Wrap up (Various)
Rising up fast as an arrow is a massive icicle, missing all of you but splashing frigid water at all of you.
Ref saves, all. Jaela, you can shield Mirajane if you want to protect her, but you'll autofail the save then.
Temp boost: Haste (CL24): +1 attack, ref, attacks on FA, speed.
Hanna http://www.soulriders.net/forum/index.php/topic,103876.msg1078446.html#msg1078446
HP: 378/378 regeneration 11
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Greater Mage Armor (CL5), Epic Mage Armor (CL24), Heroes Feast (CL20), Divine Insight (CL24)
Bonuses: +20 armor bonus to armor class, +1 morale attack rolls and Will saves, immunity to fear and poison
Resources Used: 1 rage
Mirajane http://www.soulriders.net/forum/index.php/topic,103876.msg1078449.html#msg1078449
HP: 341+1/341
Resources Used: 1 rage, 1 turn
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[20:34] <@Ebiris> roll 1d20+32 evasion
[20:34] <Serith> Ebiris roll for Serith < 33 > [d20=1]
Afina: 215+2/215, glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), fortunate fate (CL 24), divine insight (CL 24), control temperature (CL 24), haste (CL 24), good hope (CL 24)
AC 69, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 6/7/9/6/8/6/4/8/7/8/5/0
Init: +24
Attack: ice sword +42 (1d4+12 +5d6 skirmish +2d6 swift +1d6 sudden strike)
Saves: Fort: +19 (+23 vs poison), Ref: +32, Will: +27
Jaela blocks Mirajane with her body, wings brought back to protect her vitals!
> roll 1d20+29 Hanna (+1 haste)
<Serith> Kotono roll for Serith < 39 > [d20=10]
> roll 1d6 Afina
<Serith> Kotono roll for Serith < 4 > [d6=4]
> roll 1d6 Jaela
<Serith> Kotono roll for Serith < 5 > [d6=5]
> roll 8d10 damage Afina
<Serith> Kotono roll for Serith < 35 > [d10=2,2,5,5,2,7,7,5]
> roll 8d10 damage Jaela
<Serith> Kotono roll for Serith < 47 > [d10=5,6,6,3,10,6,1,10]
Damage reduction does not apply to the damage there, nor does cold resistance/immunity. You'll see why in a sec.
Hanna's surprisingly fast, even more than Afina, who hesitates. She zips up and avoids the water, while Afina is somehow caught off guard. A splash gets her right on the front of her left shoulder and runs down it. In a moment, everything a jagged part of her left shoulder down her left arm and hand is ice. Fragile ice, crumbling already as Afina's left arm is simply gone. The only blessing is that the water completely numbs the area and freezes it, no blood able to pour from her stump.
Jaela dives and pushes Mirajane out of the way, back to the water. It hits her wings, which quickly freeze over and begin to crumble. She's starting to fall, wings gone. At least she's in the same state as Afina, numb and not bleeding - for now.
Init here. Afina, you're minus an arm so two handing isn't an option, plus any obvious drawbacks. Jaela, your wings are toast, so you're starting to fall. You'll be falling on your turn, though you'll have time to react.
[20:42] <@Ebiris> roll 1d20+24
[20:42] <Serith> Ebiris roll for Serith < 36 > [d20=12]
Saccing a 7th level slot with spell-shield to negate 35 points of damage. Since that fully negates it, any chance it also negates the unpleasant statuses that come with?
Spell charges: 6/7/9/6/8/6/3/8/7/8/5/0
Init: +24
[22:43] <Rin> roll 1d20+7+1
[22:43] <Serith> Rin roll for Serith < 21 > [d20=13]
Yes, it does. No dismemberment for you, at least for now.
> roll 1d20+7 Hanna's init is numerologically pure
<Serith> Kotono roll for Serith < 16 > [d20=9]
> OOC: Mirajane's, rather. Was scrolled down.
> roll 1d20+9 Hanna's is filthy and horrible. Bad Hanna, bad.
<Serith> Kotono roll for Serith < 20 > [d20=11]
> roll 1d20+21 ???
<Serith> Kotono roll for Serith < 23 > [d20=2]
Init is Afina (36) > ??? (23) > Jaela (21 wingless, note so we don't forget) > Hanna (20) > Mirajane (16)
Y'all are now 40ft above the water. The icicle's not more than 10ft from any of you.
Open Afina. You're now both armed again since the spell shield stopped all the damage, and it needed to deal damage to make you lose a limb. Your lucky day.
#442
Even if her reflexes fail her, a flare of magic intercepts the water before it can make contact, saving Afina from Jaela's unpleasant fate. Didn't something like this happen before too? Sadly they don't have any of that special water around to make replacement wings.
"Everyone clear some room, we don't want to get splashed by that!" Afina says, speeding herself up so she can lower the water levels so splashing is unlikely to reach high enough to get them and to give Jaela more time to hopefully recover before plunging into the water herself!
