Void strike (Jaela)
Started by Anastasia, February 03, 2016, 02:05:15 PM
Vivantha will move over to try and focus her songs into destroying the spiritwall!
Can Vivantha use Spelldeath Refrain twice? I'm going to assume yes so as to not hold this up any more. She's not targeting any of her allies or herself, but is getting within 20ft of the spirit wall in order to target it with the area dispel.
[17:14] <Erad> roll 1d20+10  area dispel
[17:14] <Kobot> Erad rolled 1d20+10 area dispel --> [ 1d20=9 ]{19}
[17:15] <Erad> roll 1d20+10  area dispel
[17:15] <Kobot> Erad rolled 1d20+10 area dispel --> [ 1d20=1 ]{11}
It doesn't matter here, since seriously those rolls.
RAW spelldeath refrain would cap at +10 due to dispel magic's text. It does note to combine bard and seeker of the song level for it, so I do wonder if the intent is for it to go past +10. This is more something for another time, however.
Unfortunately, the wall endures Vivantha's musical refrain. Noise sounds, high and beautiful, yet it is not enough to cause the wall to collapse.
"Unfortunate," Canderella says with a slight shake of her head. She struts on forward, through the wall. "Enough of this playing around," she says, lightning crackling from her wings and up her body. It focuses in her hands, "Talos, I offer these unworthy restless dead to your fury!"
> roll 1d10 Canderella
<Kobot> Kotono rolled 1d10 Canderella --> [ 1d10=3 ]{3}
Twinned Moonbow, 9th level spell. 2 balls per surviving ghost.
> roll 1d20+26 eg4
> roll 1d20+26 eg4
<Kobot> Kotono rolled 1d20+26 eg4 --> [ 1d20=11 ]{37}
> roll 1d20+26 eg5
> roll 1d20+26 eg5
<Kobot> Kotono rolled 1d20+26 eg5 --> [ 1d20=6 ]{32}
<Kobot> Kotono rolled 1d20+26 eg5 --> [ 1d20=19 ]{45}
> roll 1d20+26 eg6
> roll 1d20+26 eg6
<Kobot> Kotono rolled 1d20+26 eg6 --> [ 1d20=2 ]{28}
<Kobot> Kotono rolled 1d20+26 eg6 --> [ 1d20=14 ]{40}
> roll 10d6
<Kobot> Kotono rolled 10d6 --> [ 10d6=42 ]{42}
> roll 10d6
<Kobot> Kotono rolled 10d6 --> [ 10d6=38 ]{38}
> roll 10d6
<Kobot> Kotono rolled 10d6 --> [ 10d6=39 ]{39}
> roll 10d6
<Kobot> Kotono rolled 10d6 --> [ 10d6=26 ]{26}
> roll 10d6
<Kobot> Kotono rolled 10d6 --> [ 10d6=37 ]{37}
> roll 10d6
Ball lightning hits each of the remaining ghosts, causing them to burst like overcooked sausages. They suck in everything nearby and are then gone, leaving only the dying and dazed cornugon.
The party at last has a moment to take in their surroundings. They came in the side of a hallway, 15ft wide and about as tall. To the right leads to the steel doors already seen. To the left leads straight for about 60ft until it makes a 90 degree turn to straight ahead and out of sight. The interior is the same stone as the outside, though as you glance at it, you can see the surfaces slightly bulge in places.
"We're in," Adrian says quickly, "We need to press our advantage fast."
Free act for the moment since no able enemies remain. The cornugon can't act for the moment.
Adrian
HP: 277+20/325 Fast Healing 1
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Resist Energy(Cold)(CL22), Fortunate Fate(CL25), Freedom of Movement(CL22), Death Ward(CL25), Bardsong
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, cold resistance 30.
Resources used: -
Other: -
Canderella
HP: 210/261
Resources used: Arcane casting: 9th: 2 charges
Other: -
Moonlight
HP: 335/396
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Resist Energy(Cold)(CL22), Fortunate Fate(CL25), Freedom of Movement(CL22), Death Ward(CL25), Sun Devotion(CL-), Bardsong
Resources used: Sun Devotion, 16/17 turns left
Other:
Mei
HP: 244+20/295
Resources used: -
Other: -
#122
"Get over here!" Jaela calls out to Vivantha, waving her over for good measure. Once their last remaining member is past the wall, Hanna tries to call upon healing energy while gesturing for her conjured up axe to go and assault the cornugon.
