Jaela: getting stuff done (Jaela)
Started by Anastasia, September 29, 2016, 05:04:15 PM
Okay, so basically flying an inch or two off the ground at most? Doable.
Paste me the details on your glow real quick?
The relevant part is 'as if daylight was cast' on me. I'll drop the anti-devil glow.
Please paste it when you get home, I'll check it during B5. I need to check something in it, that's all.
Righteous Halo [Transmutation, Good/Light]
Righteous Halo
Transmutation [Good, Light]
Level: Clr 8
Components: V, S, DF
Range: Personal
Target: You
Duration: 1 hour/level (D) or until discharged
Holy light washes over you as you call upon your patron deity's power. This nimbus of divine power coalescing around your form shines brightly, as if daylight had been cast upon your person.
You get a +4 sacred bonus to your Charisma score.
As an immediate action, you can discharge the magic to gain a +8 Sacred bonus to Charisma for 1 round. The spell ends after you use it in this manner.
Divine Focus
The holy symbol of your deity.
Thank you.
You appear amid obsidian and ruin. Fields of cracked, jagged obsidian are ahead. The sky is an inferno, the heat here merely unnatural rather than overwhelming. Smoke rises from cracks in the ground to the sky, somewhat obscuring vision ahead.
#125
Jaela scoops Mei into her arms and gestures ahead. "That's the direction I was aiming for," she says, after orienting herself briefly, "so let's get going!"
K:P take 10 for 60 to orient myself properly. Dana goes first, I'm right after her while reducing my glow, and the Master brings up the rear. Double move, so we go at her speed and cover 180ft per round?
#126
Precasting Foresight. By a rough estimate it'd take us half an hour to cross the distance at our speed?
Hit Dice 20+497/497hp [+24hp with Righteous Might, +48hp with Holy Transformation, +24temp hp with Divine Power]
Init: +17 (Sign precast)
Detection: Blindsight 60ft, Darkvision 60ft, Listen +10, Spot +14 (+15 with Divine Insight)
Speed: 40ft (land)/120ft (flight, perfect maneuverability) [10ft enhancement from Longstrider]
Armor Class: 59 touch, 71 vs incorporeal, 77 normal, 20% miss chance. [21 from dex and cha/-21 when flat footed, 10 armor from Millennial Chainmail/Magic Vestment (Ethereal armor), light armor, 6 from natural armor, 7 shield from animated shield/Magic Vestment (5/enhancement bonus to touch AC), 2 from Foresight, +3 luck from Recitation, 20 force from epic mage armor, +5 sacred with Shield of Warding, +3 luck from Recitation, +1 from Haste, +4 from Celestial Valor]
BAB/CMB/CMD: +22/+31/73
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +51/+51/+46/+41/+36, 2d8+40+10d6, x3/20, 10ft [+2 damage vs DR/silver, +2d6 vs undead, +1d6 vs incorporeal/gauntlets, +14 Divine Might, +3 luck from Recitation; silver+good+anarchic+epic]
Full Attack (Gae Trocaire, GMW, Haste, HW): +42/+42/+37/+32/+27, 1d8+31+1d6 non-lethal, x3/20, 10ft [+2 damage vs DR/silver, +1d6 vs incorporeal/gauntlets, +2d6 from celestial brilliance, +14 Divine Might, +3 luck from Recitation; piercing/bludgeoning/slashing/silver/bypasses any DR next round after successful hit for 10 rounds]
Ray Attack: +35
[+3 Recitation not counted, +4 Celestial Valor not counted, +4 Greater Heroism not counted, +5 Holy Warrior not counted]
Resistances and Immunities: Fire Resistance 10, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 10, Damage Reduction 20/Epic and Evil and Cold Iron, Spell Resistance 34 (43 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Foresight/not surprised or flat-footed.
Saves: Fort +55, Ref +49, Will +55 [Counted: Conviction +5 to each save, Foresight +2 to Ref; Not counted: Celesial Valor +4 to each save, Greater Heroism +4 to each save, Recitation +3 to each save]
Precast/Bead of Karma: Contingency/Righteous Might when Jaela casts Holy Transformation CL30, Energy Immunity/Cold CL30, Permanency/Greater Blindsight CL30 [Blindsight for 60ft], Permanency/Mantle of Good CL31, Permanency/Prestidigitation CL30, Extended Lore of the Gods CL30 (10hr duration), Righteous Halo CL30, Longstrider CL25, Moment of Prescience CL25
Precast: Energy Immunity/Fire CL26, Epic Mage Armor CL24, Fortunate Fate CL24, Conviction CL24, Sign CL24, Divine Insight CL24, Spell Turning CL24, Heroes's Feast CL20, Control Water CL18, Mind Blank CL17, Planar Tolerance CL7, GMW CL26/Gae Bolg, GMW CL26/Gae Trocaire, MV CL27/Millenial Armor, MV CL27/Shield, Foresight CL23.
