Jaela nods, touching down next to Mirima. "I'm thinking we don't have much of a choice. I can't challenge that sort of reach without a lot of preparation, and anything I summon won't last for the hours we'll need to get through this. Let's play it conservatively and avoid wasting our spells if we can help it?"
"Our enemies are proving to be formidable," Mirima agrees, "I will follow your lead."
Mirima
HP: 307/307 (fast healing 3)
Bonuses: +1 morale attacks/will, immunity to fear and poison
Resources Used: 4 4th level spell
Golden Bracers (Hidden Dawn): Ranks are unlocked by using them in battles of the appropriate CR or higher. Multiple ranks can be unlocked in a particular battle if it meets the CR requirements and is particularly epic.
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane. <-- Current Rank
Jaela waits about a minute to make sure their innate magic brings them back up to speed, before setting off down the trail once more.
> roll 1d100
<Rei-chan> Kotono rolled : 1d100 --> [ 1d100=38 ]{38}
Make another Survival check.
You march along - and easily avoid more assassin vines and other such things. Going on, you can her the sound of water moving ahead. Only dimly for now, but unmistakably so.
"You hear that? Following a river should get us somewhere more interesting," Jaela suggests, moving towards the sounds.
Mirima nods, "Cities are built around water."
You approach. Ahed is a large lake, a river going from it. It moves fairly fast and the waters are dark.
"Keep an eye on the jungle," Jaela tells Mirima, taking out Gae Trocaire once more. "I'll take the river side."
We'll go side by side, with me closer to the river and 10ft away from it.
-1 lvl2 spell
-Flame Strike x1
-Foresight x1
-4 rounds of Haste
-Turning x1
Cool, gimme a new round of Spot and Listen checks, both of you.
Jaela casts Vision of the Omniscient Eye.
Then, takes 10 for Spot 34, Listen 22.
Mirima takes 10 for Spot 42, Listen 42.
Do you have any ranks in K:Dungeoneering?
Hm? You glance down and notice something. The pebble and river bed is right for there to be gold deposits in the river. Likely large and unexploited ones.
"Up for collecting some gold nuggets in the river?" Jaela tells Mirima, deciding to try her hand at it. With her supernatural perception she's unlikely to really be caught off guard, after all, so she could devote a couple hours to this and see how things go.