"Adrian, Mirima, Moonlight, Mirajane, at the front with me," Jaela orders, not wasting any time. "Mei, bar the other corridor with your wall. Mom, kill the downed devil if you have the time before joining up with us."
And then she's off, charging at and then through the set of doors to the right! She can break the outer walls of the crypt with Gae Dioltas, so it would be a good indication of whether the inner doors are better reinforced. If she does fail, that's why Mirima has a scroll of Knock.
Mirajane follows, a matching crown of flames now adorning her head.
Intention is for Vivantha to rejoin us and Mei to ward off the left passage with her wall, Hanna to try and cast Mass Heal on us, Mirajane to cast Crown of Flames and Jaela to charge at the door on the right to break it down. Hanna will use her move action to retask the Spiritual Weapon to beat up the downed cornugon.
If Jaela breaks down the door, she still has a swift action to use after she sees what's there. She ends the turn in Gambit either way, with Mirajane adjacent to her. Hopefully either a charge or Knock will open the door that round.
If Hanna isn't immediately needed to deal with more enemies, she'll spend the next round killing the cornugon before bringing up the rear.
[16:29] <Louise> roll 1d20+22 Hanna
[16:29] <Rei-chan> Louise rolled : 1d20+22 Hanna --> [ 1d20=3 ]{25}
[16:31] <Louise> roll 1d20+40-10 charge, 10pa
[16:31] <Rei-chan> Louise rolled : 1d20+40-10 charge, 10pa --> [ 1d20=19 ]{49}
[16:31] <Louise> roll 3d8+84+39+30+2d6 last is goldenfire
[16:31] <Rei-chan> Louise rolled : 3d8+84+39+30+2d6 last is goldenfire --> [ 3d8=10 2d6=7 ]{170}
~2.5hr since leaving Aurora, for spell durations. 6 rounds since the crypt's barrier had been triggered. 2/13 rounds on Divine Might.
Jaela
HP: 243+20/318
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Moment of Prescience (CL21), Longstrider (CL21), Righteous Halo (CL25), GMW x4 (CL25), Celestial Brilliance (CL25), Magic Vestment x2 (CL27), Lore of the Gods (CL25), Divine Insight (CL25), Contingency (CL29), Permanency/Greater Blindsight (CL29), Permanency/Mantle of Good (CL30), Energy Resistance/Cold (CL22), Fortunate Fate (CL25), Turn Anathema (CL25), Foresight (CL23), Sublime Revelry (CL26), Mass Freedom of Movement (CL22), Mass Death Ward (CL25), Lion's Roar (CL25).
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, Blindsight for 60ft, Spell Resistance vs Evil Spells of 40, 60ft radius of bright light/60ft more of dim light; undead take 1d6 damage per round within bright light/evil outsiders and undead vulnerable to sunlight take 2d6 damage per round within bright light, evil creatures within 40ft suffer a -2 penalty to saving throws against Jaela's spells, spell-like abilities and supernatural abilities; -4 against evil outsiders and undead.
Spell charges total: 6//10/9/9/7/9/8/8/8/8//5
Spell charges remaining: 6//10/6/7/3/9/6/0/6/5//5
Resources used: 1/3 Lesser Extend charges, Foresight x1, Spell Turning, 2/16 Turning charges, 1/6 Smites.
Bolt of Glory channeled into Gae Dearg.
Hidden Dawn at CR30
Mirajane
HP: 249+20/283
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Detect Evil (CL22), Discern Lies (CL22), True Seeing (CL22), Foresight (Su/CL22), Energy Resistance/Cold (CL22), Fortunate Fate (CL25), Sublime Revelry (CL26), Mass Freedom of Movement (CL22), Mass Death Ward (CL25), Lion's Roar (CL25).