Favored Soul slots left, 01-11: 9/2/0/0/7/3/4/6/7/1/4
CL 26 Favored Soul, CL 21 Divine Crusader [+2CL untyped War domain, +1CL competence Force, +1CL untyped Protection domain, +1CL untyped Abjuration]
Spell/SLA DC: 24 + spell level
14/17 Turning left
The scythe is a scythe+2, keen and frost.
"Let's go!" Dana says, gliding along the ground as Mei curls up in your arms. Her gaze is everywhere as she keeps a close watch.
> roll 1d100+40
<Kobot> Kowork rolled 1d100+40 --> [ 1d100=15 ]{55}
> roll 1d100+50
<Kobot> Kowork rolled 1d100+50 --> [ 1d100=32 ]{82}
> roll 1d100+60
<Kobot> Kowork rolled 1d100+60 --> [ 1d100=93 ]{153}
> roll 1d20+40
<Kobot> Kowork rolled 1d20+40 --> [ 1d20=11 ]{51}
Spot for the Master, as he has the highest check here, more than outdoing any penalty for being a bit behind all of you.
You cover a mile and a half before the Master calls, "I see the enemy far ahead, and I fear they've noticed us," he says, "They move with determination and direction."
Dana
HP: 324+18/324
Bonuses: +1 morale attack rolls and Will saves, immunity to poison and disease
Resources Used: 262/262 Power Points
The Master
HP: 304+12/304
Mei
HP: 457+23/457
Spell-like abilities
1/day-daylight. Caster level 22nd. The save DCs are 16 + spell level.
Dana manifests as a 22nd level psychic warrior. The save DCs are 17 + power level.
Power points: 262
[1 pp]1: Defensive PrecognitionA, Offensive PrescienceA, VigorA.
[3 pp]2: Body AdjustmentA, Dimension SwapA, Strength of My EnemyA.
[5 pp]3: Breath BarrierA, Dimension SlideA, Greater Concealing Amorpha.
[7 pp]4: Energy AdaptationA, Psionic Freedom of Movement, Steadfast Perception.
[9 pp]5: Empower Weapon, Oak BodyA, Perfect RiposteA
[11 pp]6: Breath of the Black DragonA, Form of DoomA, Inconstant LocationA, Personal Mind Blank, Stygian TouchA
[13 pp]7: Dana's AdjustmentA, Dana's CounterA
A - Power can be augmented.
Dana manifests as a 1st level ardent with access to the pain + suffering and physical power mantles. The save DCs are 17 + spell level.
[1 pp]1: Adrenaline BoostA, DisableA
Mei casts as a 12th level paladin. Her spell DCs are 21 + spell level. Her spell themes are protection and boosting.
Check spells per day.
[4/day]1: Divine Favor, True Strike, Lesser Restorationx2
[4/day]2: Divine Protectionx4SC
[4/day]3: Righteous Furyx4SC
SC - Spell Compendium.
Mei uses invocations as a 23rd level warlock.
Least: All Seeing Eyes, Eldritch Glaive, Otherworldly Whispers.
Lesser: Baneful Blast(Evil Outsiders), Celestial Flight, Eldritch Chain, Spirit Blast, Wall of Light.
Greater: Eldritch Cone, Heavenly Endurance, Penetrating Blast, Vitriolic Blast.
Holy: Caster's Lament, Eladrin Form, Impenetrable Barrier, Steal Summoning.
Epic: -
[/quote]
[/quote]
[/quote]
Jaela sets Mei down and casts Good Hope on all of them, letting the Master and Dana take the lead. Mei will strike at range, outside the immediate melee, while Jaela herself will preempt any magical attacks and judge the level of the opposition they're likely to face for the rest of the approach.
Good Hope CL26 for all, you also missed Energy Immunity/Fire CL26 for all earlier. Master and Dana take the lead, I'll be fifty feet behind and Mei five feet behind me.
