The Assault on Avernus
Started by Anastasia, May 08, 2018, 02:48:19 PM
At least her earlier spell will ensure healing magic will work regardless of the damage being vile or not. She casts a quickened ray deflection and drops another radiant assault onto a cluster of liches while preparing to counter the next green hellfire with her own divine silver fire!
Readied action for that.
Quickened/vivacious radiant assault
[20:14] <@Ebiris> roll 1d20+31 SR
[20:14] <Kobot> Ebiris rolled 1d20+31 SR --> [ 1d20=2 ]{33}
[20:14] <@Ebiris> roll 15d6
[20:14] <Kobot> Ebiris rolled 15d6 --> [ 15d6=47 ]{47}
[20:14] <@Ebiris> roll 1d6 dazed duration
[20:14] <Kobot> Ebiris rolled 1d6 dazed duration --> [ 1d6=4 ]{4}
Damage is doubled vs undead/evil outsiders. DC 32 will or dazed for duration. Saving halves damage and inflicts dazzled rather than dazed.
T minus 2 rounds to Lixervatar arrival.
Alicia: 544/624
Active spells: Extended nondetection (CL 31), many moments of prescience (CL 31), extended greater anticipate teleportation (CL 31), foresight (CL 31), true seeing (CL 31), mass death ward (CL 31), greater heroism (CL 31), miracle (diseaseimmunity, CL 31), vision of the omniscient eye (CL 31), energy resistance x5 (CL 31), spell turning (CL 31), fortunate fate (CL 31), interplanar telepathic bond (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), dance of the unicorn (CL 30), recitation (CL 30), greater visage of the deity (CL 30), extended repelling shield (CL 31), master's touch (CL 30), sensual blessing (CL 30), ghost touch weapon (CL 30), ghost touch armour (CL 30), consecrated ward (CL 31)
Defences: AC 73 (touch 37, incorp touch 56), CMD 85, spell resistance 45, energy immunity (fire, cold), energy resistance 30 (all), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +4 morale attack/skills/saves, +10 insight perception, +3 morale damage, +2 morale ability checks, +2 luck attack/saves, +4 Str, +2 Dex, +4 Con, +2 Int, +4 Wis, +4 Cha, +1 natural armour, +7 shield AC, +4 insight skills, +25 competence perception
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +83
Sorcerer spell slots: 6/9/8/4/6/5/4/8/6/8/4/5/4/4
Duskblade spell slots: 6/12/11/10/9/4
> roll 1d20+18 will vs Alicia's radiant assaults
<Kobot> Kotono rolled 1d20+18 will vs Alicia's radiant assaults --> [ 1d20=19 ]{37}
This one isn't as effective, resisted. Blocked in some cases, but devils are still reduced by it. As this happens...
'Shall I protect you while you prepare for Lixer, Alicia?'
'Thin the horde first, less distractions later the better,' Alicia sends. 'I'm going to try and stop the next hellfire pulse.'
> roll 7d6 aura
<Serith> Kotono roll for Serith < 23 > [d6=4,1,1,2,4,6,5]
Latha continues to grow as the skies above you fill - spirits emerging, darkness rising faster and faster yet. She raises her hand up, grabbing sunbeams that forge into a lance too bright to look at. "The Morninglord rejects you! Never again know another dawn!" Latha calls out as she flings the sunlance into the gathering liches.
> roll 1d20 1 check, mostly, will do the math if it's close
<Serith> Kotono roll for Serith < 10 > [d20=10]
The joy of ranged touch. Anyway, energized sunlance.
> roll 30d6
<Serith> Kotono roll for Serith < 100 > [d6=4,6,1,1,1,2,6,3,3,6,5,2,2,2,3,5,2,4,5,5,5,1,5,5,4,5,2,2,2,1]
> roll 100+50
<Serith> Kotono roll for Serith < 150 >
> roll 1d20+30 rolling SR would help, too, sleepy this morning
<Serith> Kotono roll for Serith < 44 > [d20=14]
> roll 25d6 undead central here
<Serith> Kotono roll for Serith < 84 > [d6=3,1,5,2,5,1,2,3,1,2,3,6,1,4,6,1,4,3,3,6,6,1,3,6,6]
> roll 84+42
<Serith> Kotono roll for Serith < 126 >
Init is Lixer (Supreme Init) > Alicia (29) > Latha (13) > Hell's Legions (11)
Liches burn. Lesser devils are incinerated, glowing with holy radiance as a sunburst explodes over that part of the line.  The liches are devastated, Hell's forces momentarily checked as you attack. Then, like a vast tidal wave, they pour over. As they brave Latha's glow and attack en masse, like a coordinated tsunami, the water itself is wretched from the two of you as...