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, Mirajane is never surprised or caught flatfooted.
Resources used: Cure Serious Wounds x1/Sentinel, Crown of Flames x1, Turning x1.
Other: Hidden Dawn at CR30
Hanna
HP: (18) 335+20/335
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Detect Evil (CL22), Discern Lies (CL22), True Seeing (CL22), Detect Snares and Pits (CL22), See Invisibility (CL22), Energy Resistance/Cold (CL22), Fortunate Fate (CL25), Foresight (CL22), Sublime Revelry (CL26), Mass Freedom of Movement (CL22), Mass Death Ward (CL25), Lion's Roar (CL25).
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, Hanna cannot be flanked.
Resources used: Attune Form x2, Find the Path, Foresight, Mass Freedom of Movement, Spiritual Weapon, Mass Heal x1.
Other: -
> roll 1d10 Vivantha damage
<Rei-chan> Kotono rolled : 1d10 Vivantha damage --> [ 1d10=10 ]{10}
Vivantha passes through the wall, taking the pain and through it.
"Right," Moonlight adjusts her grip on her mace, "Let's do this."
Hanna begins to chant, as meanwhile Mei throws up a wall. It's just in time, as around the corner come at a dozen Necrolytes. They immediately begin to chant, motes of arcane light gathering around them from all directions.
"We have a problem," Mirima calls once the Necrolytes are seen, as meanwhile Jaela smashes into the steel door. It bulges inward from the impact but does not give. At the same time, Hanna finishes her chanting, but the spell fizzles out. Adrian turns towards the Necrolytes, sword at the ready. "Ready to die for your precious little prince?" he shouts.
No init for now, as the wall prevents meaningful contact for the moment. This may change soon, so assume you're in round to round actions for now. Hanna's spell fails and is wasted.
As requested, since I failed to break the door can Mirima use the Knock scroll to get it opened?
Mirima quickly comes forth and produces her scroll. A quick casting causes the door to pop ajar, a groan from abused hinges. It can be opened now.
> rolll 1d20+32 spellcraft Moonlight
<Rei-chan> Kotono rolled : 1d20+32 spellcraft Moonlight --> [ 1d20=18 ]{50}
"They're trying something to take down the wall," Moonlight cries, as Adrian readies his sword. "Jaela, think we should split up? Some of us can deal with the trash here while you go on ahead."
"Thanks, Mirima!" Jaela cheers. "Knew I could count on you!"
She hastens everyone before calling over, "Fighting retreat! Adrian, take charge. Mom, kill that devil you're toying with! Mei, get another wall up if they bring this one down. Cut a couple of them off so we'll defeat them in detail."
Grinning at Moonlight, she tells her, "Now kick that door open so we can say hello."
Using my leftover swift action to cast quickened Haste on everyone, I think we're all in range. I want to proceed with Mirajane, Mirima and Moonlight while Adrian and the others bring up the rear. That might lead us to separate, but probably not just yet.
Adrian and the others position in the rear while Jaela kicks open the door. Ahead lies a chamber full of stone slabs hung from the ceiling, each about 9ft wide and 9ft long. They hang 9ft from the ceiling. There are dozens of them in here, casting the floor below in shadow. It stretches on farther than you can see casually, not that you have much time to look. 35ft away and 10ft to the side is a skeleton. It wears robes of old, tattered gray and gazes with empty eye sockets at the party. It carries a skull in its arms, one that moves and looks about as well.
"You are not welcome here," The skeleton warns in a rasping voice, while meanwhile Adrian calls, "They just disintegrated the wall! We have incoming!"
At the same time, Mei flinches back silently, as if struck.
> roll 1d10 ow to Mei
<Rei-chan> Kotono rolled : 1d10 ow to Mei --> [ 1d10=1 ]{1}
Init here. Jaela, Mirima, Moonlight and Mirajane are at the opened door. 40ft behind them (by the gap) are Adrian and the others. The Necrolytes are 40ft away from them, for 80ft from that group and 120ft from Jaela and company.
Bardsong has one round left.