6th level slot for 1 round time stop, using control water SLA to lower water level by 48 feet in a 240x240 square. Will do other stuff with my remaining actions once time stop ends depending on what's revealed. Keeping the SR check for prismatic spray here just in case I end up using that after all
[21:03] <@Ebiris> roll 1d20+24 prismatic spray CL if needed
[21:03] <Serith> Ebiris roll for Serith < 42 > [d20=18]
Spell charges: 6/7/9/6/8/6/3/6/7/8/5/0
Init: +24
One problem with your cunning plan, Afina. Call avalanche can only be cast outside. Read the first line of the spell.
Quick note: In the future when there's an edit that isn't fairly immediate for this sort of thing, I'd rather you just make an appended new post rather than editing the old. Oftentimes I rely on who posted last to see if I need to post, I can miss edits like this which leads to delays. Thanks. At the very least, toss an OOC post after mine that you made an edit.
The water lowers. Below you can see something massive - the top of a head that takes up most of the space that you revealed, only the very top tips of its eyes visible at the newly lowered waterline. It looks like a creature made purely of ice, radiating intense cold.
K:A here.
[17:36] <@Ebiris> roll 1d20+37+15 arcana with divine insight
[17:36] <Kobot> Ebiris rolled 1d20+37+15 arcana with divine insight --> [ 1d20=19 ]{71}
Both Jaela and Afina can identify the absolutely titanic creature. It is a primal ice elemental. They're the strongest elementals known save for unique ones such as the Archomentals. They are overwhelmingly powerful, strike with Cold's full power and have an aura of overwhelming cold around them. They can transform into huge blizzards and throw around primal magic with the barest effort. Oh, and then tend to be big. Really big, as this one, based on its head, is probably hundreds if not thousands of feet tall.
The only weakness they have is fire, though many have means to stop fire damage or otherwise mitigate it.
HP: 341+1/341
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Yeah, I'll skip the prismatic spray for something with more bang.
As the primal ice element is revealed, Afina calls forth some allies to give it something else to think about before flying upwards thirty feet.
SMX to summon 1d4+1 huge storm elementals
[17:44] <@Ebiris> roll 1d4+1 huge storm elementals
[17:44] <Kobot> Ebiris rolled 1d4+1 huge storm elementals --> [ 1d4=1 ]{2}
Unfortunately only a meagre two appear, both of which are immediately stricken by the terrible cold of this environment. But it doesn't stop them both from assailing their primal cousin with great booms of thunder and flashes of lightning!
[17:46] <Kobot> Ebiris rolled 8d6 sonic DC 24 fort --> [ 8d6=32 ]{32}
[17:46] <@Ebiris> roll 8d6 sonic DC 24 fort
[17:46] <Kobot> Ebiris rolled 8d6 sonic DC 24 fort --> [ 8d6=26 ]{26}
[17:46] <@Ebiris> roll 16d6 lightning DC 24 ref
[17:46] <Kobot> Ebiris rolled 16d6 lightning DC 24 ref --> [ 16d6=53 ]{53}
[17:46] <Kobot> Ebiris rolled 16d6 lightning DC 24 ref --> [ 16d6=62 ]{62}
Afina: 215+2/215, glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), fortunate fate (CL 24), control temperature (CL 24), haste (CL 24), good hope (CL 24)
Spell charges: 6/7/9/6/8/6/3/8/7/8/4/0
Init: +24
Elemental 1: 168hp, fort +11, will +11, ref +5
> roll 1d20+33 fort doesn't fail fort saves on a natural 1 so these are academic
<Kobot> Kotono rolled 1d20+33 fort doesn't fail fort saves on a natural 1 so these are academic --> [ 1d20=8 ]{41}
<Kobot> Kotono rolled 1d20+33 fort doesn't fail fort saves on a natural 1 so these are academic --> [ 1d20=16 ]{49}
> roll 1d20+34 ref improved evasion
<Kobot> Kotono rolled 1d20+34 ref improved evasion --> [ 1d20=6 ]{40}
<Kobot> Kotono rolled 1d20+34 ref improved evasion --> [ 1d20=9 ]{43}
The primal elemental is barely phased by the storm elementals that Afina summons, the water below forming into spears of watery ice and hurling at the two elementals.
Primal magic shenanigans as a swift action.
> roll 1d20+39 touch AC vs elemental 1
<Kobot> Kotono rolled 1d20+39 touch AC vs elemental 1 --> [ 1d20=18 ]{57}
> roll 1d20+39 touch AC vs elemental 2
<Kobot> Kotono rolled 1d20+39 touch AC vs elemental 2 --> [ 1d20=18 ]{57}
> roll 25d8 and fort if they survive this
<Kobot> Kotono rolled 25d8 and fort if they survive this --> [ 25d8=121 ]{121}
> roll 25d8 and fort if they survive this elemental 2
<Kobot> Kotono rolled 25d8 and fort if they survive this elemental 2 --> [ 25d8=94 ]{94}
Let me know if they died or make Fort saves if they survived.