> roll 1d20+25
<Serith> Kotono roll for Serith < 38 > [d20=13]
Tinks on your SR.
...With a pulse of power, you shatter the spell against yourself, no longer subject to such mortal magic. You feel the Weave exulting at your touch, the power of all magic momentarily felt by you. Latha merely glows brighter, the magic crumbling before her glow. Then absolute darkness envelops all of you, a greasy miasma that seeks to drown the two of you eternal night.
> roll 1d20+24
<Serith> Kotono roll for Serith < 36 > [d20=12]
Once you would have feared a volley of unholy blights, much in the same way that a fifth circle spell was a lifetime's achievement for you. Now they dare not touch you, not as you are now. Then you are dodging, parrying and fighting, attention focused wholly on the battle and the battle alone.
> roll 1d20+54
<Serith> Kotono roll for Serith < 66 > [d20=12]
AC, Alicia?
Donald
HP: 508/543
Spells Active:
Bonuses:
Latha
HP: 505+20/505
Spells Active:
Bonuses:
Resources Used: Legion's Gate, Vivacious Fire Storm, Energized Sunlance.
Sulia
HP: 714+20/714
Spells Active:
Bonuses:
See through everything within 120ft (True Seeing)
Immunity to disease (Miracle)
Gain 20 temp hp (Greater Heroism)
Energy Res 30 (all)
Interplanar Telepathic Bond (Miracle)
+15 insight to any single skill check (Divine Insight)
+25 to stealth (competence, circumstance, racial)
+20 to disguise (untyped)
+4 competence bonus to Escape Artist (Shadow Form)
+4 untyped to init (Sign)
+2 insight to AC and Reflex (Foresight)
+5 sacred to AC and Reflex if you have and are using a shield (Shield of Warding)
+4 morale on attack and immunity to fear and 20 temp hp (Greater Heroism)
+2 morale to damage/ability checks (Good Hope)
Righteous Wrath of the Faithful (extra attack like haste, +3 morale to attack/damage), CL 31
Recitation (+2 luck to attacks/saves (+3 for Alicia worshippers), CL 31
Speaking of, alter reality for ghost-touch weapon on everyone.
Ghost touch armour of course.
Alicia is like the wind, dodging. Some blows simply are pushed away from hers, others she parries with Bonds. Yet others are sidestepped, a great dance that she is part of and part of alone. As this happens Latha blocks the same, spectral arrows pepper the both of you, as inhuman howls of fury follow, assaulting your eardrums.
> roll 1d20+51 arrows
<Serith> Kotono roll for Serith < 55 > [d20=4]
Ghost touching your armor helped here. Okay, the sonic attack isn't subject to SR, so I need a Fort save, Alicia and Latha. This is a sonic attack for resistances.
[17:05] <@Ebiris> roll 1d20+63 mettle
[17:05] <Rei-chan> Ebiris rolled : 1d20+63 mettle --> [ 1d20=7 ]{70}
Alicia: 544/624
> roll 1d20+40 Latha Fortitude
<Rei-chan> Kotono rolled : 1d20+40 Latha Fortitude --> [ 1d20=7 ]{47}
> roll 20d6 sonic Alicia none, Latha half
<Rei-chan> Kotono rolled : 20d6 sonic Alicia none, Latha half --> [ 20d6=81 ]{81}
Yet Alicia is not harmed. She resists, sloughs it off and pushes forward. From there the green hellfire comes again and...
Take your held action.
Donald
HP: 508/543
Spells Active:
Bonuses:
Latha
HP: 485/505
Spells Active:
Bonuses:
Sulia
HP: 714+20/714
Spells Active:
Bonuses:
Energy Res 30 (all)
Alicia gestures up and a wide beam of silver fire lances from her hand into the sky to core through the green hellfire that descends upon them!
