Gar-Malleos
Magic swirls around the dragon - green beams of energy, before they surround him and a few of them dart out to lance Afina.
> roll 1d20+78 touch AC vs Afina
<Kobot> Kotono rolled 1d20+78 touch AC vs Afina --> [ 1d20=2 ]{80}
<Kobot> Kotono rolled 1d20+78 touch AC vs Afina --> [ 1d20=1 ]{79}
<Kobot> Kotono rolled 1d20+78 touch AC vs Afina --> [ 1d20=14 ]{92}
Miss chance?
> roll 1d100 vs 1
<Kobot> Kotono rolled 1d100 vs 1 --> [ 1d100=55 ]{55}
> roll 1d100 vs 3
<Kobot> Kotono rolled 1d100 vs 3 --> [ 1d100=5 ]{5}
> roll 10d8 1 gets through
<Kobot> Kotono rolled 10d8 1 gets through --> [ 10d8=45 ]{45}
HP?
Unless that's a damage type I immune, I'll spell-shield a 9th level slot to reduce the damage by 45.
Leaves me on 248 hp
Afina 248/329
active spells: glaciante's spiteful ward (CL 29 attached to nothing), haste (CL 27), scalding touch (CL 31)
defences: AC 73 (touch 61), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, blindsense 30, darkvision 60, spot +41, listen +41
spell slots: 6/9/8/9/2/7/1/6/1/4/5/2/2
The blast hits Afina but her shield stops it, leaving her intact as...
Round 2. Afina.
Undaunted, Afina zips back in for more, magically boosting her strikes now she knows better what sort of defences she's up against, and flying back out of melee range afterwards!
[20:07] <@Ebiris> roll 1d20+74 10th level arcane strike
[20:07] <Kobot> Ebiris rolled 1d20+74 10th level arcane strike --> [ 1d20=15 ]{89}
[20:07] <@Ebiris> roll 1d20+69 10th level arcane strike
[20:07] <Kobot> Ebiris rolled 1d20+69 10th level arcane strike --> [ 1d20=15 ]{84}
[20:07] <@Ebiris> roll 1d20+74 10th level arcane strike skirmisher's boots for extra attack
[20:07] <Kobot> Ebiris rolled 1d20+74 10th level arcane strike skirmisher's boots for extra attack --> [ 1d20=20 ]{94}
[20:07] <@Ebiris> roll 1d20+74 10th level arcane strike skirmisher's boots for extra attack crit?
[20:07] <Kobot> Ebiris rolled 1d20+74 10th level arcane strike skirmisher's boots for extra attack crit? --> [ 1d20=14 ]{88}
[20:08] <@Ebiris> roll 13d6+6d6+2d6+10d4+18
[20:08] <Kobot> Ebiris rolled 13d6+6d6+2d6+10d4+18 --> [ 13d6=46 6d6=32 2d6=5 10d4=23 ]{124}
[20:08] <Kobot> Ebiris rolled 13d6+6d6+2d6+10d4+18 --> [ 13d6=48 6d6=25 2d6=3 10d4=25 ]{119}
[20:08] <@Ebiris> roll 26d6+6d6+2d6+10d4+36
[20:08] <Kobot> Ebiris rolled 26d6+6d6+2d6+10d4+36 --> [ 26d6=82 6d6=16 2d6=8 10d4=26 ]{168}
All those were melee touch attacks. DC 36 fort or dazed for 1 round again.
Afina 248/329
> roll 1d20 even without some of his spells this is still a 1 check
<Kobot> Kotono rolled 1d20 even without some of his spells this is still a 1 check --> [ 1d20=18 ]{18}
This time when you touch the dragon the first time, the green beams arch out again, more of them coming for her.
First one is locked, you can choose to break off your other two attacks if you want. I meant to stop you at one I didn't, so that's on me.
<Kobot> Kotono rolled 1d20+78 touch AC vs Afina --> [ 1d20=3 ]{81}
> roll 1d100 vs 50
<Kobot> Kotono rolled 1d100 vs 50 --> [ 1d100=55 ]{55}
> roll 10d8
<Kobot> Kotono rolled 10d8 --> [ 10d8=54 ]{54}
Going t make the other two attacks?
10th level slot sacrificed for -50 damage. I'll keep attacking.
