  We should be able to use it as a mid point."
