Surraruthru's endless quest for treasure (Surraruthru, Jaela)
Started by Anastasia, May 25, 2016, 10:49:16 PM
Surraruthru nods and casts Energy Immunity on himself and Ebony!
Jaela steps through the barrier on the other side from the others, and immediately puts up a wall to her left running all the way towards the exit and anchoring itself on the wall to the left from the door. The part of the wall closest to her curves in front of Jaela to try and shield her, though should the explosions have concussive force she's likely to be blown back into her sphere and its protections, she reasons.
Swift action to put a Wall of Stone to cover our left flank and curve to the front. Used at half thickness, I have 50 sections of 5ft blocks to play with that should cover the 40ft from the exit to me and then curve in front of me. If nothing exploded me I'll use my standard action to put up a matching wall on the right to complete the semi-circle.
All of us are fire-immune. Two from Surraruthru, two from Kascha.
Just an obvious question here to be clear, but you're fire immune?
Spells are cast and fire immunity is had. Jaela goes out, trying to cast her spell as everything goes crazy around her.
Concentration check.
[19:04] <Tohsaka> Roll 1d20+29
[19:04] <Serith> Tohsaka roll for Serith < 47 > [d20=18]
Jaela's able to keep her spell, the tunnel of rock appearing. It helps some, though the explosions within it are still an issue. It's tough to hold her ground but not impossible now.
The other wall rises to complete her shelter from the right, and then Jaela makes a roof!
"When Jaela's ready for it, I've got Gate prepared. If something else goes wrong I have time stop and wish ready, too."
The hall is completed. Still exploding, but a path out is now viable.
Jaela steps back into the sphere to rejoin the others, puts up a fresh wall against whatever might give chase to them before calling out, "Go!" as she disrupts her ultimate defensive spell.
Follows Jaela's order and attempts to head out with a chest!
Ebony and Kascha follow, each of them lugging their chest as well. Like this the party retreats in a hurry, running up explosive stairs mostly blind and finally emerging from it. You're sooty and reek of sulfur, but three chests are there and intact. The explosions don't seem to have damaged them at all.
"Surraruthru and I will return for the last two," Jaela says once they're safe. "Be alert."
She reaches out for Surraruthru and attempts to use dimension door to place them by the second chest she dragged over to their huddle spot.
Nothing happens. The spell's suppressed, most likely the area's just teleportation sealed.
"Hard way, then. Time for more lugging."
Surraruthru heads back in the un-fun way!