Afina 244/329
spell slots: 6/9/8/9/2/7/1/6/1/4/4/2/2
<Kobot> Kotono rolled 1d20 even without some of his spells this is still a 1 check --> [ 1d20=1 ]{1}
<Kobot> Kotono rolled 1d20 even without some of his spells this is still a 1 check --> [ 1d20=19 ]{19}
> roll 1d20+78 touch AC vs Afina the spell strikes automatically, but round 3 will be a miss for him
<Kobot> Kotono rolled 1d20+78 touch AC vs Afina the spell strikes automatically, but round 3 will be a miss for him --> [ 1d20=3 ]{81}
<Kobot> Kotono rolled 1d20+78 touch AC vs Afina the spell strikes automatically, but round 3 will be a miss for him --> [ 1d20=7 ]{85}
> roll 1d100 vs 1
> roll 1d100 vs 2
<Kobot> Kotono rolled 1d100 vs 1 --> [ 1d100=94 ]{94}
<Kobot> Kotono rolled 1d100 vs 2 --> [ 1d100=46 ]{46}
> roll 10d8
<Kobot> Kotono rolled 10d8 --> [ 10d8=37 ]{37}
You're struck again, rolling back with it as the scalding heat knocks the dragon back. It's half slumped over, momentarily stunned as..
Round 3. Go.
7th level slot sacrificed for -35 damage
Finally with a bit of breathing room, Afina casts many moments of prescience on herself!
Afina 242/329
active spells: glaciante's spiteful ward (CL 29 attached to nothing), haste (CL 27), scalding touch (CL 31), many moments of prescience (CL 31)
spell slots: 6/9/8/9/1/7/1/5/1/4/4/1/2
Init is Moore (58) > Afina (51) > Mei (47) > Surru (44) > Jaela (39) > Dragon (23) > Canderella (19)
Time resumes and abruptly...
Canderella, she'll hold since she can't do a lot with an angry countering dragon. Moore.
"Watch out, it can shoot beams to automatically counter any melee attack now!" Afina warns everyone as time restarts. Sadly she can't do so telepathically right now.
Since he hasn't heard any calls to retreat yet, Moore will continue to sing from the safety of the door he's behind!
If nothing else, the songs should give everyone enough oomph to avoid any issues!
"Shout if you need some different kind of support!" Moore calls out, as he raises his voice -- the Words of Creation managing to penetrate easily into the next room.
[16:05] <Nephrite> roll 12d4 nonlethal
[16:05] <Kobot> Nephrite rolled 12d4 nonlethal --> [ 12d4=33 ]{33}
[16:06] <Nephrite> roll 18d4 nonlethal
[16:06] <Kobot> Nephrite rolled 18d4 nonlethal --> [ 18d4=52 ]{52}
Swift to cast Inspire Great Spells
Standard to use Inspire Greatness, Jaela, Afina, Surru, Candy and Mei get +8d10 temp HP, +8 competence to attack and +3 to fort saves. In addition they all get a free widen metamagic.
In addition to that, Jaela, Afina and Mei get +12 morale bonus to saves and +12 dodge to ACs.
This brings the total for ease of reference on the bonuses to:
So in total this is +32 to attack, +22 to damage, Improved Crit (stacks if you've already got it), +16 to crit confirms and +2 CL. Jaela, Afina and Mei have a total of +15 bonus to fort saves and +12 to other saves.
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 27), True Seeing (CL10), Bibliotecha Arcana (CL27). Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, agility of dragon princess (CL 28), Surraruthru's Stupendous Dragonskin, CL 28, endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28), Foresight (CL27), Harmonize (CL27), Righteous Halo (CL27)
HP: 363(110)(415/415)
AC: 62 (86), 46 (53) touch, 52 (59) flatfooted 20% miss chance, SR 41, 30 resist all to elements
17/32 Bardic music uses 1/3 Refrain
Fort +36 (42), Ref +40 (48), Will +41 (45) (+6 due to Superior Resistance)
+14 to initiative for everyone
Spells:
0th - 4/4 (DC 22)
1st - 7/7
2nd - 5/7
3rd - 7/7
4th - 2/7
5th - 5/6
6th - 6/6
7th - 4/6
8th - 4/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 3/8
7th - 6/6
8th - 4/4
+1 Luck Bonus on Attack Rolls
Additionally, the below are pre-loaded into the Tapestry for activation as Quiescent Weaving:
Resist Energy, CL 26, Duration 260 Minutes. (4 castings)
Subject gains energy resistance to: Acid, Electricity, Fire, Sonic of 30 points.
[/spoiler]
Afina keeps an eye on Jaela, seeing that she's grabbed the sigil now. "Jaela, can you disengage?" she calls, preparing to cover their retreat if she does.
Holding for Jaela now.
Afina 242/329
defences: AC 85 (touch 73), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
