The hunt for companionship (Calleigh)
Started by Anastasia, August 30, 2016, 03:44:42 PM
Can I get two rolls, one at +7 for Calleigh, one at +6 for Tryll for init please?
[16:23] <@Ebiris> roll 1d20+7 C
[16:23] <Serith> Ebiris roll for Serith < 9 > [d20=2]
[16:23] <@Ebiris> roll 1d20+6 T
[16:23] <Serith> Ebiris roll for Serith < 24 > [d20=18]
Init is Hanna (27) > Tryll (24) > Moonlight (22) > Demon Horde (19) > Simmer (14) > Calleigh (9)
You came up about 50ft away from them. Demons everywhere, even right overhead as you peek out and see this mess. Hanna opens.
With a single word of overwhelming magic, holy power comes off Hanna like a wave, immolating demons all around her.
Righteous exile.
> roll 1d20+23 SR
<Serith> Sunshine_Ko roll for Serith < 26 > [d20=3]
> roll 20d6
<Serith> Sunshine_Ko roll for Serith < 70 > [d6=4,3,2,6,5,4,5,2,3,2,6,1,4,6,2,1,3,5,1,5]
> roll 1d20+23
<Serith> Sunshine_Ko roll for Serith < 41 > [d20=18]
The blast incinerates a pair of manes running at her, knocking a vrock back and setting a pair of hezrou aflame. As this happens...
Go Tryll.
Moonlight
HP: 307/414
Bonuses: +1 morale attack and Will saves
Hanna
HP: 354 (30)/354 regeneration 11
Simmer
HP: 291/333
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL23), Heroes Feast (CL20), Superior Resistance (CL23)
Temp boosts: Celestial Valor (+8 mind affecting, +4 attack rolls, weapon damage rolls, saves, ac. All sacred. Weapons count as holy, doesn't stack.
Always active: Detect Evil, Detect Snares and Pits, Discern Lies, See Invisibility, True Seeing.
Spell-like abilities
At will-continual flame, dispel magic, holy smite, invisibility (self only), lesser restoration, remove curse, remove disease, remove fear, speak with dead; 3/day-blade barrier, flame strike, power word stun, waves of fatigue; 1/day-earthquake, greater restoration, mass charm monster, waves of exhaustion. Caster level 22nd. The save DCs are 16 + spell level.
Hanna casts as a 23rd level cleric with access to the War and Wrath(BoED) domains. The save DCs are 20 + spell level. Her spell themes are holy magic, healing and extended buffs. Her metamagic options are Extend Spell (+1) and Consecrate Spell (+1).
[6/day]0: Create Waterx6.
[8+1/day]1: (Doom), Divine Favor, Ray of HopeBoEDx2, Shield of Faithx3, Twilight Luckx2BoED
[8+1/day]2: (Spiritual Weapon), Close Woundsx2SC, Eagle's Splendorx2, Extended Divine Favorx2, Hold Personx2
[7+1/day]3: (AfflictionBoED), Cure Serious Woundsx2, Prayerx2, RefreshmentBoEDx2, Telepathy TapBoED. S(1d3 str).
[7+1/day]4: (Radiant ShieldBoED), Blood of the MartyrBoED, Dimensional Anchorx2, Extended Prayer, Freedom of Movementx2, Stars of ArvandorBoED.
[7+1/day]5: (Righteous Might), Dancing WebBoED, Extended Freedom of Movement, Greater Commandx4, Sacred GuardianBoED.
[5+1/day]6: (Extended Righteous Might), Antilife Shell, Healx3, Extended Righteous Mightx2.
[5+1/day]7: (Power Word Blind), Extended Exalted RaimentBoED, S(1d4 str), Fortunate Fatex4SC.
[6+1/day]8: (Power Word Stun), Consecrated Radiant Assaultx4, Extended Fortunate Fatex3, Lion's Roarx2SC.
[6+1/day]9: (Foresight), Consecrated Fire Stormx2, Mass Healx3, Miracle, Righteous Exile.
[2+1/day]10: (Extended Storm of Vengeance), Cleansing RainHome, S(1d4 str), Mass Freedom of MovementHome, Summon Monster XHome
BoED - Book of Exalted Deeds.
FC2 - Fiendish Codex 2.
S - Sanctified spell. Sacrifice cost is noted in parentheses.
SC - Spell Compendium.
Hanna casts as an 13th level Champion of Gwynharwyf. The save DCs are 19 + spell level. Her spell theme is anything that helps while in a rage. Her metamagic options are Extend Spell (+1) and Consecrate Spell (+1)
[5/day]1: Divine Sacrificex5BoED
[4/day]2: Shield Otherx2, Warcryx2BoED
[4/day]3: Cure Moderate Woundsx4
[3/day]4: Break Enchantmentx2, Glory of the MartyrBoED.
