Surraruthru and spellhoarding (Surraruthru)
Started by Anastasia, February 22, 2017, 02:44:16 PM
So that I'm clear: You move back with the teleport and then cast time stop as your standard?
You weave magic around yourself with every second of super speed you have. Protections are formed around you, as you note from this far away you can't see the dragon in the ever-present void. Whatever it's doing, you can't see.
Go.
Surraruthru cautiously begins chanting again, pulling on his magic for another spell!
Still on the ropes here, so I need to make up some effort:
Casting Time Stop, CL 26.
> roll 1d4+1
<Serith> Iddy roll for Serith < 3 > [d4=2]
Round 1: Summon Monster IX, CL 26
Target: Hollyphant, SM8.
> roll 1d3
<Serith> Iddy roll for Serith < 1 > [d3=1]>
Summon in Alternate Form for Globe of Invulnerability effect.
Round 2: Summon Monster IX, CL 26 (SLA)
> roll 1d3
Round 3: Might of the Planetar, CL 26, Duration 26 Rounds
+16 enhancement bonus to Strength, a +2 enhancement bonus to Dexterity, a +8 enhancement bonus to Constitution, and a +7 enhancement bonus to natural armor. You gain a slam attack that inflicts 2d8 + 1.5 times your Strength modifier. You gain the benefits of the blind-fight and power attack feats as well.
Minor note: d20 SRD says that summons act immediately on your turn. Is that the current turn or next turn? Essentially, can I have them heal me as soon as Time Stop ends?
Surraruthru
HP: 105+20/347
AC: 70=38+4+20+1+7 (Deflection/EMA/Dodge/MotP(NA))
Init: +13, Touch/Atk: 38/42+5
Active: Epic Mage Armor (CL26), Superior Mighty Wallop (CL26), Greater Heroism (CL26), Elemental Body: Fire (CL26), Might of the Planetar (CL26)
#185
"Hollyphants, keep me healed!"
In response, the Hollyphants focus their magical abilities on Surraruthru!
Using CL 2 here as Cleric 2 is the lowest for availability for CMW, and I didn't see any CL entry for them in BoED.
> roll 2d8+2 CMW #1
> roll 2d8+2 CMW #2
<Serith> Iddy roll for Serith < 9 > [d8=2,5]
<Serith> Iddy roll for Serith < 10 > [d8=7,1]
Ain't much, but I'm hoping it's enough to survive the next round and get fully set up.
Edit: +8 additional healing on each.
Surraruthru
HP: 140+20/347
A few things.
1. The lowest CL for a typical cleric to use CMW is 3, not 2. It's a 2nd level spell, which clerics get access to at caster level 3.
2. The SLA block mentions the caster level at the end of the SLA block. It's 15th. Ergo the heal 2d8+10 damage with it (the maximum), so that's an additional 8 points of healing per cast.
3. Considering the bloated SLA CL, trumpet's issues and a few other things, I may revise hollyphants for this campaign later. So keep that in mind if you're planning to summon them in the future. It won't matter for this battle.
You summon and heal. As your wounds recover, you see it coming. A virtual streak of red, the dragon coming your way in a blur. It's burst aflame and is like a meteorite from the heavens, only bigger and meaner.
Reflex save, all three of you.
> roll 1d20+29+4 Ref Save
<Serith> Iddy roll for Serith < 52 > [d20=19]
> roll 1d20+6 Hopllyphant 1
> roll 1d20+6 Hopllyphant 2
<Serith> Iddy roll for Serith < 12 > [d20=6]
<Serith> Iddy roll for Serith < 18 > [d20=12]
Do you have evasion, Surraruthru? If you do, note it in your save.
I do. Improved Evasion. I always forget to annotate that.
Please remember, since I could easily forget and you get hammered by avoidable damage.
> roll 24d10+4d8+34 Surru none, hollyphants full
<Serith> Space_Cat roll for Serith < 188 > [d10=9,6,7,3,8,9,1,5,7,7,10,8,6,10,7,1,3,1,3,6,4,4,3,7][d8=4,6,1,8]
Hollyphants are fried.
> roll 1d4+1 recharge breath weapon
<Serith> Space_Cat roll for Serith < 5 > [d4=4]
Tough luck.
Surraruthru dives out of the way out of sheer instinct. He avoids the bulk of it and is instead able to ride the pressure wave out of the way, while the hollyphants are simply obliterated. There's nothing left of them when the dragon's passed - it's now 100ft behind you and turning in light, making a wide loop to come back this way.
Go.
Surraruthru decides to show the larger dragon the same kind of pain he's dished out so far and begins casting!
Queens Displeasure, CL 26, Instant.
> roll 1d20+26+9+10 Queen's Displeasure
<Serith> Iddy roll for Serith < 55 > [d20=10]
> roll 26d8
<Serith> Iddy roll for Serith < 118 > [d8=4,8,8,5,7,1,3,7,4,8,3,5,7,3,7,3,1,3,8,2,2,6,1,3,6,3]
Note that Aligned Spellcaster gives it +1 CL vs Evil Alignment, in which case it gets +1 to attack and an additional 1d8 damage.
Surraruthru
HP: 140+20/347
Quick question: Is that a regular or touch attack?
