Gar-Malleos
Surru and Mei ar eup. Go IDdy.
Surraruthru begins casting, planning to buy himself some time to beef up defenses!
Time Stop, CL 30.
> roll 1d4+1
<Kobot> Iddy rolled 1d4+1 --> [ 1d4=4 ]{5}
No counter, dazed. Go.
#858
Surraruthru begins casting a brace of spells into the Tapestry to bolster the defenses of Jaela and Afina!
Round 1:
Standard: Spell Turning, CL 30, 300 minute duration.
Spells and spell-like effects targeted on you are turned back upon the original caster. The abjuration turns only spells that have you as a target. Effect and area spells are not affected. Spell turning also fails to stop touch range spells. From seven to ten (1d4+6) spell levels are affected by the turning. The exact number is rolled secretly.
Round 2:
Swift: Use the Vest of the Archmagi to recall the 8th level spell Surraruthru's Stupendous Dragonskin.
Standard: Surraruthru's Stupendous Dragonskin, CL 30, 30 hour duration.
Round 3:
Standard: Create Magic Tattoo, CL 26, 24 hour duration.
+1 spellcaster level. This effect increases the subject's effective level, but not the total number of spells.
Round 4:
+1 Deflection Bonus to AC.
Round 5:
+2 Competence Bonus to Attack.
Okay, I think this trigger's Afina's spell stowaway, so she gets the time stop too. What are you doing, Afina?
"Good to go!" Jaela affirms.
Presumably, I yell this just before the time stop.
Don't think Jaela will get those buffs since you can't cast on other people when time-stopped (spell stowaway exceptions aside)
Everyone's throwing that spell around right now! Still, Afina takes advantage by recasting some of her sundered spells.
Casting the following
Round 1: Epic mage armour
Round 2: Greater heroism
Round 3: Afina's perfect vision
Round 4: Planar bubble
Round 5: Shield
Afina 242+20/329
active spells: haste (CL 27), scalding touch (CL 31), many moments of prescience (CL 31), epic mage armour (CL 29), greater heroism (CL 29), planar bubble (CL 30), shield (CL 30), spell-turning (CL 30), stupendous dragonskin (CL 30), magic tattoo (CL 26), magic tattoo (CL 26)
defences: AC 99 (touch 73), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, blindsight 200, all around vision, see invisible/ethereal, darkvision 60, spot +70, listen +70
spell slots: 6/9/8/9/1/7/0/4/1/4/4/0/1
Yeah, you can't target Jaela, she's out of the time stop. Working through the tapestry doesn't do an end run around that. Do you want to revise your action, Iddy?
Mei will be blasting the dragon. Jaela, what's your plan post time stop?
We're leaving, I'll be the last one out.
Okay, regardless of what Iddy changes his spells to or not, I don't think this is going to meaningfully impact that. Therefore I'm going to go ahead, and with leave for Iddy to post if he wants to revise his spells - within reason to what he knows while in the time stop - in light of Jaela not being a valid target.
As the timestop ends, magic woven once more, Mei stands her ground and fires once at the dragon, before hurrying back and retreating.
> roll 1d20 1 check ranged touch
<Kobot> Kotono rolled 1d20 1 check ranged touch --> [ 1d20=14 ]{14}
SR isn't aconcern now with magic dispelled plus all the bonuses to it in play.
> roll 15d6+7
<Kobot> Kotono rolled 15d6+7 --> [ 15d6=47 ]{54}
The dragon is blasted again, hit and scales scorched by Mei's power, as...
Jaela.
Jaela very quickly realizes that she can either score a decent hit or force the dragon to waste more of its ridiculously powerful magic by using True Strike, and promptly does so. And then she strikes!
Quickened True Strike.
First two attacks are smites. Persistent divine might is still in effect. I remain in Gambit.
20:27 <Lucille> roll 1d20+49+3+34+12
20:28 <Kobot> Lucille rolled 1d20+49+3+34+12 --> [ 1d20=16 ]{114}
20:28 <Lucille> roll 1d20+49+3+34+12
20:28 <Kobot> Lucille rolled 1d20+49+3+34+12 --> [ 1d20=19 ]{117}
20:28 <Lucille> roll 1d20+49+3+34+12+16 crit?
20:28 <Kobot> Lucille rolled 1d20+49+3+34+12+16 crit? --> [ 1d20=12 ]{126}
20:28 <Lucille> roll 1d20+44+3+34
20:28 <Kobot> Lucille rolled 1d20+44+3+34 --> [ 1d20=19 ]{100}
20:28 <Lucille> roll 1d20+44+3+34+16 crit?
