Dark Rumblings
Alicia wonders briefly who's been closing the doors behind all these vermin after setting them up in various rooms.
It made Marie's barrage less effective though, that can't be denied. They'll need to come up with a solution so she can better attack structures with it.
Still though, why are the vermin fleeing? Is there magic guiding them, or some sort of hivemind?
Alicia uses alter reality for some sort of souped up detect thoughts solely to discern the intelligence score of the vermin immediately rather than waiting 2 rounds.
Marie has greater arcane sight to see if any spells are on them.
You sense it. Intelligence super human indeed (28).
There are no active spells on the vermin.
"There's some form of gestalt intelligence at hand. Slay them," Alicia says to her companions, assuming that killing more of the vermin will weaken the hive mind or central brain or whatever. Her own gesture sends a wall of scything force blades all the way down the corridor to the end, churning up the vermin within.
We can roll init if necessary but with supreme init Alicia can get her first shot off unopposed.
Blade Barrier SLA used.
[20:13] <@Ebiris> roll 1d20+31 blade barrier SR
[20:13] <Kobot> Ebiris rolled 1d20+31 blade barrier SR --> [ 1d20=5 ]{36}
[20:13] <@Ebiris> roll 15d6
[20:13] <Kobot> Ebiris rolled 15d6 --> [ 15d6=46 ]{46}
DC 38 ref half.
Natural 20s happen.
> roll 1d20+4 REf
<Kobot> Kotono rolled 1d20+4 REf --> [ 1d20=20 ]{24}
Marie, going to throw in any offense here yourself?
#229
Marie raises her hand and a blast of holy power detonates down the corridor!
Righteous Smite SLA
[20:32] <@Ebiris> roll 1d20+31 righteous smite SR
[20:32] <Kobot> Ebiris rolled 1d20+31 righteous smite SR --> [ 1d20=18 ]{49}
[20:32] <@Ebiris> roll 20d6
[20:32] <Kobot> Ebiris rolled 20d6 --> [ 20d6=68 ]{68}
[20:32] <@Ebiris> roll 20d8 damage to evil outsiders if applicable
[20:32] <Kobot> Ebiris rolled 20d8 damage to evil outsiders if applicable --> [ 20d8=106 ]{106}
[20:33] <@Ebiris> roll 1d4 blind duration
[20:33] <Kobot> Ebiris rolled 1d4 blind duration --> [ 1d4=4 ]{4}
DC 31 will half, saving also negates blindness.
EDIT: Alicia's blade barrier was reflex negates, not reflex half.
Area of effect on that?
> roll 1d20+5 Will
<Kobot> Kotono rolled 1d20+5 Will --> [ 1d20=14 ]{19}
Ebony bows her head as holy energy slams into the sacs, but it is not enough. Some are vaporized by more are beyond it. "So be it," Ebony murmurs. Her hood is up as she bows her head in supplication, fingers tracing a circle in the air that glows with golden light. Rays of it emanate out all over, to which Ebony grasps it and intones, "The dawn in here!" before she hurls it, becoming a javelin of pure sunlight.
Purified Sunlance, so the sunburst radius isn't any threat to all of you.
> roll 30d8
<Kobot> Kotono rolled 30d8 --> [ 30d8=137 ]{137}
> roll 6d8
<Kobot> Kotono rolled 6d8 --> [ 6d8=21 ]{21}
> roll 1d20+4 Ref half
<Kobot> Kotono rolled 1d20+4 Ref half --> [ 1d20=16 ]{20}
A tremendous flash of sunshine blows the morning breeze across the room, the scent of vermin washed away. When the light clears, the sacs are bleached away and empty, only fragments of them left and the way ahead is clear.
Ebony
HP: 570+20/570
Bonuses: Attack+7 (+4 morale, +3 luck), Damage+0 AC+15 (+15 armor), Saves+7 (+4 morale, +3 luck), Skills+4 (+4 morale), Checks+0
Resources: Channel Energy 13/13 Dispel Evil 3/3 (week) Holy Aura 1/1 Bardic Music 30/30
Spells Used: 1 11th level sorc, 1 12th level sorc
SLAs Used:
Spells Active: Greater Heroism (CL31), Death Ward (CL31), Recitation (CL31), Mass Energy Immunity (Cold) (CL31), Epic Mage Armor (CL31)
Notes: Include doubler for WoC on bardic music.
[/quote]
Nodding in satisfaction, Alicia dismisses her blade barrier and leads the way along to then open the door to the north halfway down the hall.
This room narrows near the top, altogether a small room with a door north, east and west. The room itself is full of supplies - bows, arrows, crossbow bolts and the like. Thousands of them surely, all neatly stacked up in barrels. Above them on the walls are bows and crossbows. The floor has colored stone making an image - of the armored warrior, leading archers in a charge against wild beasts, his own gestures bringing lightning down on them. Yet shadows loom around the warrior, creeping into him, overwhelming him.
The images of the bowmen slowly becomes one of horror, their lines breaking before your eyes as they flee, the image coming alive before your eyes. They flee as if the stone was real, the image rippling from the change.
Discordant words of darkness fill the room. The Dark Speech, its words anathema to your ears. "Hide, scurry away, hide like the vermin you are. Join us." The shadows writhe as insects come out from behind the barrels, skittering up the walls, to the ceiling. They rise up from the floor, a flickering image of a humanoid, gray and empty. It hisses, "The holy light!" it wails, throwing up its arms to shield its face from you.
Any knowledge to identify what/who this is? And if it's really here or just a magical projection? (Alicia has arcane sight up and Marie has the greater version)
[17:48] <@Ebiris> roll 1d20+65 Marie religion
[17:48] <Kobot> Ebiris rolled 1d20+65 Marie religion --> [ 1d20=18 ]{83}
Marie: 515+20/515
Sorcerer spell slots: 6/9/10/8/7/7/6/6/7/7/6/4/3
Avatarlicia: 706+60/706
Sorcerer spell slots: 6/13/12/10/9/9/11/8/7/4/7/6/6/4
Duskblade spell slots: 6/17/17/16/9/4
It is a greater shadow, enhanced and grown powerful on time and sacrifice. Stronger than a normal shadow and with the insects here as a complication, it is yet no serious threat to ones such as you.
"Fool," Alicia says contemptuously as a burst of sunlight detonates in the room.
Supreme init wins.
Sunburst SLA
[18:10] <@Ebiris> roll 1d20+31 sunburst SR
[18:10] <Kobot> Ebiris rolled 1d20+31 sunburst SR --> [ 1d20=16 ]{47}
[18:10] <@Ebiris> roll 6d6 vermin damage
[18:10] <Kobot> Ebiris rolled 6d6 vermin damage --> [ 6d6=20 ]{20}
[18:10] <@Ebiris> roll 25d6 undead damage
[18:11] <Kobot> Ebiris rolled 25d6 undead damage --> [ 25d6=89 ]{89}
DC 41 ref half, blinded if save fails. Also destroys undead weak to sunlight? Dunno if that works with the no save or die rule.
