The Assault on Avernus
Started by Anastasia, May 08, 2018, 02:48:19 PM
With the current threat momentarily held at bay, Latha intones a Word of Creation, healing magic passing through the both of you.
Mass Heal, topping the two of you up before Lixer shenanigans.
More. More come, coffins erupting out, spirits summoned. By the hundreds - no, thousands. Skeletal wyrms appear in the air, vast structures of bone with ribcages full of smaller undead, fleshy, horrid things that scream for your blood. Vampires emerge in swarms, like bats gathering around. Great hounds of bone and flesh emerge, big enough to come up to your knee, snarling and drooling acid onto the ground.
But for the moment, they are hanging back out of your immediate range, gathering.
Baddies needed a regroup round. Alicia.
Donald
HP: 508/543
Spells Active:
Bonuses:
Latha
HP: 505/505
Spells Active:
Bonuses:
Resources Used: Legion's Gate, Vivacious Fire Storm, Energized Sunlance.
Sulia
HP: 714+20/714
Spells Active:
Bonuses:
See through everything within 120ft (True Seeing)
Immunity to disease (Miracle)
Gain 20 temp hp (Greater Heroism)
Energy Res 30 (all)
Interplanar Telepathic Bond (Miracle)
+15 insight to any single skill check (Divine Insight)
+25 to stealth (competence, circumstance, racial)
+20 to disguise (untyped)
+4 competence bonus to Escape Artist (Shadow Form)
+4 untyped to init (Sign)
+2 insight to AC and Reflex (Foresight)
+5 sacred to AC and Reflex if you have and are using a shield (Shield of Warding)
+4 morale on attack and immunity to fear and 20 temp hp (Greater Heroism)
+2 morale to damage/ability checks (Good Hope)
Righteous Wrath of the Faithful (extra attack like haste, +3 morale to attack/damage), CL 31
Recitation (+2 luck to attacks/saves (+3 for Alicia worshippers), CL 31
Speaking of, alter reality for ghost-touch weapon on everyone.
Ghost touch armour of course.
Mental note to acquire combat reflexes.
Alicia keeps an eye on the reinforcements, but one particular reinforcement is more important than any other, and so she tenses in preparation to unload on Lixer's avatar the moment he appears!
He appears next round so I'm readying myself to full attack as soon as he does.
Alicia: 884/884
Active spells: Extended nondetection (CL 31), many moments of prescience (CL 31), extended greater anticipate teleportation (CL 31), foresight (CL 31), true seeing (CL 31), mass death ward (CL 31), greater heroism (CL 31), miracle (diseaseimmunity, CL 31), vision of the omniscient eye (CL 31), energy resistance x5 (CL 31), spell turning (CL 31), fortunate fate (CL 31), interplanar telepathic bond (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), dance of the unicorn (CL 30), recitation (CL 30), greater visage of the deity (CL 30), extended repelling shield (CL 31), master's touch (CL 30), sensual blessing (CL 30), ghost touch weapon (CL 30), ghost touch armour (CL 30), consecrated ward (CL 31)
Defences: AC 77 (touch 28, incorp touch 46), CMD 107, spell resistance 45, energy immunity (fire, cold), energy resistance 30 (all), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +4 morale attack/skills/saves, +10 insight perception, +3 morale damage, +2 morale ability checks, +2 luck attack/saves, +36 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +15 natural armour, -8 size AC/attack, +7 shield AC, +4 insight skills, +25 competence perception
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +83
Sorcerer spell slots: 6/9/8/4/5/4/4/8/6/7/4/5/4/4
Duskblade spell slots: 6/12/11/10/9/4
Latha holds as well, ready to smash as needed.
Above you they come. The dead rise, the bone wyrms emitting cones of pure cold and death, right at you, sailing in as their ribs open up, dropping the tiny, fleshy blobs of undeath on you, gnawing at your body.
Reflex save for the breath weapons. Cold and negative energy damage in case you immune one or both.
