Gar-Malleos
Yeah, retreat back out the way we came until we can gate/plane shift home.
> roll1 d100
<Kobot> Kotono rolled d100 --> [ 1d100=61 ]{61}
The party hurries back up and up. You run up the stairs, back to the dungeon. Here you find that the T intersection going back is blocked, clogged with a thick wall of iron that prohibits further progress.
"Hang on, I can tell you how far this goes, I think." Moore says as he takes a breath.
Standard-action Hindsight to see how much of an actual trap this is -- i.e. is it just one wall, multiple, etc.
You see an erinyes bearing a wand come forth and wave it, creating wall after wall to block the way. It's layered as far as you can tell - naturally you can't see much once the way is blocked, but it looks like she didn't stop at one.
"Surraruthru, you had an idea of finding the focus for the dimensional warding through the leyline? Try locating that in case this takes us too long to punch through," Afina asks.
"Do you have enough to burn a hole through this, or should I?" Jaela asks Afina.
"They used a wand of iron walls or whatever this spell is." Moore says with a gesture. "There are a ton of these. I wonder if we just went straight up..."
"It can't be a mere wand," Canderella says, "It's too strong a spell for a wand. We may have no choice, then, but to go up."
Jaela throws herself against the first visible wall Gae Dioltas first, while Surraruthru works.
Yarp, will do. Of note, if the Ley Line nexus and dimensional block are in two different areas, which one do you want to prioritize?
The block will let us escape easier, but I've got the tree and stuff and that'll help save all of Lifasa.
Surraruthru nods and starts feeling out the weaves of magic in the area, trying to get a bead on the dimensional block or the ley line nexus.
> roll 3#1d20+57 Spellcraft
<Kobot> Iddy rolled 3#1d20+57 Spellcraft --> [ 1d20=6 ]{63}, [ 1d20=11 ]{68}, [ 1d20=20 ]{77}
Dimensional block is priority, no sense going to plant a tree and then buggering off home and leaving it in devil hands. Can worry about that when we conquer the place for real.
Surraruthru can discern both are further down somewhere.
Same direction or different ones? Also down where? Like deeper underground?
"They're off this way, somewhere. I can follow it for now, but I can't pinpoint them yet."
Surraruthru indicates the direction to the others.
Different and down below, deeper underground.
Can I tell which is which?