Adrian
HP: 278+20/325 Fast Healing 1
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Resist Energy(Cold)(CL22), Fortunate Fate(CL25), Freedom of Movement(CL22), Death Ward(CL25), Bardsong, Haste (CL25)
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, cold resistance 30. +1 attack rolls, +1 attack on full attack, +1 Reflex, movement speed bonus.
Resources used: -
Other: -
Canderella
HP: 210/261
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, cold resistance 30, +1 attack rolls, +1 attack on full attack, +1 Reflex, movement speed bonus.
Other: -
Moonlight
HP: 335/396
Other:
Mei
HP: 244+20/295
Resources used: -
Other: -
Auras Reminder
Vivantha:  Psychic aura 10ft (+2 morale init, spot, listen)
Adrian: Draconic Aura: +4 bonus to spot, listen and initiative checks to himself and all allies within 30ft.
Canderella: Determined Caster (+16 to overcome SR), Motivate Ardor (+2 to damage rolls)
[12:15] <Nephrite> roll 1d20+10+6 Vivantha init
[12:15] <Rei-chan> Nephrite rolled : 1d20+10+6 Vivantha init --> [ 1d20=1 ]{17}
240/301 (heroes feast, attune form, telepathic bond)
+10 Init, 110 ft fly (good)
52 AC
psychic aura 10ft (+2 morale init, spot, listen)
darkvision 120 ft, immunity to poison, resistance to fire 20
Saves: Fort +36, Ref +37, Will +31
Spells: 4/7/7/7/6/6/6
[19:17] <Louise> roll 1d20+12 Jaela
[19:17] <Rei-chan> Louise rolled : 1d20+12 Jaela --> [ 1d20=14 ]{26}
[19:17] <Louise> roll 1d20+12 Hanna
[19:17] <Rei-chan> Louise rolled : 1d20+12 Hanna --> [ 1d20=12 ]{24}
As Hanna is near the others, she has +6 more to her init for a total of 30.
[19:18] <Louise> roll 1d20+7 Mirajane
[19:18] <Rei-chan> Louise rolled : 1d20+7 Mirajane --> [ 1d20=5 ]{12}[/]i
[17:22] <@Ebiris> roll 1d20+13 Mirima init
[17:22] <Rei-chan> Ebiris rolled : 1d20+13 Mirima init --> [ 1d20=9 ]{22}
Mirima 199+20/285, heroes feast (CL 20), greater mage armour (CL 9), Lion's Roar (CL 25), haste (CL 21)
AC 50 (54 vs power attacks), fire resistance 30, immune to sleep, poison, fear
Spell charges: 6/9/7/6/6/5
> roll 1d20+13 Adrian
<Rei-chan> Kotono rolled : 1d20+13 Adrian --> [ 1d20=18 ]{31}
> roll 1d20+10 (+4 Adrian, +2 Vivantha) Canderella
<Rei-chan> Kotono rolled : 1d20+10 (+4 Adrian, +2 Vivantha) Canderella --> [ 1d20=14 ]{24}
> roll 1d20+7 Moonlight
<Rei-chan> Kotono rolled : 1d20+7 Moonlight --> [ 1d20=16 ]{23}
> roll 1d20+17 (+4 Adrian, +2 Vivantha) Mei
<Rei-chan> Kotono rolled : 1d20+17 (+4 Adrian, +2 Vivantha) Mei --> [ 1d20=14 ]{31}
> roll 1d20+12 Necrolytes
<Rei-chan> Kotono rolled : 1d20+12 Necrolytes --> [ 1d20=5 ]{17}
> roll 1d20+10 Skeleton
<Rei-chan> Kotono rolled : 1d20+10 Skeleton --> [ 1d20=5 ]{15}
> roll 1d20+19 skull
<Rei-chan> Kotono rolled : 1d20+19 skull --> [ 1d20=20 ]{39}
Initiative order is Skull (39) > Adrian = Mei (31) > Hanna (30) > Jaela (26) > Canderella (24) > Moonlight (23) > Mirima (22) > Necrolytes = Vivantha (17) > Skeleton (15) > Mirajane (MIKO HARDER)
Skull opens.
