The four of you gather around Thurra circle, ready to go and equipped. "I'll take you there, aim for [garbled word] and close your eyes. Open them when I say you can."
"She's telling the truth," Sylvie says, "I've made sure that she knows that she can't lie to us and what will happen if she tries it."
I'm assuming I've attached everyone to my Tapestry?
Surraruthru nods to Sylvie as he curls around Kascha's shoulders. "Thank you, Sylvie. Let's see what unpleasant things are in store for us today."
Certainly. Going to fire off any spells before you go?
#289
Yep. Spoiler'd 'cause of wall o text.
Level 3:
Mage Armor, Greater: CL 25, Duration: 25 hours
+6 armor bonus to AC.
Battlemagic Perception (Self only): CL 25, Duration 250 minutes
+5 competence on Spellcraft check to identify spell being cast, If you have at least 5 ranks in Spellcraft, you are also able to sense the use of any spell or spell-like ability within 100 feet, so long as you have line of effect to the caster. With a Spellcraft check (DC 15 + spell level) you can even ascertain the spell being cast. This determination happens quickly enough that you can attempt to counter the spell as a free action.
Level 4:
Stoneskin: CL 28, Duration: 280 minutes
Gain damage reduction 10/adamantine. Once the spell has prevented a total of 10 points of damage per caster level (maximum 150 points), it is discharged.
Level 7:
Spell Turning: CL 28, Duration: 280 minutes
Level 8:
Moment of Prescience (Self only): CL 25, Duration: 25 hours
This spell grants you an insight bonus equal to your caster level (maximum +25) on any single attack roll, opposed ability or skill check, or saving throw. Alternatively, you can apply the insight bonus to your AC against a single attack (even if flat-footed).
Mindblank (Self only): CL 28, Duration: 24 hours
Also, are you going to include Thurra in your tapestry?
Kascha
HP: 271+11/271
Spells Active: Mind Blank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Superior Resistance (CL25), Stoneskin (CL28), Spell Turning (CL28)
Bonuses: +1 morale attack/will saves, immunity to poison and disease
Sylvie
HP: 305+17/305
Spells Active: Mind Blank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Greater Mighty Wallop (CL23), Endure Elements (CL23), Overland Flight (CL23), Stoneskin (CL28), Spell Turning (CL28)
Bonuses: +1 morale attack/will saves, immunity to poison and disease, damage reduction 10/adamantine
Ebony
HP: 256+16/256
Spells Active: Mind Blank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Stoneskin (CL28), Spell Turning (CL28)
No, not connecting her to it.
Surraruthru
HP: 296+12 (150HP 10/adamantine)
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Stoneskin (CL28), Spell Turning (CL28)
Passive: Improved Evasion, Diamond Body, True Seeing
You close your eyes and vanish. It's hot here, unpleasant and stuffy. The air smells of rot and dust, like a forgotten coffin. "Don't open your eyes yet, slowly turn to your left, all of you." Thurra says.
Surraruthru keeps his head trained on where Thurra's voice is coming from, ready to blast the area if need be, but otherwise remains on Kascha's shoulders.
Surraruthru
AC: 32+6
Kascha slowly turns until Thurra says, "Stop, it's safe."
"She's not lying," Sylvie says.
"Oh yes, it's safe," Kascha says, "We're on Niflheim."
"Whatever you do, do not look back," Thurra says, "You'll regret it."
Surraruthru opens his eyes, scanning in front of the group and the sides, but not looking back..
Ahead is wastelands - blasted olive trees, cracked ground and heat. It's Niflheim.
Ebony walks ahead at a brisk pace, Thurra leading the way. Sylvie does the same, "Whatever is behind there, it's something the 'loths did a long time ago. Thurra wasn't forthcoming with details, but they hid something precious."
"Hmm, something to look into after we finish our mission, then. First thing first, though. No use in wasting our strength right now. Thurra, any clues as to what we can expect from Secretus?"
"I've never been in his realm," Thurra admits, "I only know the way, who dares six valeoloths?"
"More truth," Sylvie adds as you hurry along.
"We do, apparently."
With that, Surraruthru remains quiet while they head towards their goal.