No attack roll required, does 40d10 damage if that matters like for cancelling out the hellfire's damage.
Sure, go ahead and roll it real quick for reference.
[17:25] <@Ebiris> roll 40d10
[17:25] <Rei-chan> Ebiris rolled : 40d10 --> [ 40d10=252 ]{252}
Silver fire and green hellfire meet in the sky, beauty and nightmares waging war. The blasts meet...meet and meet and ultimately...
With a woosh of air, the green hellfire is negated. Your silver fire is gone as well, the two canceling out or close enough.
Alicia, go.
2 rounds for Lixervatar arrival, I can spend this one freely, next one has to be spent readying to full attack when he pops in.
Having moved to near the spot Lixer will teleport in, Alicia suddenly looms over the battlefield, standing as tall as a mountain on Avernus! Her castle sized blades sweep through the battlefield, focused primarily on liches but few are spared her wrath!
Swift to increase in size to colossal(+). Assuming all targets are undead for sake of bane/vivacious effects (note I can crit undead)
[17:44] <@Ebiris> roll 1d20+76 9th level arcane strike, channelled maximised/vivacious combust
[17:44] <Rei-chan> Ebiris rolled : 1d20+76 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=4 ]{80}
[17:44] <Rei-chan> Ebiris rolled : 1d20+76 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=5 ]{81}
[17:44] <@Ebiris> roll 1d20+71 9th level arcane strike, channelled maximised/vivacious combust
[17:44] <Rei-chan> Ebiris rolled : 1d20+71 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=11 ]{82}
[17:44] <Rei-chan> Ebiris rolled : 1d20+71 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=19 ]{90}
[17:44] <@Ebiris> roll 1d20+66 9th level arcane strike, channelled maximised/vivacious combust
[17:44] <Rei-chan> Ebiris rolled : 1d20+66 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=10 ]{76}
[17:44] <Rei-chan> Ebiris rolled : 1d20+66 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=19 ]{85}
[17:44] <@Ebiris> roll 1d20+61 9th level arcane strike, channelled maximised/vivacious combust
[17:44] <Rei-chan> Ebiris rolled : 1d20+61 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=2 ]{63}
[17:44] <Rei-chan> Ebiris rolled : 1d20+61 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=3 ]{64}
[17:44] <@Ebiris> roll 1d20+56 9th level arcane strike, channelled maximised/vivacious combust
[17:44] <Rei-chan> Ebiris rolled : 1d20+56 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=14 ]{70}
[17:44] <Rei-chan> Ebiris rolled : 1d20+56 th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=19 ]{75}
[17:44] <@Ebiris> roll 1d20+71 9th level arcane strike, channelled maximised/vivacious combust crit check
[17:44] <Rei-chan> Ebiris rolled : 1d20+71 th level arcane strike, channelled maximised/vivacious combust crit check --> [ 1d20=1 ]{72}
[17:44] <@Ebiris> roll 1d20+66 9th level arcane strike, channelled maximised/vivacious combust crit check
[17:44] <Rei-chan> Ebiris rolled : 1d20+66 th level arcane strike, channelled maximised/vivacious combust crit check --> [ 1d20=14 ]{80}
[17:44] <@Ebiris> roll 1d20+56 9th level arcane strike, channelled maximised/vivacious combust crit check
[17:44] <Rei-chan> Ebiris rolled : 1d20+56 th level arcane strike, channelled maximised/vivacious combust crit check --> [ 1d20=20 ]{76}
I don't autofail on a 1 so I'll assume all those crits landed.