[2/day]5: Cure Critical Woundsx2
Always active: Greater Mage Armor, Superior Resistance.
3/day-charm person, deep slumber. 1/day-burning hands, elemental swarm(fire only), fire seeds, fire shield, firestorm, flaming sphere, incendiary cloud, plane shift(fire only), produce flame, suggestion, wall of fire. Caster level 22nd. The save DCs are 19 + spell level.
Simmer casts as a 22nd level sorcerer. (Caster level 30th for lingering flames; caster level 28th for fire descriptor spells; caster level 23rd for other spells. +2 caster level bonus to overcome spell resistance.) Her spell DCs are 19 + spell level. (DC 20 + spell level for fire descriptor spells.) Her metamagic options are Searing Spell (+1), Fiery Spell (+1), Empower Spell (+1) and Maximize Spell (+2). All metamagic costs are reduced by 1 (minimum 1) for lingering flames. Simmer may 3 times per day apply maximize spell to any spell through her metamagic rod. Simmer heals a number of hit points equal to the spell level when she casts a spell with the fire descriptor. Simmer's spells with the fire descriptor set opponents ablaze, dealing 1d6 fire damage per round. Simmer may nine times per day declare a fire descriptor spell overwhelming, which renders a target dazed for one round if they fail the save. Simmer may seven times per day declare a spell that deals damage a battle spell, adding 3 points of damage per die of the spell. With her mystic fire gauntlets, 3 charges per day, swift action, add 2d6/3d6/4d6 bonus fire damage to a fire spell you cast.
[6/day]0: Acid Splash, Arcane Mark, Detect Magic, Detect Poison, Flare, Light, Mending, Prestidigitation, Touch of Fatigue.
[9/day]1: Blades of FireSC, Detect Secret DoorsFB, Lesser Orb of FireSC, Raging FlameSC, Ray of FlameSC, Shield.
[8/day]2: Boiling BloodCM, CombustSC. FireburstSC, GlitterdustFB, ScorchSC, Scorching Ray.
[8/day]3: Body BlazeSS, Fireball, Gaseous Form, Greater Mage ArmorSC, TonguesFB.
[8/day]4: Assay Spell ResistanceSC, Channeled PyroburstPHB2, Firestride ExhalationCM, Hallucinatory TerrainFB, Incendiary SurgeCM.
[8/day]5: Earth ReaverSC, Greater FireburstSC, Mage's Faithful Hound, Planar ToleranceSC, SeemingFB
[7/day]6: Fires of PuritySC, Lingering FlamesCM, MisleadFB, Superior Resistance.
[7/day]7: Delayed Blast Fireball, Greater Teleport, SequesterFB, Summon Monster 7.
[7/day]8: Greater Arcane FusionCM, Horrid Wilting, Irresistible DanceFB, Simmer's SurpriseHome
[7/day]9: Deadly SunstrokeCM, ForesightFB, Transmute Rock to LavaSC, Wish.
[0/day]10: Simmer's Contagious FireburstHome, True Meteor StormHome
CM - Complete Mage.
FB - Bonus spell from Fey Bloodline.
Home - Homebrew.
PHB2 - Player's Handbook 2.
SS - Sandstorm.
[/quote]
[/quote]
[/quote]
[/quote]
Move action concealed by ground (can't AoO unless they can easily see me and punch through the ground), free action, and standard action.
Tryll flows through the ground the remaining 50 feet, rising from the ground amidst the party as a globe of light. He addresses the party, 'The mercenaries have been extracted to Elysium, and we are ready to leave when you are done having fun.' As he says this, a burst of negative energy explodes from a nearby group of demons and flyers, a pillar of night-black flames whirling around them and up into the sky.
Stygian Conflagration
1d4 negative levels. No save to resist, but SR applies.
15 ft. wide by 40 ft. tall.
Requested rolls:
1d20+25+2 to beat SR
1d4 negative levels
Tryll
HP: 237
AC: 45
Touch AC: 28
Flatfooted AC: 39
Active Effects: Inertial Armor (Extended, CL 25), Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 24), Detect Psionics (CL 25)
PP: 473
Calleigh
HP: 118
AC: 47
Touch AC: 25
Flatfooted AC: 36
Active Effects: Inertial Armor (Extended, CL 25), Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Detect Psionics (CL 25)
Psicrystal
HP: 118
AC: 31
Touch AC: 14
Flatfooted AC: 29
> roll 1d20+25+2 to beat SR
<Serith> Iddy roll for Serith < 28 > [d20=1]
> roll 1d4 negative levels
<Serith> Iddy roll for Serith < 2 > [d4=2]
/quit
The demons are enveloped. Some resist and others wither under the storm, as Moonlight holds. 'Fine, open a portal already!'
