#600
Surraruthru focuses again, this time on his Monk abilities. Doing so, he calls on his chaotic nature and takes up the Displacing Stance!
Displacing Stance:
50% miss chance, duration 7 rounds.
Surraruthru slips into his protections, shielding himself from the worst of it.  The bloated thing's flesh-nub that serves as its head splits open, green-black blood pouring down its body as a single hand reaches out from within. A moment later, hands erupt from everything - the floor, walls, ceiling, the brains themselves, the liquid that falls from them. Hundreds of hands, all reaching for Surraruthru.
Init is Surraruthru (25) > Bloated Nightmare (22) > Brains (8)
> roll 1d20+38 vs CMD of 42
<Kobot> Kotono rolled 1d20+38 vs CMD of 42 --> [ 1d20=16 ]{54}
> roll 1d100 51+ and Surraruthru is grabbed
<Kobot> Kotono rolled 1d100 51+ and Surraruthru is grabbed --> [ 1d100=69 ]{69}
All over. The hands grasp you all over, relentless. Rough hands, smooth hands, soft hands, grasping hands, cold hands. All grab you and refuse to let go.
You're grappled, Surraruthru. Go, you're up.
Also Surraruthru, have you been applying the 50% failure chance after casting Wish to teleport to the portal out?
I haven't, I totally forgot about that. Doesn't starting a grapple require a melee attack? Displacing Stance gives a 50% miss chance like Blur.
Surraruthru struggles against the hands.
It was, that's what the d100 after the attack roll was for.
You're trying to escape so make a CMB check.
> roll 1d20+26 Serith
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 30 > [d20=4]
No good. You're held tightly, firmly. As the brains continue to scream, the hands try to hold onto you and pummel you.
> roll 1d100 51+ means pain
<Kobot> Kotono rolled 1d100 51+ means pain --> [ 1d100=38 ]{38}
You begin to slip out of the hands as they can't keep a grasp on you. You struggle with them, avoiding harm, as the bloated nightmare before you lashes out with his whip again.
> roll 1d20+24
<Kobot> Kotono rolled 1d20+24 --> [ 1d20=3 ]{27}
You lose Dex to AC when grappling, so that hits.
<Kobot> Kotono rolled 1d100 51+ means pain --> [ 1d100=7 ]{7}
Lucky.
But you phase through the whip, your chaos monk training serving you well.
Still grappled, but you're avoiding the worst of it for now. Go.
Surraruthru tries to escape again.
> roll 1d20+26 Serith
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 41 > [d20=15]
No good. The hands have you securely and you just can't escape.
Anything else you can do? Trying to escape the grapple takes your standard and being grappled really stops you moving.
You struggle in vain, the hands grasping and pawing at you all over.
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 39 > [d100=39]
Fortunately, your stance holds, if just barely. You're able to evade just enough of them to keep from being choked out, as the bloated nightmare points at you with its third hand. Greasy, black and cloying darkness surrounds you, cold and warm at the same time.
> roll 1d20+15 SR
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 25 > [d20=10]
What's your SR, Surraruthru?
The magic washes over you, doing nothing as your defenses hold.
Go Surraruthru. Also note how many rounds of displacement you have left.
I'll note it in my stat block.
Surraruthru focuses on his magical energies again, hoping they don't fail him this time, and calling forth a cloud of death.
Cloudkill, CL 25.
> roll 1d20+34 Concentration
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 53 > [d20=19]
> roll 1d100 Spell Failure
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 9 > [d100=9]
Surraruthru
HP: 291/296
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Displacing Stance: 4/7 rounds, 50% Spell Failure
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Moment of  Prescience, Energy Immunity (Fire)
Argh! You focus but your magic is overtaxed, crumbling and failing. As you struggle in vain, the hands continue to grasp at you.
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 71 > [d100=71]
> roll 5d6+18
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 34 > [d6=3,6,3,1,3]
The hands rip you, choking you and raking at your scales. You suppress the pain through pure will, ignoring the bleeding as the bloated nightmare whips at you again.
> roll 1d20+24
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 37 > [d20=13]
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 3 > [d100=3]
But you slip away, phasing slightly as the whip goes through you harmlessly.
Go, Surraruthru.