The skull flies right out of the skeleton's arms, just above it. Its face is twisted into a rictus grin as it cackles, before spewing a glowing green blast at Jaela.
> roll 1d20+37 touch AC
<Rei-chan> Kotono rolled : 1d20+37 touch AC --> [ 1d20=10 ]{47}
But Jaela instinctively calls on the Triune, the sound of the three names causing the blast to wither and dissolve before it touches her.
Adrian and Mei are up.
"Right," Adrian grins low and braces a moment, before charging into the diabolical ranks head on. "Crush them!"
> roll 1d20+39 (+2 charge, +1 haste, +1 heroes feast, +5 bardic music, -15 PA, activating bless weapon sheathe as a swift action)
<Rei-chan> Kotono rolled : 1d20+39 (+2 charge, +1 haste, +1 heroes feast, +5 bardic music, -15 PA, activating bless weapon sheathe as a swift action) --> [ 1d20=14 ]{53}
> roll 2d6+66
<Rei-chan> Kotono rolled : 2d6+66 --> [ 2d6=5 ]{71}
Adrian rushes into the teeth of the Necrolytes, hacking deeply into one as he dodges a swipe from a bony staff, then deflects a ray of purple light. Gaelach glows a soft silver as he does battle, while Mei positions herself with a stern look at them. She advances 25ft and stops, opening her mouth and saying but one word, "Angharradh!" Her voice is pure and clear, a quiet tone amplified dozens of times over, until it echos amid the halls like a crack of thunder.
Suddenly warm spring winds blow about, the heroes near her beginning to glow with a soft white light. This same light makes the cornugons shriek and shield themselves, as...
> roll 1d20+21 vs DC 34 holy word
<Rei-chan> Kotono rolled : 1d20+21 vs DC 34 holy word --> [ 1d20=20 ]{41}
The devils sizzle and cry out, but withstand the worst of it. Blinding light gathers around Mei, angel wings extending out from her back, solid and unlike the ones she normally calls on. She seems more, greater, overwhelming.
Hanna's up. Holy Aura on Adrian and the ones by him, baddies saved against holy word, and she gets greater visage of the deity.
Adrian
HP: 280+20/325 Fast Healing 1
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Resist Energy(Cold)(CL22), Fortunate Fate(CL25), Freedom of Movement(CL22), Death Ward(CL25), Bardsong, Haste (CL25), Holy Aura (CL22)
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, cold resistance 30. +1 attack rolls, +1 attack on full attack, +1 Reflex, movement speed bonus, +4 deflection AC, +4 resistance saves, blinding on enemy attack.
Resources used: -
Other: -
Canderella
HP: 210/261
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Resist Energy(Cold)(CL22), Fortunate Fate(CL25), Freedom of Movement(CL22), Death Ward(CL25), Bardsong, Holy Aura(CL22)
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, cold resistance 30, +1 attack rolls, +1 attack on full attack, +1 Reflex, movement speed bonus, +4 deflection AC, +4 resistance saves, blinding on enemy attack.
Other: -
Moonlight
HP: 335/396
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Resist Energy(Cold)(CL22), Fortunate Fate(CL25), Freedom of Movement(CL22), Death Ward(CL25), Sun Devotion(CL-), Bardsong, Holy Aura (CL22)
Other:
Mei
HP: 244+20/295
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Resist Energy(Cold)(CL22), Fortunate Fate(CL25), Freedom of Movement(CL22), Death Ward(CL25), Bardsong, Greater Visage of the Deity (CL22)
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, telepathy with teammates, cold resistance 30, +1 attack rolls, +1 attack on full attack, +1 Reflex, movement speed bonus, visage bonuses.
Resources used: 1 words of the triune
Other: -
Standing over the downed cornugon, Hanna brings her axe upon it again and again, her blood-soaked visage striking fear into the hearts of her enemies!
Hanna goes into greater rage, Fearsome Fury means enemies coming within 30ft of her need to roll a will save against DC 44 or be shaken for 1d4+1 rounds or the duration of her rage.