Ray Attack: +35
[+2 attack/damage Good Hope not counted, +3 Recitation not counted, +4 Celestial Valor not counted, +4 Greater Heroism not counted, +5 Holy Warrior not counted]
Saves: Fort +55, Ref +49, Will +55 [Counted: Conviction +5 to each save, Foresight +2 to Ref; Not counted: Good Hope +2 to each save, Celesial Valor +4 to each save, Greater Heroism +4 to each save, Recitation +3 to each save]
Precast: Energy Immunity/Fire CL26, Epic Mage Armor CL24, Fortunate Fate CL24, Conviction CL24, Sign CL24, Divine Insight CL24, Spell Turning CL24, Heroes's Feast CL20, Control Water CL18, Mind Blank CL17, Planar Tolerance CL7, GMW CL26/Gae Bolg, GMW CL26/Gae Trocaire, MV CL27/Millenial Armor, MV CL27/Shield, Foresight CL23, Good Hope CL26.
Favored Soul slots left, 01-11: 9/2/0/0/6/3/4/6/7/1/4
14/17 Turning left
You can distantly see them now. 500ft ahead and closing in as everyone takes position. A great chariot with two efreeti riders, each one pulled by four hellhounds, each large as a warhorse. It's coming right your way.
"Here we fucking go!" Dana calls, then shouts, "Over here, you limp dicked motherfuckers!"
Init.
Dana
HP: 324+18/324
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Energy Immunity (Fire) (CL26), Good Hope (CL26)
Bonuses: +1 morale attack rolls and Will saves, immunity to poison and disease, +2 morale to attack rolls, weapon damage rolls, skill checks, ability checks and saving throws.
The Master
HP: 304+12/304
Mei
HP: 457+23/457
Power points: 262
Epic: -
[/quote]
[/quote]
[/quote]
[/quote]
[17:57] <Annerose> roll 1d20+17 Sign
[17:57] <Kobot> Annerose rolled 1d20+17 Sign --> [ 1d20=5 ]{22}
> roll 1d20+5
<Kobot> Kowork rolled 1d20+5 --> [ 1d20=8 ]{13}
> roll 1d20+9 Master
<Kobot> Kowork rolled 1d20+9 Master --> [ 1d20=12 ]{21}
> roll 1d20+12 Mei
<Kobot> Kowork rolled 1d20+12 Mei --> [ 1d20=10 ]{22}
> roll 1d20+10 Efreet 1
<Kobot> Kowork rolled 1d20+10 Efreet 1 --> [ 1d20=1 ]{11}
> roll 1d20+10 Efreet 2
<Kobot> Kowork rolled 1d20+10 Efreet 2 --> [ 1d20=8 ]{18}
> roll 1d20+9 hellhounds
<Kobot> Kowork rolled 1d20+9 hellhounds --> [ 1d20=17 ]{26}
Init is Hellhounds (26) > Jaela = Mei (22) > Master (21) > Efreet 2 (18) > Dana (13) > Efreet 1 (11)
Hellhounds open.
The chariot rushes ahead over the broken terrain, clearing 200ft in moments. It's only 300ft away now. You can see the turbans of the efreet, as well as the tight vests and flowing pants they wear. Each has a scimitar on their belt and a considerable amount of jewelry.
Go Jaela. Mei will hold pending what you do.
Jaela is briefly tempted to seize the chariot for herself and arrive in style, but dismisses the idea. Even if she knew how to ride or tame the hellhounds, there might be nasty surprises in the chariot itself. It's just too much hassle, overall. That, however, alerts her to how annoying it would be if she had to chase it down and so Jaela materializes two phantom spears that each strike a hellhound!
Spiritual Weapon as swift, Spiritial Weapon as standard.
[18:22] <Annerose> roll 1d20+32 hellhound 1
[18:22] <Kobot> Annerose rolled 1d20+32 hellhound 1 --> [ 1d20=10 ]{42}
[18:22] <Annerose> roll 1d20+32 hellhound 2
[18:22] <Kobot> Annerose rolled 1d20+32 hellhound 2 --> [ 1d20=12 ]{44}
[18:22] <Annerose> roll 1d8+5 force, hellhound 1
[18:22] <Kobot> Annerose rolled 1d8+5 force, hellhound 1 --> [ 1d8=4 ]{9}
[18:22] <Annerose> roll 1d8+5 force, hellhound 2
[18:22] <Kobot> Annerose rolled 1d8+5 force, hellhound 2 --> [ 1d8=6 ]{11}
Forgot Knowledge Devotion and Good Hope there, so +7 to attack and +7 to damage.
Ray Attack: +35
14/17 Turning left
Serious question, do you have the CL to do that? They're 300ft away and spiritual weapon is 100ft + 10ft/level.