> roll 1d20+42 bombs away en masse
<Rei-chan> Kotono rolled : 1d20+42 bombs away en masse --> [ 1d20=20 ]{62}
> roll 1d20+42 bombs away en masse crit?
<Rei-chan> Kotono rolled : 1d20+42 bombs away en masse crit? --> [ 1d20=1 ]{43}
Do you have any miss chance? Just making sure since this is your first combat in years.
I immune both cold and negative energy (divinity for cold, death ward for negative energy) so won't bother with reflex. No miss chance.
> roll 6d8+35+3d6+1d6 does not beat your SR
<Rei-chan> Kotono rolled : 6d8+35+3d6+1d6 does not beat your SR --> [ 6d8=25 3d6=7 1d6=4 ]{71}
By SR I mean damage reduction. So that applies. There's a save effect attached, but you can't fail the save even with a 1, so no save needed.
Yet the breath is meaningless to you as you stand there and endure, bitten all over. With such a large form perhaps it is inevitable, dozens of them tasting your divine blood, exploding in instants from it - but leaving wounds nonetheless, as the new liches begin to chant, a scything wave of force slashing into your legs.
> roll 1d20+38 touch AC
<Rei-chan> Kotono rolled : 1d20+38 touch AC --> [ 1d20=4 ]{42}
Hit.
> roll 25d8 force damage
<Rei-chan> Kotono rolled : 25d8 force damage --> [ 25d8=128 ]{128}
Blood is drawn from your legs, slashed open as the ground cracks and writhes when your blood touches it. The entire land shudders from the contact as another sonic howl echos from the disembodied spirits here.
Fort you two.
Was that force thing a ray? I have ray deflection.
[18:39] <@Ebiris> roll 1d20+71 mettle
[18:39] <Rei-chan> Ebiris rolled : 1d20+71 mettle --> [ 1d20=1 ]{72}
Being a deity is pretty great at times like this.
Alicia: 700/884
No, it was not a ray. However, I should've skipped the save since you can't fail it. I'm still getting a handle on that aspect of running you two, I'm so used to stopping on a save call.
> roll 1d20+40 Latha Fortitude
<Rei-chan> Kotono rolled : 1d20+40 Latha Fortitude --> [ 1d20=16 ]{56}
> roll 20d6 sonic Alicia none, Latha half
<Rei-chan> Kotono rolled : 20d6 sonic Alicia none, Latha half --> [ 20d6=67 ]{67}
Yet you endure the sonics as well as last time, simply surviving it as forces rally to rush you again, but not yet as...
Abruptly the avatar begins to appear, but a second before that, a renewed double blast of green hellfire rockets down, aimed at obliterating you.
Reflex, Alicia and Latha, Lixer was holding too. Then your held action and then the avatar, if it survives.
Donald
HP: 428/543
Spells Active:
Bonuses:
Latha
HP: 472/505
Spells Active:
Bonuses:
Sulia
HP: 714+20/714
Spells Active:
Bonuses:
Energy Res 30 (all)
[18:49] <@Ebiris> roll 1d20+52 reflex
[18:49] <Rei-chan> Ebiris rolled : 1d20+52 reflex --> [ 1d20=3 ]{55}
> roll 1d20+55 Latha evasion
<Rei-chan> Kotono rolled : 1d20+55 Latha evasion --> [ 1d20=19 ]{74}
Latha takes none while Alicia takes 200 vile damage after the successful save.
Oh, the flames hurt. They burn you, violate your spirit, taint you with undeath.
But you endure as the avatar and liches appear, right on time and ready as...
Go, Alicia.
As Alicia's blades descend on Lixer's avatar she makes sure to dispel his protections before they strike!
Quick Cast Superb Dispelling. How many checks?
