Surraruthru and spellhoarding (Surraruthru)
Started by Anastasia, February 22, 2017, 02:44:16 PM
This blade makes a single melee attack with an attack bonus equal to the caster's caster level + main spellcasting stat ability modifier + 10
Regular, I believe.
Thanks.
The created gash of force slices deep into the red dragon's scales, leaving its side bleeding blazing blood. That doesn't stop him, however, and he's coming right back around. He barrels full into you, teeth first.
> roll 1d20+49 (-10 PA) vs AC 70
<Serith> Space_Cat roll for Serith < 63 > [d20=14]
So girded, Surraruthru trusts in his mage armor. It's enough - the maw surrounds him again, but a field of force stops it from closing. It glows dark blue on both ends, the mage armor stressed. It gives you enough time to fly out, avoiding the bite as the dragon glides past. As it glides past, its tail whips out, a bevy of gleaming magic missiles pummeling you from the tip of its tail.
> roll 10d4+10
<Serith> Space_Cat roll for Serith < 34 > [d4=4,2,3,2,4,1,2,1,3,2]
Note if you have something up that stops magic missiles.
As you're hit, the dragon goes about 120ft to the other side of you, hazy and indistinct in the void, only semi visible.
Go. Dragon has concealment.
I don't. From watching it fly away and get hazy, do I know about how close I have to be to see it clearly?
You were able to see him clearly at 100ft, so no more than 20ft, unless it's something localized or an effect it made somehow.
#199
Surraruthru uses his boots to teleport above the other dragon, at a distance of 100 ft so he can clearly see his target, and begins casting again! If pure offense is how he wants to play it, he'll race him!
Hellball, CL 26
> roll 10d6 fire
> roll 10d6 sonic
> roll 10d6 acid
> roll 10d6 electricity
<Serith> Iddy roll for Serith < 43 > [d6=5,4,1,6,3,5,6,3,6,4]
<Serith> Iddy roll for Serith < 32 > [d6=1,1,3,3,1,3,5,3,6,6]
<Serith> Iddy roll for Serith < 48 > [d6=5,4,6,5,1,6,6,3,6,6]
<Serith> Iddy roll for Serith < 39 > [d6=6,4,1,2,6,5,5,2,6,2]
Edit: Forgot this originally, figured it'd be called for.
> roll 1d20+26 SR
<Serith> Iddy roll for Serith < 40 > [d20=14]
Surraruthru
HP: 126/347
AC: 70=38+4+20+1+7 (Deflection/EMA/Dodge/MotP(NA))
Init: +13, Touch/Atk: 38/42+5
Active: Epic Mage Armor (CL26), Superior Mighty Wallop (CL26), Greater Heroism (CL26), Elemental Body: Fire (CL26), Might of the Planetar (CL26)
> roll 1d20+25
<Rei-chan> Space_Cat rolled : 1d20+25 --> [ 1d20=4 ]{29}
The dragon's sheer flames counter some of the spell, but you see it shocked and sizzled. Somehow that only seems to enrage it more, as it stays back and...
> roll 1d4+1
<Rei-chan> Space_Cat rolled : 1d4+1 --> [ 1d4=4 ]{5}
When you blink again, the dragon is gone. Where is it?
Go. You can Spellcraft what it did if you like.
> roll 1d20+37 Spellcraft Serith
<Serith> Iddy roll for Serith < 49 > [d20=12]
It was time stop. The dragon could be anywhere and had a chance to prepare itself for the battle.
Surraruthru begins casting, holding his position, and calling on his magic to generate a protective field!
Wall of Force (Sculpt Spell), CL 26, Duration 26 rounds
260 sq/ft area; Arrange the squares to form a cube with one hole/murder hole in the center of each side to either fire spells through or teleport out of.
Surraruthru
HP: 126/347
Uh, well, I'm not sure on the physics of magic here, but I'd keep them as small as I possibly can while still allowing myself to teleport out and launch spells through. I dunno how much magic expands at what rate in what distance from the point of magical focus/casting, but I guess that can technically be bypassed by the fact that you can change the point of launching the spell and just like... Stick a claw or the tip of my tail out of the hole.
Let me look up the relevant things.
1. Wall of force doesn't expand. It takes a shape as described in the spell. Read that for information on how you can shape it, bearing in mind sculpt spell is a thing.
2. As the wall is 10ft/square increments, that would be the minimum hole size before sculpt spell. Reading that, it doesn't meaningfully change it. While the dragon could breathe into it, the size of the creature prevents natural attacks from getting through.
That's fine. That's more than enough space for me to work with. Though I can technically make that opening smaller by keeping the interior room as small as possible and laying the outside walls with an offset, but that's WAY to much effort for this. As it is, as long as I can duck into a corner for cover, I'm good.
By the expansion thing, I meant spells that I throw out of it. Like Hellball is a 40 ft. diameter. I dunno if it needs space/distance to expand or if it expands as it travels.
It doesn't expand until it hits. Anyway, that it for your turn?
Besides being paranoid and looking around for it, just taking cover to block spells and stuff.