20:28 <Kobot> Lucille rolled 1d20+44+3+34+16 crit? --> [ 1d20=16 ]{113}
20:28 <Lucille> roll 1d20+39+3+34
20:28 <Kobot> Lucille rolled 1d20+39+3+34 --> [ 1d20=5 ]{81}
20:29 <Lucille> roll 1d20+34+3+34
20:29 <Kobot> Lucille rolled 1d20+34+3+34 --> [ 1d20=12 ]{83}
-2 for all due to a mistake, but all still hit.
20:31 <Lucille> roll 4d8+36+5d6+4d6+22+10 and 1 negative level
20:31 <Kobot> Lucille rolled 4d8+36+5d6+4d6+22+10 and 1 negative level --> [ 4d8=15 5d6=20 4d6=17 ]{120}
Should be 132, forgot to add in divine might.
20:31 <Kobot> Lucille rolled 4d8+36+5d6+4d6+22+10 and 1 negative level --> [ 4d8=21 5d6=15 4d6=13 ]{117}
Should be 119, forgot to add in divine might and subtract smite.
20:31 <Kobot> Lucille rolled 4d8+36+5d6+4d6+22+10 and 1 negative level --> [ 4d8=19 5d6=13 4d6=11 ]{111}
Should be 113, forgot to add in divine might and subtract smite.
20:32 <Lucille> roll 12d8+204+5d6+4d6+9d6 and 3 negative levels crit1
20:32 <Kobot> Lucille rolled 12d8+204+5d6+4d6+9d6 and 3 negative levels crit1 --> [ 12d8=49 5d6=12 4d6=12 9d6=34 ]{311}
Should be 347, forgot to add in divine might.
20:33 <Lucille> roll 12d8+174+5d6+4d6+9d6 and 3 negative levels crit2
20:33 <Kobot> Lucille rolled 12d8+174+5d6+4d6+9d6 and 3 negative levels crit2 --> [ 12d8=52 5d6=14 4d6=13 9d6=34 ]{287}
Should be 293, forgot to add in divine might and subtract smite.
Total 1,004 and 9 negative levels.
20:24 <Lucille> Dune, casting True Strike. Does it counterspell?
20:24 <Lucille> Affects the rest of my turn
20:24 <•Kotono> Committing?
20:25 <Lucille> Yes
20:25 <•Kotono> Yes.
20:25 <•Kotono> Post this in yoru coming post for reference.
20:25 <Lucille> My second swift action is also True Strike. Does it counterspell that too?
20:27 <•Kotono> Yes. It's not willing to deal with true striking. Same posting requirement as the last.
20:27 <Lucille> Done
You stab - again and again and again and again and again. The dragon's wounded and yet his wounds begin to heal at the same time, as green beams lash out at you.
roll 1d20+78 touch AC Jaela 1
> roll 1d20+78 touch AC Jaela 2
> roll 1d20+78 touch AC Jaela 3
<Kobot> Kotono rolled 1d20+78 touch AC Jaela 1 --> [ 1d20=3 ]{81}
<Kobot> Kotono rolled 1d20+78 touch AC Jaela 2 --> [ 1d20=1 ]{79}
<Kobot> Kotono rolled 1d20+78 touch AC Jaela 3 --> [ 1d20=11 ]{89}
> roll 1d20+78 touch AC Jaela 4
> roll 1d20+78 touch AC Jaela 5
<Kobot> Kotono rolled 1d20+78 touch AC Jaela 4 --> [ 1d20=8 ]{86}
<Kobot> Kotono rolled 1d20+78 touch AC Jaela 5 --> [ 1d20=12 ]{90}
Touch AC, Jaela?
70 right now, 20% miss chance, and Surru gave me spell turning previously. The 1 missed, at least.
> roll 1d100 vs 1
> roll 1d100 vs 3
<Kobot> Kotono rolled 1d100 vs 1 --> [ 1d100=69 ]{69}
> roll 1d100 vs 4
<Kobot> Kotono rolled 1d100 vs 3 --> [ 1d100=74 ]{74}
> roll 1d100 vs 5
<Kobot> Kotono rolled 1d100 vs 4 --> [ 1d100=17 ]{17}
<Kobot> Kotono rolled 1d100 vs 5 --> [ 1d100=54 ]{54}
> roll 10d8
<Kobot> Kotono rolled 10d8 --> [ 10d8=52 ]{52}
> roll 10d8
> roll 10d8
<Kobot> Kotono rolled 10d8 --> [ 10d8=65 ]{65}
<Kobot> Kotono rolled 10d8 --> [ 10d8=46 ]{46}
You're struck again and again as you strike the dragon in turn, bloodied but intact. Those shots hurt, no two ways about it as...
Do those provoke anything from you, Jaela? They're technically ranged attacks that don't provoke the normal AoO for making a ranged attack in melee.