Alicia: 500/884
[19:08] <@Ebiris> roll 23#1d20+32
[19:08] <Rei-chan> Ebiris rolled : 23#1d20+32 --> [ 1d20=19 ]{51}, [ 1d20=4 ]{36}, [ 1d20=20 ]{52}, [ 1d20=13 ]{45}, [ 1d20=12 ]{44}, [ 1d20=10 ]{42}, [ 1d20=12 ]{44}, [ 1d20=16 ]{48}, [ 1d20=17 ]{49}, [ 1d20=19 ]{51}, [ 1d20=8 ]{40}, [ 1d20=5 ]{37}, [ 1d20=10 ]{42}, [ 1d20=4 ]{36},
[19:08] <Rei-chan> [ 1d20=12 ]{44}, [ 1d20=10 ]{42}, [ 1d20=6 ]{38}, [ 1d20=19 ]{51}, [ 1d20=8 ]{40}, [ 1d20=17 ]{49}, [ 1d20=10 ]{42}, [ 1d20=13 ]{45}, [ 1d20=14 ]{46}
[19:08] <@Ebiris> roll 22#1d20+32
[19:08] <Rei-chan> Ebiris rolled : 22#1d20+32 --> [ 1d20=1 ]{33}, [ 1d20=7 ]{39}, [ 1d20=18 ]{50}, [ 1d20=5 ]{37}, [ 1d20=5 ]{37}, [ 1d20=7 ]{39}, [ 1d20=9 ]{41}, [ 1d20=10 ]{42}, [ 1d20=12 ]{44}, [ 1d20=6 ]{38}, [ 1d20=13 ]{45}, [ 1d20=13 ]{45}, [ 1d20=17 ]{49}, [ 1d20=9 ]{41},
[19:08] <Rei-chan> [ 1d20=10 ]{42}, [ 1d20=2 ]{34}, [ 1d20=12 ]{44}, [ 1d20=18 ]{50}, [ 1d20=13 ]{45}, [ 1d20=14 ]{46}, [ 1d20=19 ]{51}, [ 1d20=13 ]{45}
Posting this now so you can figure that all out while I figure out my attack routine.
So noted, working that out. Just post your attack routine when it's all rolled out.
As her dispel takes apart the avatar's protections, her blade follows, lined with acid that even Bwimb would have no choice but to respect as it carves into the avatar, proceeding to rend apart any liches should he fall before her onslaught!
[19:13] <@Ebiris> roll 1d20+82 channelled vivacious flux grasp, 13th level arcane strike, divine might
[19:13] <Rei-chan> Ebiris rolled : 1d20+83 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=16 ]{98}
[19:13] <Rei-chan> Ebiris rolled : 1d20+83 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=6 ]{88}
[19:13] <@Ebiris> roll 1d20+77 channelled vivacious flux grasp, 13th level arcane strike, divine might
[19:13] <Rei-chan> Ebiris rolled : 1d20+78 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=11 ]{88}
[19:13] <Rei-chan> Ebiris rolled : 1d20+78 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=5 ]{82}
[19:13] <@Ebiris> roll 1d20+72 channelled vivacious flux grasp, 13th level arcane strike, divine might
[19:13] <Rei-chan> Ebiris rolled : 1d20+73 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=9 ]{81}
[19:13] <Rei-chan> Ebiris rolled : 1d20+73 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=10 ]{82}
[19:14] <@Ebiris> roll 1d20+67 channelled vivacious flux grasp, 13th level arcane strike, divine might
[19:14] <Rei-chan> Ebiris rolled : 1d20+68 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=1 ]{68}
[19:14] <Rei-chan> Ebiris rolled : 1d20+68 channelled vivacious flux grasp, 13th level arcane strike, divine might --> [ 1d20=20 ]{87}
[19:14] <@Ebiris> roll 1d20+62 channelled vivacious flux grasp, 13th level arcane strike, divine might - if Lixer is still alive add 30 to this for moment of prescience, won't bother if it hits a lich instead
[19:14] <Rei-chan> Ebiris rolled : 1d20+63 channelled vivacious flux grasp, 13th level arcane strike, divine might - if Lixer is still alive add 30 to this for moment of prescience, won't bother if it hits a lich instead --> [ 1d20=12 ]{74}