[17:47] <@Ebiris> roll 6d6+40+3d6+1d8+9d4+160
[17:47] <Rei-chan> Ebiris rolled : 6d6+40+3d6+1d8+9d4+160 --> [ 6d6=14 3d6=10 1d8=1 9d4=27 ]{252}
[17:47] <Rei-chan> Ebiris rolled : 6d6+40+3d6+1d8+9d4+160 --> [ 6d6=26 3d6=11 1d8=6 9d4=27 ]{270}
[17:47] <Rei-chan> Ebiris rolled : 6d6+40+3d6+1d8+9d4+160 --> [ 6d6=13 3d6=13 1d8=8 9d4=20 ]{254}
[17:47] <@Ebiris> roll 12d6+80+6d6+1d8+9d4+240
[17:47] <Rei-chan> Ebiris rolled : 12d6+80+6d6+1d8+9d4+240 --> [ 12d6=43 6d6=30 1d8=3 9d4=20 ]{416}
[17:47] <Rei-chan> Ebiris rolled : 6d6+40+3d6+1d8+9d4+160 --> [ 6d6=25 3d6=16 1d8=3 9d4=21 ]{265}
[17:47] <Rei-chan> Ebiris rolled : 12d6+80+6d6+1d8+9d4+240 --> [ 12d6=41 6d6=20 1d8=3 9d4=22 ]{406}
[17:47] <Rei-chan> Ebiris rolled : 6d6+40+3d6+1d8+9d4+160 --> [ 6d6=21 3d6=16 1d8=3 9d4=21 ]{261}
[17:47] <Rei-chan> Ebiris rolled : 6d6+40+3d6+1d8+9d4+160 --> [ 6d6=19 3d6=12 1d8=1 9d4=26 ]{258}
[17:47] <Rei-chan> Ebiris rolled : 6d6+40+3d6+1d8+9d4+160 --> [ 6d6=20 3d6=10 1d8=2 9d4=19 ]{251}
[17:47] <Rei-chan> Ebiris rolled : 12d6+80+6d6+1d8+9d4+240 --> [ 12d6=45 6d6=23 1d8=2 9d4=16 ]{406}
She then hurls her sword out in the direction of a cluster of necrolytes, the titanic weapon cutting through ranks of devils like a buzz-saw before returning to her hand!
Quickened whirling blade, 60 foot line, presumably it's 30 feet wide with me being colossal. Assuming all devil targets for bane/vivacious effects.
[17:49] <@Ebiris> roll 1d20+76 quickened whirling blade, 9th level arcane strike, channelled maximised/vivacious combust
[17:49] <Rei-chan> Ebiris rolled : 1d20+76 quickened whirling blade, 9th level arcane strike, channelled maximised/vivacious combust --> [ 1d20=7 ]{83}
[17:50] <@Ebiris> roll 6d6+42+3d6+2d6+9d4+160 and 1 negative level
[17:50] <Rei-chan> Ebiris rolled : 6d6+42+3d6+2d6+9d4+160 and 1 negative level --> [ 6d6=22 3d6=10 2d6=7 9d4=24 ]{265}
All around her is ruin and true death, and she calls out with her voice carrying for miles at her current stature, "This is what it is when Gods do battle, Lixer! Is your avatar ready? Are you?" she challenges. "Be grateful I am here to educate you!"
Alicia: 784/884
Defences: AC 77 (touch 28, incorp touch 46), CMD 107, spell resistance 45, energy immunity (fire, cold), energy resistance 30 (all), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +4 morale attack/skills/saves, +10 insight perception, +3 morale damage, +2 morale ability checks, +2 luck attack/saves, +36 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +15 natural armour, -8 size AC/attack, +7 shield AC, +4 insight skills, +25 competence perception
Sorcerer spell slots: 6/9/8/4/5/4/4/8/6/7/4/5/4/4
From here you can see it all.
You can see Noir Jarden, teeming with activity.
You can see Sulia and Donald waging war, back to back as they defend themselves from the onslaught.
You can see your foes, cut down by your oversized blade. In a few swipes everything within your immediate reach is wiped out, then the liches are cleaved through as you stand there, momentarily triumphant. For this moment the battlefield is cleared, even as you can feel the infernal power gathering, more and more intense by the moment.
In your mind as you stand there that moment, 'Do you need support, Alicia?' Latha asks.
'Lixer's avatar is seconds out, along with eight liches. Prepare to disable or kill the liches while I handle the avatar.'
Latha has one round to spend freely and then her next round needs to be spent readying an action to do something about the incoming teleport. Depending on how Lixer and the liches are positioned she could maybe drop a prismatic sphere where the liches are inbound so they'll be trapped inside of it? Either that or buff or heal...
When they do pop in I'd like her to either drop a sunbeam or righteous smite to blind the liches or try to get a final blow in on the avatar if I fail to kill it.