[20:06] <Louise> roll 1d20+38+1+5
[20:06] <Rei-chan> Louise rolled : 1d20+38+1+5 --> [ 1d20=19 ]{63}
[20:06] <Rei-chan> Louise rolled : 1d20+38+1+5 --> [ 1d20=7 ]{51}
[20:06] <Louise> roll 1d20+33+1+5
[20:06] <Rei-chan> Louise rolled : 1d20+33+1+5 --> [ 1d20=1 ]{40}
[20:06] <Louise> roll 1d20+28+1+5
[20:07] <Rei-chan> Louise rolled : 1d20+28+1+5 --> [ 1d20=17 ]{51}
[20:07] <Louise> roll 1d20+23+1+5
[20:07] <Rei-chan> Louise rolled : 1d20+23+1+5 --> [ 1d20=1 ]{30}
[20:08] <Louise> roll 3d6+21+5+5
[20:08] <Rei-chan> Louise rolled : 3d6+21+5+5 --> [ 3d6=11 ]{42}
[20:08] <Rei-chan> Louise rolled : 3d6+21+5+5 --> [ 3d6=6 ]{37}
[20:08] <Rei-chan> Louise rolled : 3d6+21+5+5 --> [ 3d6=9 ]{40}
[20:08] <Rei-chan> Louise rolled : 3d6+21+5+5 --> [ 3d6=7 ]{38}
[20:08] <Rei-chan> Louise rolled : 3d6+21+5+5 --> [ 3d6=10 ]{41}
[20:09] <Louise> roll 1d20+34 intimidate
[20:09] <Rei-chan> Louise rolled : 1d20+34 intimidate --> [ 1d20=10 ]{44}
~2.5hr since leaving Aurora, for spell durations. 7 rounds since the crypt's barrier had been triggered. 3/13 rounds on Divine Might.
Jaela
HP: 243+20/318
AC: 66 normal, 58 touch, 60 vs incorporeal, 20% miss chance.
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Moment of Prescience (CL21), Longstrider (CL21), Righteous Halo (CL25), GMW x4 (CL25), Celestial Brilliance (CL25), Magic Vestment x2 (CL27), Lore of the Gods (CL25), Divine Insight (CL25), Contingency (CL29), Permanency/Greater Blindsight (CL29), Permanency/Mantle of Good (CL30), Energy Resistance/Cold (CL22), Fortunate Fate (CL25), Turn Anathema (CL25), Foresight (CL23), Sublime Revelry (CL26), Mass Freedom of Movement (CL22), Mass Death Ward (CL25), Lion's Roar (CL25), Haste (CL21).
Hidden Dawn at CR30
Mirajane
HP: 249+20/283
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Detect Evil (CL22), Discern Lies (CL22), True Seeing (CL22), Foresight (Su/CL22), Energy Resistance/Cold (CL22), Fortunate Fate (CL25), Sublime Revelry (CL26), Mass Freedom of Movement (CL22), Mass Death Ward (CL25), Lion's Roar (CL25), Haste (CL21).
Hanna
HP: (7) 401+20/401, rage round 1
Effects: Heroes Feast (CL20), Attune Form (CL22), Telepathic Bond (CL22), Detect Evil (CL22), Discern Lies (CL22), True Seeing (CL22), Detect Snares and Pits (CL22), See Invisibility (CL22), Energy Resistance/Cold (CL22), Fortunate Fate (CL25), Foresight (CL22), Sublime Revelry (CL26), Mass Freedom of Movement (CL22), Mass Death Ward (CL25), Lion's Roar (CL25), Hase (CL21).
Resources used: Attune Form x2, Find the Path, Foresight, Mass Freedom of Movement, Spiritual Weapon, Mass Heal x1, Rage x1.
Other: -
"What was that, ghost snot?" Jaela scoffs at the floating skull, as all magic in a thirty feet radius around it and the skeleton shudders. "You try too hard!"
There is only one thing to do in this situation, and it's another charge aimed straight at the skull!
Quickened Chain Dispel as stated, then a charging smite with Gae Dioltas, no Gambit for a change. Assuming blindsight confirms what I'm seeing.
It does. 2 on the skeleton and 3 on the skull.