[19:14] <Rei-chan> Ebiris rolled : 1d20+63 channelled vivacious flux grasp, 13th level arcane strike, divine might - if Lixer is still alive add 30 to this for moment of prescience, won't bother if it hits a lich instead --> [ 1d20=16 ]{78}
[19:14] <@Ebiris> roll 1d20+67 channelled vivacious flux grasp, 13th level arcane strike, divine might crit check
[19:14] <Rei-chan> Ebiris rolled : 1d20+68 channelled vivacious flux grasp, 13th level arcane strike, divine might crit check --> [ 1d20=11 ]{78}
[19:17] <@Ebiris> roll 6d6+55+3d6+2d6+13d4+2*30d12
[19:17] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=32 3d6=11 2d6=4 13d4=26 30d12=211 ]{550}
[19:17] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=15 3d6=11 2d6=11 13d4=34 30d12=221 ]{568}
[19:17] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=17 3d6=12 2d6=9 13d4=33 30d12=196 ]{518}
[19:17] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=22 3d6=14 2d6=9 13d4=25 30d12=190 ]{505}
[19:18] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=23 3d6=3 2d6=6 13d4=31 30d12=212 ]{542}
[19:18] <@Ebiris> roll 6d6+55+3d6+2d6+13d4+2*30d12
[19:18] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=13 3d6=11 2d6=3 13d4=34 30d12=232 ]{580}
[19:18] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=18 3d6=12 2d6=8 13d4=26 30d12=202 ]{523}
[19:18] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=21 3d6=14 2d6=5 13d4=30 30d12=191 ]{507}
[19:18] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 --> [ 6d6=19 3d6=9 2d6=3 13d4=27 30d12=161 ]{435}
[19:18] <@Ebiris> roll 6d6+55+3d6+2d6+13d4+2*30d12 this is if that 20/79 didn't crit
[19:18] <Rei-chan> Ebiris rolled : 6d6+55+3d6+2d6+13d4+2*30d12 this is if that 20/79 didn't crit --> [ 6d6=22 3d6=7 2d6=4 13d4=40 30d12=212 ]{552}
[19:18] <@Ebiris> roll 12d6+110+6d6+2d6+13d4+2*60d12 this is if that 20/79 did crit
[19:18] <Rei-chan> Ebiris rolled : 12d6+110+6d6+2d6+13d4+2*60d12 this is if that 20/79 did crit --> [ 12d6=36 6d6=19 2d6=6 13d4=36 60d12=325 ]{857}
[19:19] <@Ebiris> roll 1d20+1 rank check to see if I can inflict negative levels on Lixervatar past his divine immunity
[19:19] <Rei-chan> Ebiris rolled : 1d20+1 rank check to see if I can inflict negative levels on Lixervatar past his divine immunity --> [ 1d20=7 ]{8}
If that passes each hit delivers 1 negative level (2 on the crit).
Anyone hit needs to make a DC 37 fort save or suffer -10 to both armour and natural armour. It's a penalty so doesn't stack with itself.
I have a swift action left to spend depending on how things look at the end of that. Let me know if I had to expend those moments of prescience too?
Alicia: 500/884
Sorcerer spell slots: 6/9/8/4/5/4/4/8/6/7/4/4/4/2
Even with his magic crumbling, spells fading as others stay up, Lixer's robed avatar moves deftly. His staff lashes out to parry away one blow, as another hits a glimmering field of force. Yet you push, and with a sudden kick, catch him in the chest. It's enough to knock him a step back and deliver a massive, double handed swing that goes from head to middle, black blood falling from the sound. Yet in spite of that massive blow, the avatar is still up, half blindingly parrying another attach, as another and another is deflected.
> roll 1d20+5 rank check
<Rei-chan> Kotono rolled : 1d20+5 rank check --> [ 1d20=19 ]{24}
Take your swift.
Edit: Flux grasp is an autopass.