'On it," Hanna says, 'Be ready, I'll miracle us out of here! Everyone be close!'
Moonlight holds.
Demons everywhere. A haze of dark energy rips through all of you, like a tornado wave.
> roll 1d20+24 combined demonic energies SR
<Serith> Sunshine_Ko roll for Serith < 27 > [d20=3]
> roll 1d100 Tryll incorpreal, 51+ beats it if he doesn't have SR that stops it anyway
<Serith> Sunshine_Ko roll for Serith < 44 > [d100=44]
Hanna's SR holds. Tryll's incorporeality holds. Simmer and Moonlight need Will saves.
> roll 1d20+28 SImmer (+4 celestial valor)
<Serith> Sunshine_Ko roll for Serith < 31 > [d20=3]
> roll 1d20+36 Moonlight (+4 celestial valor, +4 occult slayer)
<Serith> Sunshine_Ko roll for Serith < 50 > [d20=14]
> roll 20d10 Simmer full Moonlight half
<Serith> Sunshine_Ko roll for Serith < 116 > [d10=6,8,7,6,6,7,5,10,2,5,5,10,5,5,5,3,4,5,5,7]
> roll 2d4 rounds sickened Simmer only
<Serith> Sunshine_Ko roll for Serith < 6 > [d4=3,3]
Simmer looks weak and pale afterwards, coughing up blood as she staggers. "Shit!"
Moonlight bears it better, as demons clash all around you, clawing at the three of them.
<Serith> Sunshine_Ko roll for Serith < 2, 19, 5, 6, 10, 20, 6, 3, 19, 17, 13, 9, 2, 3, 5, 3, 18, 16, 9, 18 >
> roll 1d3 1 Hanna 2 Moonlight 3 Simmer
<Serith> Sunshine_Ko roll for Serith < 2 > [d3=2]
> roll 1d20 crit confirm
<Serith> Sunshine_Ko roll for Serith < 16 > [d20=16]
> roll 2d8+17
<Serith> Sunshine_Ko roll for Serith < 31 > [d8=7,7]
In the chaos that follows, a bloated mane leaps onto Moonlight's front and bites her neck, torn off as she raggedly bleeds. "Ugh! Hurry!"
Simmer falls to her knees, sick. As she vomits blood, she grabs a wicked looking longbow with one hand and a heavy shield with another, breathing heavily.
Simmer is ready to go. Calleigh's up.
Moonlight
HP: 218/414
Hanna
Simmer
HP: 175/333
CM - Complete Mage.
Home - Homebrew.
SS - Sandstorm.
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Tryll flexes his brain, manifesting a barrier around the group as the power washes over them!
Intellect Fortress up as an immediate action! Link
Calleigh joins the group the same way Tryll did. "Everybody ok? Healing?" Calleigh brandishes a wand at Moonlight.
Cure Critical, 4d8+10
[18:50] <@Ebiris> roll 4d8+10
[18:50] <Serith> Ebiris roll for Serith < 32 > [d8=5,8,6,3]
Moonlight's wounds heal as Hanna kicks a vrock back and quickly calls out, "Gwynharwyf!" That single word seems to express it all, as the demons reel back in terror. It's the last thing you see here, as reality blurs and you stand before Aurora, safe and sound. Whew!
You made it. Simmer's panting in pain, but holds shield and longbow. "Even..." she looks up, "Got some treasure out of it."
Free act, loot post incoming.
Moonlight
HP: 252/414
Hanna
Simmer
HP: 175/333
CM - Complete Mage.
Home - Homebrew.
SS - Sandstorm.
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Calleigh's response is to blast Simmer with healing too. Right in the face!
4d8+10
[14:01] <Nephrite> roll 4d8+10
[14:01] <Serith> Nephrite roll for Serith < 29 > [d8=2,2,8,7]
"Let's go see if we can find Moonlight's Mercenaries!"
"T-thanks," Simmer says, wounds healing further. "Elysium should take care of the rest."
"Whew, that was close," Moonlight exhales, "Those demons just appeared out of nothing. No idea how they found us, but they did."
Fast healing 2 due to Elysium, so any injuries are going to mend automatically anyway.
"Weeeeeee...mighta set them off when we started gating out the guys. Or maybe it was the tunneling. Either way, we probably started it. Sorry." Calleigh looks contrite.
"Whatever, they're demons," Moonlight says, "Let's go find them!"
They aren't far. They're gathering perhaps a mile away, getting their hastily tossed through things together and having a meal. The iron masked man approaches all of you, "Moonlight," he greets, only to be stopped by Moonlight running up and hugging him.
"Idiot!" she scowls, giving his chest a fist pound. "You could have asked for help sooner, like before I just happened to message you!"
