Dark Rumblings
Behind the stairs, the wall radiates magic.
Skipping a CL check you can't fail.
Greater arcane sight automatically identifies spells in sight without needing to roll spellcraft.
An illusion hides a door behind it.
"Hidden door here," Marie says to Alicia, going over to open it up!
Here lies a room. A room with the Eye of Shar engraved into the floor, glowing with a faint purple light that casts deep shadows over the room. In the center lies a stairway going even deeper into the ground.
A slender line of silver fire whips out from Alicia's fingertip and defaces that eye engraving, scoring two deep gouges criss-crossed over it. Then the two of them descend those stairs - the shadows went down after all!
On silver fire touching the eye, the glow sputters out and fades, the gouges remaining.
Deeper within you find the stairs end. At the bottom sits a stone archway, colored purple and black in alternating bands. There is no light coming from it - for Marie can discern and identify the powerful, unholy magic of utterdark when she sees it.
"Utterdark spell," Marie says helpfully.
"I'll handle it then," Alicia says, a mage's disjunction rippling around the archway.
[19:17] <@Ebiris> roll 1d20+31 disjunction vs utterdark
[19:17] <Rei-chan> Ebiris rolled : 1d20+31 disjunction vs utterdark --> [ 1d20=16 ]{47}
Any other dispel checks to be made for other stuff within the 40ft radius?
Marie: 515/515
Active spells: Extended superior resistance (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), extended repelling shield (CL 31), bibliotheca arcana (CL 31), extended nondetection (CL 31), sensual blessing (CL 31), extended ray deflection (CL 31)
Defences: AC 93 (touch 35), CMD 76, spell resistance 45, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), protective aura, nondetection (DC 46), ray deflection
Stat buffs/penalties: +11 shield AC, +15 insight knowledge, +25 perception
Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, tremorsense 60, blindsight 60, perception +71
Sorcerer spell slots: 6/9/8/8/7/7/6/6/6/7/6/4/2
Avatarlicia: 582/582
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 31), ghost touch weapon (CL 31), epic mage armour (CL 31)
Defences: AC 69 (touch 32), CMD 73, spell resistance46, status immunity (polymorph, petrification, disease, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 47)
Stat buffs/penalties: +13 armour
Sorcerer spell slots: 6/13/12/11/9/9/11/8/8/8/7/6/7/4
Duskblade spell slots: 6/17/17/16/9/6
[19:24] <@Ebiris> roll 5#1d20+31
[19:24] <Rei-chan> Ebiris rolled : 5#1d20+31 --> [ 1d20=6 ]{37}, [ 1d20=20 ]{51}, [ 1d20=13 ]{44}, [ 1d20=13 ]{44}, [ 1d20=16 ]{47}
Magic is torn away, darkness sundered. Ahead is a hall decorated with Sharran symbols and the Eye of Shar, another door ahead. At this door stands a skeleton, a large creature, perhaps a troll. It begins to move as you come into sight, currently 55ft away.
Said skeleton promptly explodes in a blast of sunlight as Alicia and Marie stride onwards.
Supreme initiative means I can't fail, if it survives we can roll for the skelly and Marie.
[19:53] <@Ebiris> roll 25d6 sunburst
[19:53] <Rei-chan> Ebiris rolled : 25d6 sunburst --> [ 25d6=88 ]{88}
DC 41 ref half, blinded if save fails.
The skeleton is simply vaporized, turn to ash in a second.
There was no point rolling for init there, yeah. Go ahead, the door deeper in is now unguarded.
"You know we might be a bit over the top for this one," Marie says to Alicia as she goes ahead to check the door for traps while Alicia defaces the Sharran eye symbols with more slender whips of silver fire.
[20:05] <@Ebiris> roll 1d20+71 perception
[20:05] <Rei-chan> Ebiris rolled : 1d20+71 perception --> [ 1d20=2 ]{73}
"Perhaps," Alicia allows. "But I wouldn't take it for granted. Something worse might be below, or yet to appear."
